infographic showcasing all aspects axii for high balance machining
cnc high balance end mills in both 2 and 3 flute designs
Utilizing Tap Testers
What Tap Testers Do
How Tap Testing Works
how to properly tap test a cnc tool
Shank Tolerances, Collet Fits, & h6 Benefits
A cutting tool’s shank is one of the more vital parts of a tool, as it’s critical to the collet-tool connection. There are several types of shanks, each with their own tolerances and suitable tool holder methods. One of the most popular and effective tool holding styles is a shrink fit tool holder, which works with h6 shanks, but what does this mean and what are the benefits of it? How is this type of shank different from a shank with standard shank tolerances? To answer these questions, we must first explore the principals of tolerances.
The Principals of Tolerances
Defining Industry Standard Tolerances
There are two categories of shank tolerances that machinists and engineers operating a CNC machine should be familiar with: hole basis and shank (or shaft) basis. The hole basis system is where the minimum hole size is the starting point of the tolerance. If the hole tolerance starts with a capital “H,” then the hole has a positive tolerance with no negative tolerance. The shank basis system is where the maximum shank size is the starting point. This system is relatively the same idea as the hole basis system but instead, if the tolerance starts with a lowercase “h,” the shank has a negative tolerance and no positive tolerance.
Letter Designations
The limits of tolerance for a shank or hole are designated by the appropriate letter indicating the deviation. For instance, the letter “k” has the opposite minimum and maximum designations as “h”. Tolerances beginning with “k” are exclusively positive, while tolerances beginning with “h” are exclusively negative. The number following the given letter denotes the International Tolerance (IT) grade. For example, a tolerance with the number 6 will have a smaller tolerance range than the number 7, but larger than the number 5. This range is based on the size of the shank. A hole that has a 0.030” diameter will have an h6 tolerance of (+0.0000,-0.0002), while a 1.00” hole with have an h6 tolerance band of (+0.0000,-0.0005).
It is important to note that most sources list IT tolerances in millimeters, while the graph below has been translated to inches. Operations that require more precise manufacturing, such as reaming, will have lower IT grades. Operations that do not require manufacturing to be as precise will have higher IT grades.
graph showing shank tolerances vs diameter
Preferred Collet Fits
Different types of combinations of hole basis and shank basis tolerances lead to different types of collet fits. The following table offers insight into a few different types of preferred fits and the shank tolerances that are required for each.
infographic of collet fits and the associated clearance
Image: Machinery’s Handbook 29th Edition.
Shrink Fit Tool Holders
The shrink fit holder is one of the more popular styles of tool holders because of its ability to be more customizable, as evident in the chart above. In this method, a collet is heated to expand, then cooled to contract around the shank of a tool. At room temperature, a cutting tool should not be able to be inserted into a shrink fit holder – only when the holder has undergone thermal expansion due to the introduction of a significant amount of heat should the tool fit. As the holder cools, the tool is held tighter and tighter in place. Typically, a holder is heated through a ring of coils by an induction heater. It is important to heat the holder uniformly, paying mind to not overheat it. Doing so could cause the shank that is being held to expand within the holder and remain stuck.
Benefits of Shrink Fit Tool Holders
  1. Gripping power. The shank is held flush and uniform against the holder, resulting in a tighter connection.
  2. Low runout. A more secure connection will result in extended tool life, and a higher quality surface finish.
  3. Better balance for high RPM. With a tighter tool-to-holder connection, the opportunity exists for more aggressive running parameters.
Explore More About Tool Holders With Our Cutting Tools Explained Webinar
Shank Tolerances Summarized
Understanding shank tolerances is an intricate part of the machining process as it impacts which tool holder is appropriate for your job. A secure holder connection is vital to the performance of the tool in your application. With an h6 shrink fit holder, the result is a secure connection with stronger gripping power. However, only certain shanks are able to be used with this type of holder. From the letter designation assigned to a shank, to whether that letter is upper or lowercase, each detail is vital to ensuring a proper fit between your tools shank and its corresponding shrink fit holder.
The Importance of Tolerances
close up of a shaped of slot from a corner radius end mill and its tolerances
stacking tolerances
standard deviation
tolerance stacking
standard deviation
root sum
Click Here to Learn More
Use Worst Case Analysis:
For the left corner radius
.125” – .001” = .124”
For the flat section
.250” – .002” = .248”
For the right corner radius
.124” + .248” + .124” = .496”
.125” + .001” = .126”
.250” + .002” = .252”
.126” + .252” + .126” = .504”
  1. Drilling
  2. V-Grooving
  3. Milling
  4. Spot Drilling
  5. Chamfering
5 unique drill mill operations
graphic showcasing the tool face differences between and mill and drill mills
Drill Mills: Tool Offering
Mill Style – 2 Flute
harvey tool 2 flute mill style drill end mill
Mill Style – 4 Flute
harvey tool 4 flute mill style drill mill
Drill Style – 2 Flute
2 flute drill mills drill style
Helical Tip – 4 Flute
Traditional Roughing
helical solutions ball end mill for stainless steels
High Efficiency Milling
HEV-5
Machining Advisor Pro
Harvey Tool: Behind the Scenes
Many of our end users have had great questions about our manufacturing process, how we keep all of our tools in stock, and more. Now for the first time, we decided to open our doors and show you how we manufacture and fulfill the Harvey Tool product. We partnered with John Saunders from NYC CNC to create a “Factory Tour” video, covering topics like our CNC grinding machines and setups, tool manufacturing, and our warehouse organization and fulfillment procedures.
In the video below, we first toured our Rowley, MA warehouse and fulfillment center with Fulfillment Manager Megan Townsley. After that, we head up to Maine to check out how the Harvey Tool product is manufactured and inspected with VP of Operations Brian McKahan.
We know you’re busy making amazing parts, and might not have time for the entire video. To save you time, here are some of the highlights and facts you should know about Harvey Tool.
When We Say Miniature, We Mean Miniature
Our miniature end mills are in stock in diameters down to .001″. In fact, our Stub and Standard end mills cover every diameter from .001″ to .120″, meaning we will always have you covered when it comes to micro-machining. Although it is hard to see with the naked eye, you can get an up-close look at the famed .001″ end mill by jumping to the 35 minute mark in the tour video.
Micro-Tools Require Precision Grinding
We utilize advanced CNC grinding technology to manufacture our miniature tools at our plant in Maine. Brian MacKahan, VP of Operations, does an excellent job of breaking down our manufacturing process beginning at the 21 minute mark of the tour video. If you just want to see some miniature CNC grinding in action, jump ahead to the 26 minute mark.
Our Inspection Process is Rigourous
All of our tools are sent through an extensive inspection process, both at our plant in Maine and at our headquarters in Massachusetts. To check out the Massachusetts inspection room, head to the 19 minute mark of the video. If you want to see some more in-depth inspection at our facility in Maine, you can jump to the 35 minute mark.
Yes, We Have It In Stock
If you need it, we have it. All 20,000+ tools from our catalog are kept stocked and ready to ship to you the same day. If you need more proof, jump to 15:30 in the tour video, where you will see John Saunders choose a randomly selected Undercutting End Mill from our catalog and find it in our warehouse, in stock and ready to head out to a shop.
We Maintain a 99.8% Order Accuracy Rate
Our fulfillment team handles all of your orders with precision and accuracy. We maintain a 99.8% order accuracy rate, with fulfillment team members checking every order multiple times to ensure you receive exactly what you need. You can learn more about our order fulfillment process and accuracy rates by moving to the 5 minute mark in the video.
We Sell More Than Miniature
Miniature end mills have always been our bread and butter, but did you know that we have many larger diameter tools in stock as well? At the 9 minute mark in the video, you can see John pull out a 3/4″ Long Reach Ball Nose End Mill from our shelves. If you are interested in larger diameter specialty tooling, jump to 12:15 in the video to check out one of our large diameter Corner Rounding End Mills.
When You Call, You’ll Always Talk to An Experienced Tech Expert
Though we didn’t catch it on tape, John Saunders was blown away by our tech team during his visit. He got a chance to pick their brains about a problem he was having and a few minutes later, he received a recommendation for the right compression cutter to tackle his unique operation. This tool was later showcased in one of his “Widget Wednesday” videos.
When you choose Harvey Tool, you will never get an automated system or countless steps before you are able to talk to a real person about your applications. Our industry-leading technical support team is available over the phones or via email every Monday-Friday from 8 AM EST to 7 PM EST. You can reach them by calling 800-645-5609, or by sending an email to [email protected].
We Value Our Distributor Network
We value our large distributor network, and we ask that all orders are placed with your local dealer. To find the closest distributor to you, use the “Find a Distributor” tool on our website.
We’re Hiring!
We are currently hiring for many different positions, including open CNC Machinists positions for all shifts at our manufacturing plant. If you want to be a part of the Harvey Performance Company team, check out our Opportunities page for more information.
Helical Solutions: Behind the Scenes
We have shown our end users bits and pieces of our manufacturing process on our website and via social media, but for the first time we decided to open our own doors to the public and show you every step behind how we manufacture and fulfill the Helical Solutions product. We partnered with John Saunders from NYC CNC to create a “Factory Tour” video, covering topics like our CNC grinding machines and setups, tool manufacturing, and our warehouse organization and fulfillment procedures.
In the video below, we first toured our Gorham, Maine manufacturing plan with Plant Manager Adam Martin. Then, we ran a few tests with the Helical tools on our Haas machine, before heading back to our warehouse in Massachusetts to talk about fulfillment and new products with Fulfillment Manager Megan Townsley.
We know you’re busy making amazing parts, and might not have time for the entire video. To save you time, here are some of the most important facts you should know about Helical.
We Take Quality Control Seriously
Our high performance end mills go through an extensive inspection and quality assurance process before they end up in your machine, with multiple inspection points along the manufacturing journey. At the 17 minute mark of the video, you can learn more about how we monitor the quality of the tools in batches as they are manufactured. If you skip ahead to the 29 minute mark, you can see some of our more advanced inspection machines in action.
We Stand Behind Our Tools with Our Renewal Services
Our Tool Renewal service is a great way to maximize your cost-savings and avoid having to re-purchase new tools without sacrificing any aspects of the original design. At Helical, we do not re-sharpen tools. Rather, we restore your tools to their original geometry. We will review the condition of your used tools and return the cutting edge to its original sharpness and strength, allowing the tool to retain its outstanding performance. The renewed tools go through the same rigorous inspection, edge prep, and coating process that we follow for all our of our new tools. To learn more about our Tool Renewal services, head to the 23:30 mark in the video.
Our Tool Coating Is Done In-House
We have multiple tool coating machines in-house which allow us to take the ground tools right off the line and transfer them to our coating room to have Aplus, Zplus, or Tplus coatings added. These machines also have the capability to create roughly 20 different coatings, which are reserved for specials and custom orders. If you want a close-up look at the coating room and learn how the PVD coating process actually works, head to the 35 minute mark.
Our Standard Catalog Items Are Stocked and Ready for Your Machine
We don’t make our standard catalog tools to order. All of our standard tools are stocked and ready to make some chips in your machine. We also introduce hundreds of new tools to our annual catalog to keep providing our customers with the latest in high performance tooling technology. You can check out our new tools for 2018, including our new High Balance Tools and Metric Tooling, by heading to 52:20, or take quick look at our rows of stocked tools in our warehouse by jumping to 56:55.
Diamond Wheels Grind Carbide Tools
Diamond grinding wheels are the essential tool (outside of the machine) when it comes to grinding carbide. We have a unique management system for our diamond wheels, and a redressing process which can see these wheels last up to a year or more before they need replacement. Adam goes through our “frozen wheel” room with John at the 32:45 mark in the video above.
We Track Every Batch of Tools With Laser Etching
Our tools are all laser etched on-site with our logo, phone number, and tool description, but also with a specific batch number. These batch numbers allow us full track-ability of every tool so we can quickly asses any questions or concerns a customer may have about a tool. With these numbers, we are able to track the tool’s journey all the way back to which machine it was made on, which grinding wheel was used, and who ran the program. We have a couple of these laser etching machines in Maine, which you can see in action at the 42 minute mark.
If You Can Dream It, We Have Probably Made It
We have had some crazy tool drawings come in to our custom tool program over the years, including oddly shaped form tools, tools with a crazy long length of cut, “paper cutters”, and more. You can see some cool examples of custom tools we have manufactured by jumping to the 20 minute mark. If you are more interested in how we actually make them, head to the 27 minute mark to see one of our large custom tools being ground on our Walter machines.
Our Technical Resources Are Second To None
We don’t leave you hanging after your purchase of Helical tools. We have a multitude of technical resources and How-Tos available here on our blog, and we also offer the HEM Guidebook, a complete guide to High Efficiency Milling techniques.
If you are looking for information on speeds and feeds, we suggest you try our Machining Advisor Pro application. This application is designed to increase metal removal rates and shop productivity by generating customizable running parameters optimized for your Helical Solutions end mills. You can click here to get started with Machining Advisor Pro today.
You Will Always Get a Real Person When You Call Helical
If you have technical questions about an upcoming job, a special application, or tooling selection, you can contact Helical by phone at 866-543-5422. Our technical experts are available over the phone Monday-Friday from 8 AM to 5 PM EST, and you will always get a real person to talk to with no automated systems to navigate through. You can also reach our team by email at [email protected].
Questions about where to buy Helical tools? You can give our team a call, or you can find your local distributor by using the “Find a Distributor” tool on our website. Simply choose your state to see a complete list of authorized distributors in your area.
We’re Hiring!
We have a current list of our open opportunities on our website! Open jobs include CNC Machinist, Quality Control Inspector, and Customer Service Representative.
Harvey Tool Fall 2018 Catalog Contest
Show Us How You #MachineTheImpossible with Harvey Tools!
Has Harvey Tool helped you #MachineTheImpossible? If so, snap a picture of your finished part, the Harvey Tool used, and tell us your story for a chance to be featured on the cover of our Fall 2018 catalog!
Did Harvey Tool help you get through a tough application? Did a miniature end mill help you machine an intricate feature? Did you use a variety of tools to make one impressive part? Have you had to substitute a tool unexpectedly? We’d like to see! Show us how you #MachineTheImpossible.
How to Participate
Using #MachineTheImpossible and @harveytool, tag your photo of the finished part and the Harvey Tool end mill(s) used to machine it. Remember, don’t share anything that could get you in trouble! Proprietary parts and trade secrets should not be on display.
Official Contest Rules
Contest Dates:
  • The contest will run between June 1, 2018 and June 15, 2018. Submit as many entries as you’d like! Entries that are submitted before or after the contest period will not be considered for a feature on the catalog cover. (But we’d still like to see them!)
The Important Stuff:
  1. Take a photo of your finished part and the Harvey Tool end mill(s) used to machine it.
  2. Share your photo on social media using #MachineTheImpossible and tagging @HarveyTool.
  3. Detail the story behind the project (tool number (s), operation, running parameters, etc.)
Catalog Cover Feature
All submissions will be considered for a featured spot on our Fall 2018 catalog cover. Of these entries, the most impressive will be put up to popular vote.
We’ll pick our favorites, but the final say is up to you. Stay tuned for details on when official voting will open to the public!
Need More Incentive?
The Top 10 selected winners will also receive a Harvey Tool Prize Pack and be entered into consideration to appear as a “Featured Customer” on our blog!
The Fine Print:
  • Please ensure that you have permission from both your employer and customer to post a finished part.
  • All entries must be the original work of the person identified in the entry.
  • No purchase necessary to enter or win. A purchase will not increase your chances of winning.
  • On June 25, 2018 the top 10 winners will be announced to the public. The Top 10 selected winners will receive a prize. The odds of being selected depend on the number of entries received. If a potential winner cannot be contacted within five (5) days after the date of first attempt, an alternative winner may be selected.
  • The potential winners will be notified via social media. Each potential winner must complete a release form granting Harvey Tool full permission to publish the winner’s submitted photo. If a potential winner cannot be contacted, or fails to submit the release form, the potential winner forfeits prize. Potential winners must continue to comply with all terms and conditions of these official contest rules, and winning is contingent upon fulfilling all requirements.
  • Participation in the contest constitutes entrant’s full and unconditional agreement to and acceptance of these official rules and decisions. Winning a prize is contingent upon being compliant with these official rules and fulfilling all other requirements.
  • The Harvey Tool Catalog Contest is open to residents in US and Canada who are at least 18 years old at the time of entry.
Composite Materials
  2. Uncut Fibers
  3. Fiber tear-out
  4. Uneven tool wear
Straight Flute End Mill
straight flute end mill
Compression Cutters
compression cutter end mill
Chipbreaker Cutter
Diamond Cut End Mill
Composite Finisher
Coating or No Coating?
bag of copper chips from cnc machining
Coolant
Tool Engagement
infographic showcasing the rotation and movement of a cutting tool in climb milling
Initial Workpiece Engagement
Gummy Materials Summarized
