Ramping to Success
ramping
What is Ramping?
ramping
Benefits of Ramping
climb milling
Climb Milling (Figure 3)
climb milling
Cutting With Dovetails
Avoiding Tool Failure
dovetail cutters
dovetail cutters
dovetail cutters
dovetail cutters
5. Failing to Climb Mill.
6. Improper Chip Flushing.
7. Giving the Job Away.
How To Avoid Common Part Finish Problems
Harvey Tool’s Miniature High Performance Composite Drills are specifically designed with point geometry optimized for the unique properties of composite materials. Our Double Angle style is engineered to overcome common problems in layered composites and our Brad Point style is built to avoid the issues frequently experienced in fibrous composites.
Cutting Circular Tool Paths
Internal Circular Tool Paths
External Circular Tool Paths
Optimize Your Performance
Selecting the Right Plastic Cutting End Mill
Choose Workholding Method
plastic cutter selection
Determine Heat Tolerance
The amount of heat generated should always be considered prior to any machining processes, but this is especially the case while working in plastics. While machining plastics, heat must be removed from the contact area between the tool and the workpiece quickly and efficiently to avoid melting and chip welding.
For plastics with a higher heat tolerance, a Two or Three Flute Plastic Cutting End Mill can be utilized. Because it has more cutting edges and allows for higher removal rates, its tool life is extended.
The polymer arrangement in plastics can cause many burrs if the proper tool is not selected. Parts that require hand-deburring offline after the machining process can drain shop resources. A sharp cutting edge is needed to ensure that the plastic is sheared cleanly, reducing the occurrence of burrs. Three Flute Plastic Cutting End Mills can reduce or eliminate the need to hand-deburr a part. These tools employ an improved cutting action and rigidity due to the higher flute count. Their specialized end geometry reduces the circular end marks that are left behind from traditional metal cutting end mills, leaving a cleaner finish with minimal burrs.
Flute Count Case Study
3 FLUTE PLASTIC FINISHER: A facing operation was performed on a separate acrylic piece with a specialized 3 Flute Plastic Finisher End Mill. The specialized cutting end left minimal swirling marks and resulted in a smoother finish.
Use Proper Tooling
Axial Depth of Cut (ADOC)
To support the thin wall during the machining process, keep a wide-cross section behind it. We recommend utilizing a “stepped down” approach, which divides the total wall height to manageable depths while working each side of the wall. The Axial Depth of Cut (ADOC) dimension will vary depending on the material (and its hardness) being cut.
thin wall milling
Radial Depth of Cut (RDOC)
thin wall milling
  • Climb milling will help to keep tool pressure to a minimum.
  • Manual vibration dampening and wall stabilization can be achieved by using thermoplastic compounds, or wax, which can be thermally removed.
  • The use of ultra-high performance tool paths can optimize tool performance.
Avoid Tool Deflection
deep cavity milling
deep cavity milling
Achieve Optimal Finish
Deep Cavity Milling
Mill to the Required Depth
Evacuate Chips Effectively
that must be avoided.
Deep Cavity Milling
How To Combat Chip Thinning
Defining Chip Thinning
Chip Thickness
How Chip Thinning Occurs
radial chip thinning
Lasting Benefits
