10 Reasons to Use Flat Bottom Tools
Flat Bottom Drills
Thin Plate Drilling
Crosshole Drilling
Angled Drilling
Half Hole Drilling
Bore & Finish Drilled Holes
Straighten Misaligned Holes
The unique geometry of flat bottom counterbores makes them effective at spotting on irregular surfaces. Standard drills and spot drills are susceptible to walking on these kinds of surfaces, which can potentially ruin an operation.
Remove Drill Points
Remove End Mill Dish
I am curious if anyone has any experience using flat bottom drills and if anyone knows what kind of finish and size tolerances can flat bottom drills be expected to maintain.
Rooney is that you? I am also looking for the same answer
Thank you for your question! Harvey Tool Flat Bottom Drills have a diameter tolerance of +.000mm/-.013mm. This tool is ideal for both inclined and rounded surfaces, and reduces burrs on break through what its flat bottom design (no point angle and no dish).
Please feel free to give our tech team a call for more information. You can reach us at 800-645-5609.
Thanks!
Hey, just wondering. What is the difference between an end mill and a flat drill?
What characteristics make them different?
Is there going to be a centering problem using just a flat drill without spotting it first?
We always suggest spotting before drilling to reduce the wear and tear on your drill, but you should not have any issue with using a flat bottom drill without spotting. Flat bottom drills allow you to drill on irregular surfaces and reduces burrs on break through. They are ideal for drilling on inclined and rounded surfaces, creating flat bottom holes, tilted drilling for angled holes, and drilling intersecting holes, half holes, shoulders, or thin plates.
I’m having a issue with drills getting sucked down when trying to drill thru holes in .125 thick plates. Will a Drill like this eliminate this problem?
Hello Al,
Flat Bottom Tools might be able to help you in this circumstance but it would be better to talk through the whole application with one of our technical experts. Please send an email to [email protected] with all your application information and they can help figure out the best way to fix your problem.
Getting stuck in only 1/8 ” thick…. sounds like a programmer issue
Many thanks for you kind and efficient service.
I like your tool tips. I need to have a hole drilled in the ground. I’ll have to hire a contractor to get it done.
Great insights on flat bottom tools! I especially appreciate how you highlighted their versatility and efficiency in various applications. I can’t wait to try some of these techniques in my own projects!
Great insights on flat bottom tools! I hadn’t considered how they could improve accuracy and reduce cycle times — definitely going to implement some of these tips in my next project. Thanks for sharing!
Great article! I never realized how versatile flat bottom tools are until I read this. The benefits for achieving precision in machining really stood out to me. I’m excited to incorporate these tools into my projects!
