infographic of ball nose milling parameters without tilt angle
Shop Harvey Tool’s Vast Selection of Ball Profile End Mills – Click Here to Get Started
ball nose effective cutting diameter chart
ball nose cutting diameter calculation
ball nose compensated speed calculation
KEY
ADOC = Axial Depth of Cut
D = Cutting Diameter
R = Tool Radius (Dia./2)
RDOC = Radial Depth of Cut
SFM = Surface Feet per Minute
Sc = Compensated Speed
ball nose milling infographic of adoc with tilt angle
KEY
Cutting With Dovetails
Check our Harvey Tool’s Comprehensive Selection of Dovetail Cutters that Ship to You Today.
Avoiding Tool Failure
infographic examining drop hole allowance parameters with dovetails
nondrop-hole dovetail cutters
dovetail cutters with different neck diameters
microdovetailing with dovetail cutter
5. Failing to Climb Mill.
6. Improper Chip Flushing.
7. Giving the Job Away.
Selecting the Right Plastic Cutting End Mill
three Harvey tool plastic cutting end mills
Choose Workholding Method
Chart of workholding parameters and their preferred selection to upcut or downcut as a result
Determine Heat Tolerance
The amount of heat generated should always be considered prior to any machining processes, but this is especially the case while working in plastics. While machining plastics, heat must be removed from the contact area between the tool and the workpiece quickly and efficiently to avoid melting and chip welding.
For plastics with a higher heat tolerance, a Two or Three Flute Plastic Cutting End Mill can be utilized. Because it has more cutting edges and allows for higher removal rates, its tool life is extended.
Chart of end mill flute count and their respective workpiece heat tolerance levels
The polymer arrangement in plastics can cause many burrs if the proper tool is not selected. Parts that require hand-deburring offline after the machining process can drain shop resources. A sharp cutting edge is needed to ensure that the plastic is sheared cleanly, reducing the occurrence of burrs. Three Flute Plastic Cutting End Mills can reduce or eliminate the need to hand-deburr a part. These tools employ an improved cutting action and rigidity due to the higher flute count. Their specialized end geometry reduces the circular end marks that are left behind from traditional metal cutting end mills, leaving a cleaner finish with minimal burrs.
Shop Harvey Tool Plastic Cutting End Mills Today
Flute Count Case Study
3 FLUTE PLASTIC FINISHER: A facing operation was performed on a separate acrylic piece with a specialized 3 Flute Plastic Finisher End Mill. The specialized cutting end left minimal swirling marks and resulted in a smoother finish.
Image of facing operation patterns from a standard 2 flute plastic cutter beside another image from a specialized 3 flute plastic finisher
Chart of plastic cutting end mills vs metal cutting end mills that compares values on their features
