Confidently Select Your Next Thread Mill
Thread Mill Product Offering
Single Form
single form harvey tool thread mill
  1. Ground Flat – Instead of a sharp point these tools have a ground flat to help ensure long tool life.
  2. Eccentric Relief – Gives the cutting edges extra strength for the high feeds at relatively low RPMs required for harder materials.
  3. AlTiN Nano Coating – Allows for superior heat resistance.
single form thread mill for hardened steels
Tri-Form
tri form thread mill from harvey tool
Multi-Form
coolant through multi form thread mill
Long Flute
long flute harvey tool thread mill
N.P.T. Multi-Form
npt thread mill from harvey tool
Understanding the Distinctions
harvey tool marking cutters ad
harvey tool doubled ended engraving cutter
Harvey Tool Product Offering
types of cnc engraver tips, pointed, radiused, and tipped-off
Choosing the Right Tool
Corner Rounding End Mill with dimension callouts
2 flute and 4 flute corner rounding end mills with 5° flares
Front or Back
harvey tool back Corner Rounding End Mill
These tools are often offered in 2, 3, and 4 flute styles.  2 flute styles are normally used for aluminum and non-ferrous materials, although 3 flutes is quickly becoming a more popular choice for these materials, as they are softer than steels so a larger chip can be taken without an impact on tool life. 4 flutes should be chosen when machining steels to extend tool life by spreading out the wear over multiple teeth. 4 flute versions can also be run at higher feeds compared to 2 or 3 flute tools.
Drill/End Mills
harvey tool combination drill end mill
infographic showcasing 5 unique drill mill operations
Undercutting End Mills
harvey tool undercutting lollipop end mill
infographic of four unique uses for undercutting end mills
Double Angle Shank Cutters
harvey tool double angle shank cutter
infographic showing 6 different uses of double angle shank cutters
Flat Bottom Tools
two stacked harvey tool cnc tools, top being a flat bottom drill and bottom a flat bottom counterbore
infographic showing 5 uses of flat bottom cnc tools. thin plate, cross hole, irregular surface, angled, and half hole drilling
infographic showing the five unique uses for flat bottom counterbores
Adjustable Chamfer Cutters
harvey tool adjustable chamfer mill set to 45 degrees
adjustable chamfer cutter inserts and hardware
Flat Bottom Drills
Flat Bottom Drill
infographic showing 5 different Flat Bottom Drill Operations
Thin Plate Drilling
Crosshole Drilling
Angled Drilling
Half Hole Drilling
infographic showcasing 5 different uses of flat bottom counterbores
Bore & Finish Drilled Holes
Straighten Misaligned Holes
Remove Drill Points
Remove End Mill Dish
Keyseat Cutter Geometry
infographic of ideal and non-ideal keyseat sizing and uses based on depth and cutter diameter
two Harvey Tool Keyseats showcasing bottom geometry of tooling
Harvey Tool Keyseat Geometries
Radial Depth of Cut
Understanding a keyseat cutter’s radial depth of cut is critical to choosing the correct tool, but understanding how it affects your tool path is necessary for optimal results. While it may be tempting to make a cut using a keyseat cutter’s maximum RDOC, this will result in increased stress on the tool, a worse finish, and potential catastrophic tool failure. It is almost always better to use a lighter depth of cut and make multiple passes (Figure 2).
ideal and non-deal keyseat radial depth of cut
Desired Slot Size
infographic of desired slot size compared to keyseat sizes and thickness
staggered tooth keyseat geometries
Having trouble finding the perfect keyseat for your job? Harvey Tool offers over 2,100 keyseat cutter options, with cutter diameters from 1/16” to 1-1/2” and cutter widths from .010” to ½”.
The Multiple Uses of a Chamfer Mill
A chamfer mill, or a chamfer cutter, is one of the most common tools used by machinists daily. When creating a part, machining operations can oftentimes leave a sharp edge on a workpiece. A chamfer mill eliminates sharp edges, leaving a sloped surface, or a chamfer, instead. In doing so, the part will be stronger and more aesthetically appealing to its eventual user.
This singular tool can provide many cost-saving benefits to machinists. Aside from the namesake operation it performs on a part, a chamfer mill can be used for several machining operations including beveling, deburring, countersinking, and spotting.
Chamfer Mill for Beveling
The terms “chamfer” and “bevel” are often used interchangeably. These two features, while similar, actually have two different definitions. While a chamfer impacts a portion of the side of a workpiece – specifically the edge of a part, a bevel angles the entire side of what was a squared-off part feature. Thus, the side of a part can feature two chamfers, or only one bevel (Figure 1).
infographic of chamfer mills chamfering and beveling a part
A chamfer mill, however, can perform both operations. The two features are equivalent in both geometry, and how they are machined.  A chamfer mill will create both part features in the exact same fashion; a bevel just may use a larger portion of the cutting surface, or may require multiple passes to create a large part feature.
Chamfer Mill for Deburring
Like many other versatile tools, a chamfer mill can be used to easily and swiftly deburr a part during the CNC machining process. In doing so, efficiency is maintained as manual deburring – a time exhaustive process – isn’t necessary.
A chamfer mill’s angled cutting surface, shown in the image below, makes it a great tool for deburring workpiece edges.  Because a very small amount of the chamfer cutter’s cutting face will be used, a simple adjustment to running parameters will allow for simple deburring operations using a very light cut depth.
Did you know that Harvey Tool fully stocks Deburring Chamfer Cutters, that are specifically designed for deburring operations? This tool features an increased flute count, allowing for minimized cycle times.
two helical solutions chamfer mills
Chamfer Mill for Spotting & Countersinking
Drilling precise, clean, and aesthetically appealing holes into a part is not a one-step process. In fact, some use up to four different tools to machine a perfect hole: spotting drill, drill, flat bottom counterbore, and countersink. However, a chamfer cutter is often used to perform two of these operations simultaneously.
By using a pointed chamfer cutter with a diameter larger than that of the hole being drilled, a machinist can spot and countersink the hole in one operation prior to its creation. Tipped-off Chamfer  Cutters are unable to perform a spotting operation because they are non-center cutting. By spotting a hole, the drill has a clear starting point. This works to alleviate walking during the drilling process, which in turn drastically reduces the chance of misaligned holes. By countersinking a hole, the screw sits flush with the part, which is often a requirement for many parts in the aerospace industry.
One consideration to keep in mind is that a carbide spot drill should always have an angle larger than that of the drill following it. However, many countersinks have angles that are smaller than most drill points.  This creates a dilemma in choosing a chamfer tool for both spotting and countersinking, as they can reduce the number of tools needed, but do not see the full benefit of a spot drill with a proper angle.
three helical solutions chamfer mills of different end profiles
Helical Solutions Chamfer Mills
A chamfer mill, also known as a chamfer cutter, is a tool that can perform several machining operations including chamfering, beveling, deburring, spotting, and countersinking. Due to this versatility, chamfer mills are an essential part of every machinist’s arsenal.  All that’s needed to run them is these various operations is a slight change to running parameters and depth of cut.
Benefits of HEM:
  • Faster cycle times.
  • Overall cost savings
small harvey tool end mill for micromachining on a penny showing size
end mill in the cut with external coolant being applied
Undercutting End Mills: Well-Rounded Tools That Offer Maximum Versatility
Undercutting end mills, also known as lollipop cutters or spherical ball end mills, are a common choice for machining undercuts. An undercut is a common part feature characterized by one part of a workpiece “hanging” over another. Undercuts are typically difficult, or even impossible, to machine with a standard tool, especially on 3-axis machines. In many cases, a specialty tool is needed to tackle this feature. Although they are frequently associated with a singular use, undercutters are actually very versatile tools that are worth keeping on hand for a variety of operations.
Undercutting
undercutting end mill ideal operations in machining
Unsurprisingly, these tools are very well suited to undercutting operations. Creating an undercut on a part can be tricky and time consuming, especially when forced to rotate the workpiece. Fortunately, this can be greatly simplified with an undercutter.
Exactly what tool to use depends on the geometry of the feature and the part. These tools are available with a range of wrap angles like 220°, 270°, and 300°. Greater wrap angles are the result of a thinner neck and create a more spherical cutting end. This style offers more clearance at the cost of rigidity. Likewise, undercutting end mills with lower wrap angles sacrifice clearance for greater rigidity.
Deburring & Edgebreaking
deburring with undercutting end mills
Since undercuts have a wrap angle that is greater than 180°, they are very well-suited to deburring or edgebreaking anywhere on your workpiece, including the underside. Deburring your parts by hand can be inefficient for your shop – using an undercutting end mill instead will save you time and money. Edgebreaking operations are often a critical final step to create a part that looks and feels like a finished product and that is safe to handle.
All undercutting end mills can be used to deburr and edgebreak, which makes them a useful tool to have on hand in any shop. Some manufacturers also offer specialized deburring tools that are designed with a right and left hand flute orientation, giving them “teeth” that make them particularly useful for deburring complex shapes. Using a deburring tool in a 5-axis machine often makes it possible to deburr or edgebreak an entire workpiece in one shot.
slotting uses of undercutting end mill
Most machinists might not think of undercutting end mills for slotting, but they are fully capable of this operation. An equivalent slot can be machined with a regular ball end mill, but doing so might not be feasible due to clearance issues – an undercutter has a reduced neck, unlike a standard ball end mill. Additionally, using an undercutter to slot can save time switching to an equivalent ball end mill.
Harvey Tool Stocks a Wide Variety of Undercutting End Mills Perfect for Your Next Machining Job
Since only 180° of the cutting end can be used to slot, undercutting end mills with lower wrap angles and thicker necks are best suited to slotting. However, high helix undercutting tools may be ideal if improved finish and increased chip removal are important to the operation.
Contouring & Profiling
contouring and profiling illustration with lollipop end mill
With their wrap angle and increased clearance, undercutting end mills are very useful for both simple and complicated contouring and profiling operations. Their versatility means that it is sometimes possible to accomplish the entire operation with a single tool, rather than several, especially when 5-axis milling.
Reduced shank tools offer the most versatility in complex contouring and profiling operations. The ability to chuck these tools at any depth means that they are capable of maximum clearance.
Choosing An Undercutting End Mill
While most undercutting end mills are conceptually similar, there are a few key differences that must be considered when picking the right tool for your job. Harvey Tool offers the following styles as stock standard tools.
selection undercutting end mills sizes and styles
