Part Finish Reference Guide
Common Finishing Problems
- Burrs
- Scallop marks
- Chatter Marks
Factors That Influence Part Finish
- Specific material and hardness
- Cutting tool speeds & feeds
- Tool design and deployment
- Tool projection and deflection
- Tool-to-workpiece orientation
- Rigidity of workholding
- Coolant and lubricity
- Final-pass depth of cut
Finishing Problem Solutions
- Tools with high helix angles and flute counts work best for finishing operations. Softer materials show great results with higher helices, while harder materials can benefit greatly from increased flute counts.
- Increase your RPM and lower your IPT (Figure 2).
- Ensure that tool runout is extremely minimal.
- Use precision tool holders that are in good condition, are undamaged, and run true.
- Opt for a climb milling machining method.
- Use tooling with Variable Pitch geometry to help reduce chatter.
- A proper radial depth of cut (RDOC) should be used. For finishing operations, the RDOC should be between 2 and 5 percent of the tool’s Cutter Diameter.
- For long reach walls, use reduced neck tooling which help to minimize deflection (Figure 3).
- Extreme contact finishing (3x cutter diameter), may require a 50% feed rate reduction.
Common Surface Finish Nomenclature
Ra = Roughness average
Rq = RMS (Root Mean Square) = Ra x 1.1
Rz = Ra x 3.1
