    • ITC
December 10, 2024/4 Comments/in CNC Machining, Drilling, Drilling & Holemaking, Getting Started, Holemaking, Large Featured, Machining 101, Machining Techniques, Material Specific, Tool Geometry, Tool Information Guides, Tool Selection/by Emily Van Volkom
When it comes to achieving precision in CNC drilling applications, the choice of tools and techniques can make a significant difference in the outcome. One essential element that often doesn’t get the spotlight it deserves is the Pilot Drill. This blog post will explore the importance of pilot drills, their applications, and best practices for integrating them into your CNC machining processes.
What is a Pilot Drill?
A pilot drill is used to create a guide hole in deep drilling applications where precision is required. This guide hole keeps the drill on center, maintaining straightness throughout the cut. By creating a pilot hole, machinists can also improve the quality of the finished product and extend the life of their tools.
The Importance of Pilot Drills in CNC Machining
1. Enhanced Accuracy
The primary advantage of using a pilot drill is the enhanced accuracy it provides. When working with harder materials or complex geometries, a small pilot hole helps maintain the alignment of the longer drill, reducing the risk of misalignment and defects.
2. Extended Tool Life
Using a pilot drill can significantly extend the life of your deep-hole drilling tools. By first creating a pilot hole, the chasing drill experiences less stress, reducing wear and tear, and the chance of breakage, ultimately leading to cost savings from longer tool life.
3. Improved Chip Removal
Pilot drilling can enhance chip removal, particularly in deep-hole drilling scenarios. The smaller pilot hole allows for better coolant flow, which is crucial for effective chip evacuation and maintaining optimal cutting temperatures.
Applications of Pilot Drills
Pilot drills are versatile and can be used in various applications, including:
  1. Deep-hole Drilling: Pilot holes create a guide when drilling deep holes for improved centering and straightness.
  2. Tapping Operations: A pilot hole can facilitate easier and more accurate tapping.
  3. Reaming: When preparing for reaming operations, a pilot drill can ensure the hole is properly aligned and sized.
  4. Screw and Bolt Holes: Pilot holes are essential for ensuring screws and bolts are inserted correctly and securely.
Best Practices for Using Pilot Drills
1. Application
Piloting is recommended for tighter tolerance holes when drilling at depths of 8xD or greater. Valor Holemaking provides a custom tolerance of +0.0002/+0.0005 (+0.005mm/+0.013mm) to create the perfect oversized guide hole for their traditional drill lines capable of drilling 8xD or greater. Valor Holemaking’s Pilot Drills also include a +2/+1 deg angle tolerance to ensure a larger angle than the chasing drill. Piloting depth is recommended as 3xD for all applications drilling 8xD or greater.
2. Choose the Right Size and Point Angle
Selecting the appropriate size for your pilot drill is crucial. As a rule of thumb, the diameter of the pilot hole should be slightly larger than the diameter of the final hole. This allows for optimal support for the chasing drill while preventing excessive material removal. The pilot drill’s point angle should be equal to or larger than the succeeding drill. This allows the tip of the succeeding drill to engage the material before the flank does (see figure below).
3. Optimize Feed Rates
When using a pilot drill, ensure that the feed rates are optimized for both the pilot and the larger drill. Adjusting the feed rate can improve performance and reduce the risk of tool breakage. Valor Holemaking’s downloadable speeds and feeds tables and Machining Adviser Pro are excellent resources, and you can always consult Valor Holemaking’s Tech Team for further assistance!
4. Use Proper Coolants
Effective cooling and lubrication are vital in metal machining. Ensure that your pilot drill is adequately cooled with flood coolant or adjust speeds and feeds to maintain tool integrity and enhance cutting performance.
5. Maintain Tool Condition
Regularly check the condition of your pilot drills. Worn or damaged pilot drills can lead to inaccuracies and affect the performance of subsequent operations.
6. Integrate with CNC Programming
Incorporate pilot drilling into your CNC programs to ensure that it’s executed at the right stage of your machining process. Program one revolution or brief dwell at the bottom of the pilot hole to ensure a clean surface. This will help streamline operations and improve overall efficiency.
Pilot drills may seem like a small detail in the larger scope of CNC machining, but their impact on precision, tool life, and overall efficiency is significant. By understanding their importance and implementing best practices, machinists can enhance their processes and achieve superior results. Whether you’re a seasoned CNC operator or just starting out, incorporating pilot drills into your workflow is a smart move that can lead to greater accuracy and success in metal machining.
https://www.harveyperformance.com/wp-content/uploads/2024/12/Featured-Image-Pilot-Drills-IMG.jpg 525 1400 Emily Van Volkom http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Emily Van Volkom2024-12-10 13:53:412025-01-30 09:11:16Mastering Precision: Pilot Drills in CNC Machining
Mastering CNC Drilling: Geometries and Key Factors
August 9, 2024/0 Comments/in CNC Machining, Drilling, Drilling & Holemaking, Holemaking, Large Featured, Machining 101, Material Specific, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
Selecting the proper drill for a specific application is essential to ensuring a successful cnc drilling job. Achieving a perfectly machined hole can often be challenging. There are many machining woes that can occur when drilling into a material. These can greatly affect hole quality, and regardless of the material being machined, there is often zero margin for error to ensure all components meet specifications.
To ensure you are selecting and using the correct drill, you need not only a deep understanding of drill geometries, but also the factors that influence the performance of the drill and quality of the hole. In this comprehensive guide, we’ll dive into drill geometries, while also exploring the performance factors that determine CNC drilling results. Furthermore, we’ll connect these to the strategic decisions that drive the tool selection process, so you can gain a competitive edge at the spindle.
Performance Factors Influencing CNC Drilling Success
Part Material
Different materials require different drill geometries and cutting speeds to maintain hole quality and prevent excessive wear. With different types of materials, whether it be a softer non-ferrous material like aluminum or a harder ferrous material like stainless steels, you’ll face different challenges as you manufacture your part. To ensure that you’re getting the best performance and tool life possible features and geometries must be considered.
metal blocks that have many holes from cnc drilling operations
CNC Drill Geometries
It is important to understand the different geometries of a drill to understand how they affect an application. For an in depth dive into drill geometries, read 10 CNC Drill Geometries Every Machinist Must Know. This breaks down the unique aspects of geometries and how they affect the cnc drilling process.
Drill Geometries and Drill Walking
CNC drill walking occurs when a drill lacks sufficient engagement with the material. This causes it to deviate from its intended tool path, leading to inaccuracies in hole placement and dimensions. This occurs due to various factors, often including improper drill geometry choice. Understanding how different drill geometries influence drill walking is crucial to ensure you’re achieving precision and consistency in every hole.
Point Angles
The point angle dictates cutting forces and chip evacuation. Choosing the right angle, such as 118° or 135°, based on material hardness, ensures efficient drilling and prevents walking. The shallower the point angle, the better the distribution of cutting forces on the material. Higher angles walk less, as the point grabs into the material easier. Machinists must weight these options when choosing the proper drill.
Web Thickness
Web thickness is the distance between cutting edges or flutes at the face of the drill. This is where stability is generated in a tool. Webs that are too thin can increase the likelihood of breakages, while webs that are too thick will generate unnecessary cutting forces. Finding the proper blend of stability and cutting force is a common struggle for machinists.
CNC Drill Length Considerations
Flute and overall length impact stability and chip evacuation. Matching these lengths to drilling depth prevents deflection and enhances hole quality.
While it may be easiest to purchase a long drill that will work in a variety of scenarios, it is not the best choice to ensure precision. Machinists should best match their required depth to the effective depth of a drill. This ensures that the tool will be as rigid as possible, generating the straightest holes.
As tool length increases, rigidity decreases. Therefore, a properly matched drill will be as rigid as the situation allows. This affords the machinist with the best possible outcome for their unique drilling application.
Coolant-Through Drilling
Proper cooling and lubrication extends tool life and ensures excellent hole quality. If your machine is equipped with the option to run through spindle coolant tooling, it can be extremely beneficial to your application. Unlike an end mill, where chips often have the ability to evacuate outward from the tool, the chips in a drilling operating are held captive inside the feature as it’s being drilled. Here, chips are only able to evacuate through the drill fluting
Through spindle coolant not only cools and lubricates a drill at the point of material removal, but also forcibly evacuates the chips. This can increase your tool’s life while reducing or removing the need for peck cycles all together. This means faster cycle times and higher production rates for your product.
On the other hand, coolant can be fed externally, and sprayed onto the tooling. This will aid in cooling and lubricity. The downside is it is less efficient than utilizing a coolant-through drill. In deep hole drilling applications, external coolant is often ineffective for chip evacuation efforts, and is not the ideal choice for the best results.
Speeds & Feeds
Optimizing speeds & feeds is essential for efficient and accurate drilling. There is not a “one size fits all approach” for speeds & feeds, as all tools and materials require a slightly different approach.
Finding the right balance for each material prevents tool wear and ensures effective chip evacuation. Valor Holemaking offers comprehensive starting parameters in the form of Speeds & Feeds Charts and each tool is also supported by Machining Advisor Pro. This tool allows machinist to custom generate speeds & feeds based off the exact tool path, material, and machine setup.
Rigidity and Stability
A sturdy machining setup reduces vibrations during drilling, improving hole quality. The same can be said about the drill within. A rigid tool is a stable tool, especially as the depth requirements increase. Stability is especially important for drilling heavy-duty materials. This can be impacted by several factors, most importantly the quality of the tool and its design, as well as its chip management capabilities. High precision and high-performance solid carbide drills are designed for the utmost rigidity to ensure repeatability time after time and part after part.
Software and Programming
CNC programming software simplifies creating and editing drilling programs. Compatibility with common CAD/CAM software streamlines integration. Much like machine quality, proper programming is an important step in ensuring precision in CNC drilling applications. CAD/CAM integration ensures the correct dimensions are input to the software to best ensure the tool correctly fits the required parameters.
Exploring CNC Drilling Geometries & Key Factors: Wrapped Up
There are many different drill geometries and factors that can directly impact a drill’s performance and hole quality. Understanding these features can greatly assist in your tool selection process, allowing you to improve productivity and hole quality, so you can gain a competitive edge at the spindle. Drilling is often the most precise aspect of machining, so mastering geometries is critical to success.
https://www.harveyperformance.com/wp-content/uploads/2024/08/Featured-Image-Mastering-CNC-Drilling.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2024-08-09 14:34:572025-11-12 16:00:33Mastering CNC Drilling: Geometries and Key Factors
HSS vs Cobalt vs Carbide: Choosing a Tool Substrate
July 31, 2024/0 Comments/in CNC Machining, Large Featured, Titan USA, Tool Information Guides, Tool Selection/by Allison House
Do you know which cutting tool substrate is right for you? Popular cutting tool manufacturers, such as Titan USA, oftentimes sell high speed steel, cobalt, and solid carbide cutting tools – but which is right for your application? This article will serve as a guide to the benefits of each material, and the best choice for specific applications.
At the same time, do you understand the differences of high speed steel vs cobalt vs carbide? Follow along for the key differences of the three substrates.
High Speed Steel Tooling
Titan USA High speed steel reamer with callouts
When it comes to high speed steel tooling, this will be the most economical choice among the three substrate options. The above image shows a Titan USA High Speed Steel Reamer.
High speed steel is known for its high working hardness and excellent toughness. While maintaining a rigid set up should always be a priority, high speed steel tooling can excel in situations where a rigid set-up can’t be obtained, and where there is potential for excessive tool holder overhang. The toughness of high speed steel over cobalt and solid carbide makes it less prone to brittle fracture or chipping. These tools can be used in a variety of ferrous materials, such as steel and iron, and non-ferrous materials such as brass, copper, and aluminum alloys.  However, high speed steel should not be used in hardened versions of these materials.
This substrate is not without its drawbacks, too, though. High speed steel tooling will need to be run at slower cutting speeds than cobalt or solid carbide tooling, which could potentially make it less ideal for high production runs.
Cobalt Tooling
Titan usa cobalt reamer with dimension callouts
For most situations, cobalt is going to offer an intermediate option when compared to high speed steel and solid carbide options. The image above shows a Titan USA Cobalt Reamer.
Cobalt can be run even faster than high speed steel tooling. It can also be used in most hardened and abrasive materials such as bronze, stainless steel, cast iron, and titanium.
However, a cobalt bit will not retain its edge sharpness for as long as a solid carbide bit, and it will be more prone to brittle failure than high speed steel tooling in non-rigid set ups.
If you have a desire to run at faster running parameters than what high speed steel tooling offers, or if you are running in a hardened material, cobalt may be your next consideration. While it will typically have a higher cost than high speed steel tooling, it would be a more economical option than solid carbide.
Solid Carbide Tooling
Titan USA Carbide reamer with dimension callouts
Solid carbide will be the premier material substrate offered for most cutting tool selections, as it offers high edge sharpness that allows tooling to be run at the fastest running parameters offered among the three material substrates. The above image shows a Titan USA Solid Carbide Reamer.
Although solid carbide tends to be the most expensive substrate option, the ability to run at high speeds and feeds allows you to reduce your cutting time. This increased productivity can prove to be more economical for higher production jobs. Solid carbide tooling is going to have the highest heat and wear resistance, allowing the tooling to last longer and require less replacement.
Further, solid carbide is a good choice when dealing with hardened materials or high temp alloys. For example, it can be used in hardened steels, titanium alloys, and nickel alloys up to 45RC. When paired with material specific tool geometries and coatings, solid carbide can even be used in materials up to 68Rc.
One downside to solid carbide tooling is that its high hardness can make it more susceptible to brittle failure and therefore may not be a good choice when dealing with non-rigid set ups. For example, solid carbide can be more prone to chipping or breaking when encountering interrupted cuts, vibrations, or shocks.
Substrate Options
Substrate Options
When browsing the different material options offered by Titan USA, this article can act as a helpful guide for choosing the right tool for your application.  For more information on the different tooling styles offered in high speed steel, solid carbide, and cobalt, please visit the Titan USA website at https://www.titancuttingtools.com/ .
Sources:
  1. Chitnis, Rohit. “HSS vs Cobalt vs Carbide Drill Bits: What to Choose.” Benchmark Abrasives, Benchmark Abrasives, 29 June 2022, benchmarkabrasives.com/blogs/news/hss-vs-cobalt-vs-carbide-drill-bits-what-to-choose.
  2. “A Comprehensive Guide to Pros and Cons of Carbide Tools and HSS.” TJ Grinding, 8 May 2018, tjgrinding.com/blog-post/comprehensive-guide-pros-and-cons-carbide-tools-and-hss.
  3. “High-Speed Steel vs Carbide Tools: AIMS Industrial.” AIMS Industrial Supplies, www.aimsindustrial.com.au/blog/hss-vs-carbide. Accessed 17 June 2024.
  4. Startoolinc. “The Difference between High speed steel & Carbide End Mills.” Tool Talk, 11 Feb. 2020, tooltalk.blog/the-difference-between-high-speed-steel-carbide-end-mills/#:~:text=Compared%20to%20HSS%2C%20carbide%20tools,to%20face%20milling%20and%20beyond.
https://www.harveyperformance.com/wp-content/uploads/2024/07/Featured-Image-Selecting-Cutting-Tool-Substrate.jpg 525 1400 Allison House http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Allison House2024-07-31 16:29:122025-11-12 15:58:06HSS vs Cobalt vs Carbide: Choosing a Tool Substrate
Multi-Axis Finisher Q&A
March 29, 2024/2 Comments/in Helical Solutions, How-To's, Large Featured, Machining 101, Machining Techniques/by Tom Pyle
What is a Multi-Axis Finisher?
A tool that uses an extremely large radius to increase finishing performance in two different ways, depending on the needs of the machinist. Either the Multi-Axis Finisher will provide a better surface finish than a traditional Ball End Mill in the same amount of time, or will provide the same surface finish in far less time than a traditional Ball End Mill. A middle ground with improved surface finish and reduced cycle time is also easily achievable.
What Are Other Names for Multi-Axis Finishers?
Multi-Axis Finishers are oftentimes referred to as Barrel Cutters or Conical Barrel Mills or Circle Segment Cutters, among many others.
What Are the Different Forms of Multi-Axis Finishers, and How Do They Differ?
There are several different forms of Multi-Axis Finishers, including Lens, Taper, Oval, and Barrel. With a Lens Form, there’s a large radius on the end of the tool that’s in line with the tool axis. Taper Form, in contrast, has three tangential radii and a large radius defined at a specific angle relative to the tool axis. An Oval Form has two tangential radii, offering additional angle flexibility, while a Barrel Form has a large radius on the OD of the tool.
The most significant benefit is oftentimes observed utilizing a Taper Form Multi-Axis Finisher, as the radius of this tool can become vastly large on this form, while the others are more limited. However, this great benefit also comes with the least amount of flexibility in terms of approach to a workpiece.
What Are the Benefits of a Multi-Axis Finisher?
There are two clear benefits to using a Multi-Axis Finisher, compared to a Ball End Mill: Increased surface finish, and reduced cycle time (Or most likely both, concurrently).
What is a Benefit Multiple?
Helical Solutions is the industry’s premier manufacturer of Multi-Axis Finishers, and the Benefit Multiple is a significant reason why. Helical specifies the theoretical benefit that can be seen with its Multi-Axis Finishers, providing machinists direct insight into the gains that can be realized with these tools.
Benefit Multiple refers to the Cusp Height, correlated directly with the theoretically-achievable surface finish. Assuming the same cusp height from a Ball End Mill to a Multi-Axis Finisher, the Benefit Multiple relates to the time savings that could be seen in a machinists’ toolpath. For example, a Benefit Multiple of 4 would result in a toolpath ¼ as long as for a Ball End Mill of the same diameter. The stepover pass-to-pass would be 400% as much as a Ball End Mill to keep the same cusp.
When Should I Not Use a Multi-Axis Finisher?
Multi-Axis Finishers are best applied to wide-open surface areas; or large, smooth contours rather than small features or tight areas. Application of these tools will always be on a case-by-case basis. For help with your specific application, contact Helical Solutions Technical Support at 866-543-5422.
How Can I Get the Most Out of My Multi-Axis Finisher?
Multi-Axis finishers are best utilized when working further towards the OD of the tool. Tapered Form Multi-Axis Finishers are the most obvious choice for this, as its nose radius is small and has the least amount of efficiency. Similarly to a ball end mill, working near the center will have limited cutting ability, while the OD of the tool will see the full surface footage of the programmed RPM.
Taper Form Multi-Axis Finishers should be used when tilted at the specified taper angle. Oval Form Multi-Axis Finishers should be used towards the OD. Lens Form Multi-Axis Finishers should be tilted to avoid working on-center.
Lens Form Multi-Axis Finishers Look Like a High Feed End Mill. Can I Use it That Way?
Yes. However, there are differences in the form, and while a Lens Form Multi-Axis Finisher could theoretically be used as a High Feed End Mill, the two tools are not interchangeable.  A High Feed End Mill would not be the best choice for Multi-Axis Finishing, nor would a Lens Form Multi-Axis Finisher be our first recommendation for feed milling.
Do I need special software to program Multi-Axis Finishers?
Yes. A number of years ago, there were only a few CAM software packages that supported the programming of these specific forms. Nowadays, most CAM software providers have some degree of support for this method. Two of the first CAM software offerings to support this were MasterCAM and Hypermill, though many additional options exist today.
Why haven’t I heard of Multi-Axis Finishers Until Now?
In the grand scheme of things, Multi-Axis Finishers provide a very new approach to finishing, having been developed within the last handful of years.  Similar to High Efficiency Milling, these tools offer a new technique to approach your workpiece, offering increased efficiency and reduced cycle times.  Compared to the history of milling, modern tool manufacturing and CAM software have only just become able to program these unique forms.  Multi-axis finishers are positioned to revolutionize the world of finishing.
For more information on Multi-Axis Finishers, visit Multi-Axis Finishers: The Key to Amazing Surface Finish.
https://www.harveyperformance.com/wp-content/uploads/2024/03/Featured-Image-Multi-Axis-Finishers-QA.jpg 525 1400 Tom Pyle http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Tom Pyle2024-03-29 10:27:012024-11-07 16:12:11Multi-Axis Finisher Q&A
March 29, 2024/0 Comments/in CNC Machining, Helical Solutions, Large Featured, Tool Information Guides, Tool Selection/by Tom Pyle
A Key to Improving Surface Finish
In today’s Manufacturing Industry, part finish and machining efficiency are key to a successful machine shop. It’s no surprise, therefore, that the popularity Multi-Axis Finishers has never been greater. Helical Solutions is a leader in the manufacturing of Multi-Axis Finishers, and its customers utilize this impressive tool when faced with extremely high surface finish requirements, oftentimes swapping out a traditional Ball End Mill to dramatically improve finish while minimizing cycle times.
Multi-Axis Finisher Basic Principles
A Multi-Axis Finisher can be easily recognized by its large radius included in the profile of the tool. With a larger radius, a far greater stepover can be used pass-to-pass while keeping the same cusp height as a Ball End Mill. This decreases the cycle time by a known value called the Benefit Multiple.
A Multi-Axis Finisher with a Benefit Multiple of 8 will reduce the cycle time to 1/8 of the cycle time for a Ball End Mill of the same shank diameter – an 87.5% time savings! If a Multi-Axis Finisher is used with the same pass-to-pass stepover as a Ball End Mill, the finish will be drastically improved due to exponentially smaller cusp heights. Most situations allow both reduced cycle time and improved surface finish to be achieved.
The images below show the comparison of a ball end mill to an Oval Shape Multi-Axis Finisher with a benefit multiple of 4.
Due to their large radii, Multi-Axis Finishers are best suited for wide open, flowing, and somewhat flat surfaces. Smaller spaces, especially tight corners, will generally not see as much benefit from these tools due to limited use of the major radius.
Multi-Axis Finisher Tool Selection
The Manufacturing Industry’s leader in Multi-Axis Finishers, Helical Solutions offers 3 distinct profiles, each fully stocked and available to ship the day of purchase.
The oval form includes 2 tangential radii and offers the most versatility in smaller spaces where a slightly varied approach angle is required, such as impellers or fan blades.
The taper form includes 3 tangential radii and a taper angle. It allows for the largest radius, and therefore greatest potential improvement of finish and reduction of cycle time. They are best used where a specific approach angle is needed and where maximum performance gain is desired.
The lens form includes 2 tangential radii on the end of the tool and is used for work mostly on the face of a part. Tilt angles of approximately 5 degrees are recommended for these tools to avoid working on-center.
Programming Multi-Axis Finishers
Programming Multi-Axis Finishers requires some additional consideration compared to a typical end mill. Luckily, many modern CAM packages offer support for these unique profiles, including many of Helical’s CAM partners. Each software has their own name for these toolpaths, so reach out to your CAM or Helical sales rep to find how you can program yours!
For more information on Multi-Axis Finishers, and to learn if this advantageous tool is right for you, read our Multi-Axis Finishers Q&A.
https://www.harveyperformance.com/wp-content/uploads/2024/03/Featured-Image-Multi-Axis-Finisher-Keys-to-Surface-Finish-1.jpg 525 1400 Tom Pyle http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Tom Pyle2024-03-29 10:27:002024-04-24 09:17:44Multi-Axis Finishers: The Key to Amazing Surface Finish
CFRP: Material Properties and Tool Selection
October 27, 2022/0 Comments/in Composites, Large Featured/by Matthew Hernandez
Carbon Fiber Reinforced Polymers (CFRP) is composed of carbon fibers, bound with resin, to create a groundbreaking material that has proven to have limitless application possibilities in a wide range of composite cutting industries. Due to its attractive properties of strength, durability, corrosion resistance, and its lightweight nature, there has been a rising utilization of carbon fiber in the aerospace and automotive industries. However, it does not come without its own set of challenges in comparison to typical metal machining.
Three sheets of cfrp carbon fiber material on top of one another
CFRP Properties
CFRP has a high resistance to being deformed without permanent effects (elastic modulus), resistance to tension, low thermal conductivity, and low thermal expansion. While many of these properties are ideal for many applications, there are unique effects that must be considered when machining.
Abrasiveness
CFRP’s high elastic modulus makes it highly abrasive, causing challenges in tool wear and tool life that must be addressed. For example, while milling typical metals, clean chips are formed and ejected. But milling carbon fiber is like sanding, where material is removed in the form of dust particles.
Abrasion is a large issue in carbon fiber machining as it is responsible for poor tool life and dullness of the tool that can cause a part to be scrapped. As soon as a tool begins to dull, it will cause poor part finish and increase the chances of delamination and fraying.
Causes of Heat Generation
Typically, in metal machining, most of the heat is transferred into the chips with a fraction of the heat into the part and workpiece. Due to CFRP’s low thermal conductivity and no chips formed to dissipate the heat, most of the heat is transferred to the tool and part. This heat is unideal, as it will cause more tool wear and potentially cause damage, resulting in delamination.
For more information on composite delamination, read “Overcoming Composite Holemaking Challenges.”
Varying Properties
No composition of CFRP is made the same, meaning that operating parameters can vary. There is no one-solution-fits-all for every application, as it is often found to be less predictable than metals due to its varying properties. These varying components includes the fiber type, fiber density, resin type, layup orientations, thickness, matrix hardness, and heat sensitivity, which all must be taken into consideration.
Methods to Reduce CFRP Issues
Having high interval checks to monitor cutting and dimension quality to catch any errors before they may be irreversible is one way address CFRP machining issues. Another method to tackle CFRP would be through picking the right tool for the application.
Selecting a CFRP Tool
Tooling material type (substrate) and geometry both determine the quality of cutting the carbon fiber and durability of the tool.
Tooling Substrate/Coating
When selecting a tool to machine CFRP materials, it is essential to opt for a tool that is strong, sharp, and resistant to the abrasive properties that CFRP holds. Many machinists opt for solid carbide cutters with diamond coatings such as DLC, CVD, or PCD, as they provide the tooling with increased tool life and improved cutting action. These tools provide added hardness and abrasion resistance to combat the effects of machining CFRP.
Corehog end mill coating chart for selecting a tool to machine cfrp carbon fiber materials
CoreHog’s Coating Chart
While PCD diamond tools are considerably higher in price than other diamond coated tooling options, they provide the longest tool life and performance against abrasion and tool wear. Often, they are more cost effective in the long run due to their longevity, when compared to cheaper options that only save money in the short term.
Product image of a corehog square pcd diamond end mill
CoreHog PCD Diamond End Mill – Square
Product image of a Corehog ball nose PCD diamond end mill
CoreHog PCD Diamond End Mill – Ball Nose
In comparison to the cost of the part to be machined, the tool may be a fraction of the cost, making it worth spending the extra money to prevent greater costs that come with scrapping the part. Composite cutting tool manufacturer, CoreHog, stocks an array of PCD Diamond End Mills in Square and Ball Nose profiles.
Tooling Geometry
The geometry of a tool also plays a vital role in its machining capabilities of CFRP. There are many different geometry solutions, depending on your application, with different flutes, angle of cut approach, and profile. Corehog’s selection of CFRP Router Bits offer a great solution to your various CFRP needs.
Product image of a corehog cfrp router bit upcut burr style
CoreHog CFRP Router Bits – Burr Style – Upcut
Product image of a corehog cfrp router bit end mill upcut
CoreHog CFRP Router Bits – End Mill Style – Upcut
Product image of a corehog cfrp router bit drill point upcut
CoreHog CFRP Router Bits – Drill Point Style – Upcut
https://www.harveyperformance.com/wp-content/uploads/2022/10/Feature-Image-Machining-Carbon-Fiber-1.jpg 600 1599 Matthew Hernandez http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Matthew Hernandez2022-10-27 09:43:302025-11-20 09:23:34CFRP: Material Properties and Tool Selection
Understanding Machining Advisor Pro (MAP) 2.0
September 8, 2022/0 Comments/in How-To's, Large Featured, Machining Advisor Pro Help, Trending Now/by Harvey Performance Company
Machining Advisor Pro (MAP) was first introduced to the CNC Machining Industry in 2018 as a tool to quickly, seamlessly, and accurately deliver recommended running parameters to machinists using Helical Solutions end mills. then, thousands of users have utilized this cutting-edge resource, every day. In August 2022, a new and improved version of MAP was launched, optimized for Harvey Tool’s 27,000+ miniature and specialty cutting tools.
The following article is intended to introduce MAP 2.0 features. For more in depth information about MAP, including how to get started using it, please visit the original “In the Loupe,” post Get to Know Machining Advisor Pro.
New Map 2.0 Features
Addition of all Harvey Tool Products
With the release of MAP 2.0, users now have access to expertly tailored speeds and feeds parameters and recommendations to meet the exact demands of cutting tool and machine setup for all Harvey Tool products. This means that more than 27,000 Harvey Tool products are available in MAP and users can find their Specialty Profile Cutting Tools, Miniature End Mills, and Holemaking and Threading products to confidently use MAP generated speeds and feeds. With the addition of new products, there is now a new variety of operations to choose from, specific to the product selected.
New Strategy Option for Operations
Before the MAP 2.0 update, there were only two drop down menus for operation: type and toolpath. With the new update, there is an additional third operation drop down menu titled “strategy.” This option allows for users to further refine their machining operation, but only for certain tools that require it. For example, when using a Double Angle Shank Cutter on MAP, users can choose from a list of toolpaths including deburring, chamfer, or v-groove.
Once selected, users will choose a strategy for the toolpath – single side or double side engagement. The use of this feature gives the user more flexibility in their operations and saves time by automating their operation calculations. This feature is available for a variety of different toolpaths within the application.
MAP Offline Mode
With the release of MAP 2.0, and the addition of over 27,000 Harvey tools, users now can work offline. The work offline feature is only available for the new Harvey Tools. To access this feature, users can select the “User Account” button in the top right and start the process to allow MAP to work offline. Activating the work offline mode will cache the Harvey Tool data and takes around 15-20 minutes to complete before allowing the user to work offline.
Having the ability to use MAP offline can be useful when users are unable to connect to the internet as you will still be able to access MAP on a desktop or mobile app, whenever and wherever you need it.
https://www.harveyperformance.com/wp-content/uploads/2022/08/Feature-Image-Harvey-MAP-Launch-IMG-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-09-08 14:26:192022-09-08 16:36:58Understanding Machining Advisor Pro (MAP) 2.0
5 Boring Bar Mistakes That Cause Lathe Chatter
September 8, 2022/4 Comments/in CNC Machining, Large Featured, Micro 100, Turning/by Harvey Performance Company
Boring bar applications are very popular in the lathe and CNC machining industry, as they provide a shop with extreme diversity and accuracy. Running a boring bar properly, however, is essential to ensuring you’re maximizing shop efficiency and achieving outstanding part finish. There are many mistakes that can be made when running boring bars and many that cause excessive machining vibrations or lathe chatter that must be avoided. Learn the five mistakes that could be causing tool chatter in your boring applications and how you can stop this lathe chatter once and for all.
Mistakes Causing Lathe Chatter
Using a Dull Cutter
Boring with a worn-out tool significantly increases cutting forces generated by the cut, potentially leading to lathe chatter. The more a tool is run, the more chance it has for galling, or in other words, built-up edge (BUE), making it imperative to inspect your boring bar before each application. BUE occurs when material is welded onto the cutting tool due to high friction and heat generation during a CNC machining operation. This condition is not desirable because it leads to poor tool life and increased vibrations due to an uneven cutting edge. Stocking your tool crib with great quality boring bars can help reduce BUE by providing a sharp, long lasting cutting edge, catered for your exact application. Learn other ways to reduce BUE in your turning applications, today.
Shows zoomed in effects of built-up edge and wear failure on carbide boring bar which leads to lathe chatter
Image Source: Carbide inserts Wear Failure modes. | machining4.eu, 2022
Utilizing Incorrect Speeds & Feeds
Like many applications, using improper turning speeds & feeds can lead to poor performance. In boring applications, using too high of a chip load can cause deflection, greatly increasing the chances of tool failure. Using too low of a chip load doesn’t allow the tool to cut enough, which causes the tool to bounce off the material, leading to increased tool wear and poor part finish. Discovering the right balance for using chip load is crucial in order to produce a more efficient cut.
lathe turning speeds and feeds
When running a boring bar, it is imperative to use the speeds & feeds recommended for the tool being used. Micro 100 provides downloadable and printer-friendly Speeds & Feeds for all Standard and Quick Change Micro-Quik turning tools.
Lacking Workpiece Support
A main cause of chatter in lathe applications is lack of support on the workpiece. If a workpiece is not properly supported when entering a boring application, the tool will begin to chatter. Not only is it essential to confirm the proper workholding device is being used, but it’s also important to ensure that your setup is as rigid as possible. Learn more about workholding styles and considerations to make sure you’re supporting your workpiece properly in your next boring application.
Uneven Tool Holding
Similarly, tool holding also plays a vital role in the performance of a boring bar application. It is important to select a tool holder that accommodates the tooling being used and is as rigid as possible. Using an improper method of tool holding can lead to tool runout, which occurs when the tool or holder deviates too far off its axis.
Understanding the overall rigidity of your system is a critical step in understanding how to best reduce lathe chatter.
Micro-Quik tool holder with a tool inserted and pointing towards workpiece
Image Source: @abom79
Many machinists opt for tools that promote machining efficiency by boosting the speed at which tool changes occur. For example cutting tool manufacturer Micro 100 offers Micro-Quik Holders, which offer unmatched rigidity, axial and radial repeatability, tip-to-tip consistency, and part-to-part accuracy in tool changes totaling fewer than 30 seconds.
Drilling an Improper Starter Hole
Before starting a boring application, drilling the proper hole is vital to ensuring that the boring bar has sufficient contact with the workpiece to properly stabilize the cut.
If a hole is too large, the boring bar could deflect off of the workpiece. If the hole is too small, there will not be enough clearance for the tool, increasing chances of tool wear and possibly tool failure.
When selecting a drill to prepare the workpiece for your boring applications, there are two dimensions that should be considered: the Head Width and the Minimum Bore Diameter.
Boring bar with line drawing showing where different dimensions are located on the tool
The Head Width, or “H” value on the above line drawing, is the actual width of the boring tool. The Minimum Bore Diameter is a calculated dimension slightly larger in size compared to the head with that is associated with the smallest drill size that should be used to start a boring application. It is recommended to opt for a drill that is the same or slightly larger than the Minimum Bore Diameter of the boring bar being used, to ensure there is proper clearance for the cutting edge.
Utilizing an Inefficient Coolant Strategy
If coolant isn’t aimed properly on the workpiece or if improper coolant is being used, tool life and quality part finish can be significantly reduced. Additionally, if coolant lines are aimed directly at the bore, the pressure of the coolant holds the chips in the bore, causing them to evacuate improperly. This then causes chip recutting, leading to lathe chatter and finish problems.
Opting for a Plumbed and Ported Tool Holder can mitigate this problem, ensuring chips are being properly evacuated out of the cut.
coolant being sprayed onto a part during a cnc machining operation
Machinists generally utilize Flood or High Pressure coolant methods for chip removal. Flood coolant uses low pressure to create lubricity and aid in chip evacuation. On the other hand, high pressure coolant delivers instant cooling of a part and quickly shoots chips away to prevent recutting.
https://www.harveyperformance.com/wp-content/uploads/2022/09/Featured-Image-Boring-Bar-Chatter.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-09-08 14:20:092025-11-12 15:58:455 Boring Bar Mistakes That Cause Lathe Chatter
Machining Nickel Alloys: Common Mistakes to Avoid
April 4, 2022/1 Comment/in CNC Machining, Helical Solutions, Large Featured, Material Specific/by Will Lauzon
Nickel-based alloys are growing in popularity across many industries such as aerospace, automotive, and energy generation due to their unique and valuable mechanical and chemical properties. Nickel alloys exhibit high yield and tensile strengths at low weights and have high corrosion resistance in acidic and high temperature environments. Because of these advantageous properties, nickel alloys have increasingly become popular in machine shops.
Unfortunately, nickel alloys have a reputation for creating issues at the spindle. These metals present themselves to be problematic as they easily work harden. Further, nickel alloys generate high temperatures during machining, and have gummy chips that can weld onto cutting tools, creating built-up edge (BUE). Fortunately, with the correct approach, one can be successful in cutting nickel alloys.
Work Hardening
Across machine shops, nickel alloys are notorious for being difficult to machine. This reputation stems, largely, from work hardening, or a metal’s microhardness increasing due to the addition of heat. According to the Nickel Development Institute, this heat is generated through friction and plastic deformation of the metal. As the metal is cut, the friction between the cutting tool and workpiece generates heat which is concentrated around the cutting area.
Simultaneously, the metal is being physically worked. This means that as it is being machined, it is experiencing plastic deformation, which is a physical property that measures how much a material can be deformed to the point that it cannot return to its original shape.
This physical working of a nickel alloy increases its hardness faster than it does most other metals. The combination of high heat generation and physical work quickly increases the alloy’s hardness, causing tools to dull quickly and fail. This may result in scrapped parts and broken tools.
8 flute HVNI End Mill for Machining Nickel Alloys
Shown above is Helical Solutions’ End Mill for Nickel Alloys. This tool, engineered to excel in Inconel 718 and other nickel-based superalloys, is fully stocked in 6 and 8 flute styles.
Tool Adhesion
As nickel alloys are being machined and heat is generated, chips tend to become stringy and weld themselves to a tool’s cutting edge. This phenomenon, built up edge or BUE, rounds the cutting edge of the tool, resulting in poor cuts and increased friction, thus further contributing to work hardening. An example of BUE is seen in the image below.
Zoomed in display of built-up edge on End Mill Flutes
On the above tool, chips from the workpiece (Inconel 718) have welded onto the cutting edge, severely decreasing the tool’s effectiveness. Image Source: International Journal of Extreme Manufacturing
Built-up edge also speeds up tool wear, as the rotational forces involved in the cut increase. Now that the cutting edge is rounded from welded chips, a blunt tool is being forced into the workpiece.
With a blunt edge, the cutting motion changes from a shearing action to plowing. In other words, instead of cutting through the metal, the tool is pushing the material, resulting in poor cuts and increased friction.
Excessive Heat Generation
With poor cutting, internal heat of the tool rises, which can cause thermal cracking, defined by cracks that form perpendicular to the cutting edge. The fractures within the tool are created by extreme internal tool temperature fluctuations.
As a cutting tool rapidly overheats while cutting nickel alloys, cracks may form which can lead to catastrophic tool failure. With high temperatures, galling may also occur, which is characterized by pieces of the tool flaking off due to the same adhesion that causes BUE. As the tool is being welded to the workpiece and the machine continues to rotate it, pieces of the tool may start to break off resulting in tool failure.
Overcoming Nickel Alloy Difficulties
Temperature Control and Coolant Usage
The first step to effectively machine nickel alloys is to keep temperatures manageable as the workpiece is cut. Using high pressure coolant is mandatory. Coolant pressure should be 1000 psi or greater. This high pressure concentrating on the cutting zone of the workpiece will dissipate heat within both the cutting tool and workpiece. By doing so, the chances of work hardening lessen.
High pressure coolant will also aid in clearing out chips from the cutting area. Those hot gummy chips are responsible for BUE. Removing them as quickly as possible reduces the risk of BUE forming on the cutting edge. Additionally, chip removal is important to avoid chip recutting.
Chips absorb much of the heat and often work harden themselves. Recutting these hardened chips will dull the cutting edge resulting in poor cuts and decrease tool life. In general, water-based cutting fluids are preferable as they have higher heat removal rates and have a lower viscosity, which is needed for high metal removal operations.
Using the Proper Techniques
To also assist with heat removal, utilize climb milling techniques, where possible. When climb milling, the chip thickness is at its maximum at the beginning of the cut and tapers off until the cut is complete. Due to this, less heat is generated, as the cutting tool does not rub on the workpiece. Most of the heat from the cut is transferred into the chip.
Selecting the Proper Tooling and Coating
The next step is selecting the right end mill. Your end mill of choice should have a proper tool coating, such as Helical’s Tplus coating. Tool coatings are specifically engineered to improve tool performance by reducing friction, increasing tool microhardness, and extending tool life.
Next is selecting flute count. Tools used for nickel alloys need to be rigid to withstand the cutting forces present when machining high hardness alloys. Therefore, higher flute counts are necessary. If using traditional roughing toolpaths, your end mill should have at least 6 flutes. With 6 flutes, there is sufficient flute valley depth to allow for chip evacuation, while having a larger core diameter keeps the tool strong and rigid.
For finishing operations and instances of implementing high efficiency milling, higher flute counts should be considered. A tool used this way should have 8 flutes to provide excellent surface finish.
Helical’s End Mills for Nickel Alloys
CNC tooling manufacturer Helical Solutions’ End Mills for Nickel Alloys product offering, its HVNI tool family, specializes in machining nickel alloys as it exhibits these key tool features.
Four Helical Solutions End Mills for Nickel Alloys positioned over a Helical product container
The tools shown above are Helical Solutions’ End Mills for Nickel Alloys. These tools are coated in Tplus for high hardness, resulting in improved tool life and increased strength,
With its Tplus coating and variable pitch to minimize chatter, these solid carbide end mills are engineered to perform in all grades of nickel alloys. Coupled with their geometry to maximize cutting performance, Helical’s End Mills for Nickel Alloys utilize faster speeds and feeds, which are readily available on the Helical Solutions’ website and Machining Advisor Pro.
For more information about the chemical make-up, uses, and categorization of nickel alloys, read “In the Loupe’s” post “Understanding Nickel Alloys: Popularity, Chemical Composition, & Classification”.
https://www.harveyperformance.com/wp-content/uploads/2022/04/Feature-Image-Nickel-Alloys-2-IMG.jpg 525 1400 Will Lauzon http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Will Lauzon2022-04-04 11:44:542025-11-20 09:47:58Machining Nickel Alloys: Common Mistakes to Avoid
4 Key Benefits of Combination Feed & HEM End Mills
February 15, 2022/1 Comment/in Helical Solutions, Large Featured/by Harvey Performance Company
Designed to conquer machine limitations and other common machining issues, combination and multifunctional tooling are highly coveted by machinists. These tools often integrate multiple geometries and flute designs to tackle wider varieties of machining applications with the same tool. This means fewer tools and tool changes are needed within a job, reducing complexity and increasing shop flexibility.
Taking these Issues and limitations into consideration, Harvey Performance Company’s Engineering Team went to work to design a new series of end mills referred to as Helical Solutions’ Combination High Feed & HEM End mills. This product series offers a feature set that will solve the four common issues listed below along with a few other issues that machinists commonly experience in the spindle.
For most shops, machine limitations cause longer, costlier, and more complicated jobs. If you are reading this article, you may know exactly what we are talking about. Machinists have a job that needs to be completed and end up having to add another operation. They find themselves improvising on tooling to complete an operation. This is because their machine has a limited number of tool stations, less than adequate horsepower, or several other limitations. Many times, this will impact operations in a negative way by increasing overall cost or reducing the quality of parts. As the name suggests, Helical’s Combination Feed & HEM tooling has been designed to excel in both applications without requiring a tool change. The end profile is non-center cutting for high feed applications, while the offset chipbreaker OD geometry excels in high efficiency milling strategies.
Helical Solutions Combination Feed & HEM end mill
How This Tool Addresses Machine Limitations
A common issue present in a fair number of shops is a limited number of tool stations available. The Combination Feed & HEM products afford the ability to do multiple roughing and finishing operations with one tool, using only one tool position. This eliminates the need to try to blend tools or control multiple offsets in your machining operation.
A second machine limitation that may affect your tool choice is you machine horsepower. The high feed end geometry and the chipbreaker OD geometry are both designed to reduce the amount of power required. This opens up new opportunities within light duty and low horsepower machines, offering more flexibility to your shop.
Cut Down Part Cycle Times
In a shop, long cycle times negatively impact productivity and machine availability. As the manufacturing industry becomes more competitive and as jobs become more demanding, the need for reducing cycle times becomes even more important.
The Combination Feed & HEM End Mills allow the use of both High Feed and High Efficiency milling strategies that provide high metal removal rates in your operations.  Increased material removal rates lead directly to reduced cycle times, plus the versatility of these tools helps to avoid time-consuming tool changes.
Click Here to Watch Helical’s Combination Feed & HEM Mill Be Pushed to the Limits
Limiting Complexity and Increasing Ease of Use
With today’s machined parts growing in complexity, programming can become cumbersome with multiple machining strategies and many tools required.  Finding ways to reduce the complexity of programming can help an entire job run smoother through your shop.
These Combination Feed & HEM End Mills provide an increased ease of use. This gives you the ability to conquer multiple operations with one tool. This eliminates the need to program and set-up multiple tools, boosting productivity
Helical Solutions Combination Feed & HEM end mill laying over a product container
Cutting Down on Costs
Another common issue is the cost of purchasing tooling. The Combination Feed & HEM End Mills offer a feature set that allows the consolidation of tooling and operations. Reducing the number of different tools needed for your application can reduce the overall cost of your operations substantially.
Feed/HEM Product Capabilities and Application Areas
Helical’s Combination Feed & HEM End mills are designed to tackle a broad range of demanding operations in a wide variety of steel types. As these products were engineered to solve machine limitation issues, the end geometry excels across a variety of operations. These include High-Feed milling operations, machining bores, closed or open pockets, internal or external contours, etc. The peripheral geometry was engineered with flexibility in mind. This allows the use of an HEM (High Efficiency Machining) toolpath to achieve high metal removal rates while maintaining great chip control as well as most traditional roughing and finishing strategies.
The versatility of these tools can be easily illustrated with a long list of applications:
  1. High efficiency milling
  2. High feed slotting
  3. High feed roughing
  4. Milling in open and closed pockets
  5. Internal and external profiling
  6. Helical ramping and interpolation
  7. Rough and finish profile milling
  8. Offset plunge milling in slots and deep pockets
  9. Traditional roughing operations
  10. Contouring and profiling operations
Commonly, machinists would need a range of specialty tooling to complete different aspects of a job. This requires long cycle times, and higher costs when all the necessary tools are considered. As most shops suffer from a limited number of available tool stations, combination mills aid in alleviating this pressure. These tools are designed to excel and conquer.
Conquer Machine Limitations and Shop Issues
Helical’s Combination Feed & HEM End Mills were designed with versatility in mind. The major benefit of these tools is addressing machine limitations and the common issues presented above. These tools will provide you with a feature set that will allow you to combine operations, reduce cycle times, reduce cost, reduce scrap, and expand your machines capabilities. Let Helical impress you with the Combination Feed & HEM line of end mills.
https://www.harveyperformance.com/wp-content/uploads/2022/02/Feature-Image-Combo-Feed-HEM-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-02-15 15:52:512023-09-21 14:11:204 Key Benefits of Combination Feed & HEM End Mills
Page 2 of 3123
