Helix Angles Rule of Thumb
Slow Helix Tool <40°
Benefits
Drawbacks
High Helix Tool >40°
Benefits
Drawbacks
Harvey Tool Chamfer Cutters
How to Select a Spindle
properly selecting a spindle
Green Manufacturing: Lasting Environment & Shop Benefits
“Green Manufacturing” has become a common phrase used by many in America’s largest industry. It is defined by Goodwin College as “the renewal of production processes and the establishment of environmentally friendly operations within the manufacturing field.” Taking the time to rethink dated processes can save you time, money, and help build your reputation as a state-of-the-art business. The establishment of environmentally friendly machining processes is a huge leap in the right direction of creating an eco-friendly business.
green field with shrubs
Green Manufacturing is the next logical step forward for the industry.
How to Get Started With Green Manufacturing
The first step you should take on your march toward a more sustainable machine shop, and green manufacturing, is an evaluation of your facilities environmental impact. The most common method for environmental impact assessment of the manufacturing process is Life Cycle Assessment or LCA. ISO 14040 defines LCA as the compilation and evaluation of the inputs, outputs, and the potential environmental impacts of a product system throughout its life cycle.
4 Questions to Ask Yourself:
  1. Goal Definition and Scoping – What am I trying to achieve in this investigation?
  2. Inventory Analysis – What are the quantified inputs (energy, water, materials, etc.) and outputs (air emission, wastewater)?
  3. Impact Assessment – How do these things affect the environment?
  4. Interpretation – What can I change to make my processes more efficient and eco-friendly?
There are databases available to help with the inventory analysis. These databases collect information such as feed rate, cutting speed, tool diameter, cutting time, coolant properties, and then calculate all the material, and energy inputs and outputs.
Understanding the Impact of Cutting Fluids
Cutting fluids are most likely the number one pollutant in your machine shop, and are getting in your way of achieving green manufacturing. According to Modern Manufacturing Processes, North American manufacturers consumed more than 2 billion gallons in 2002, and the metal working fluid market has only grown since then. Cutting fluids have a number of benefits to the machining process, mostly involving cooling of the cutting region, lubrication, and chip evacuation.
Contaminants
Getting the most out of your coolant is a key factor of cost efficiency in any machine shop. Therefore, one of the largest problems you are likely to face, or are currently facing, is the deterioration of cutting fluid performance due to contaminants. The most common types of contaminants include:
  1. Free oils (tramp or sump oil) – Liquid that lubricates the gears and equipment of CNC machine seeping into the cutting fluid
  2. Coarse Particulates – Relatively larger solid waste, chips, and swarf
  3. Fine Particulates – Extremely small pieces of the workpiece or cutting tool that usually consist of heavy metals such as cobalt, cadmium, chromium, aluminum, and lead
  4. Microorganisms – Bacteria and fungi that grow inside the walls and pipes of the CNC machine
Coarse particulates such as chips and swarf are generally easily extracted using an H-Chain, chain and flight, push bar, or a flume system. Fine particulates are more difficult as they require either separation or filtration in the form of setting tanks, foam separators, centrifugal separation, or magnetic separators. Free oil can also be removed through filtration but can also be taken care of quickly and easily with a skimmer.
green manufacturing contaminants
The right filtration system can both save machine shops money and help the environment.
Microorganisms are the most difficult to remove as they can be a tenth of the size of fine particulates. “Monday morning stink” is a common side effect of anaerobic bacteria excreting hydrogen sulfide during their metabolic processes. These organisms are one of the main reasons coolant has to be drained and changed from a machine every few months. Advancements in technology over the past few decades have made it possible for membrane microfiltration systems to separate biomass, as well as oil from coolant fluids. With these types of systems, operators will no longer have to use problematic biocides as these have troublesome health effects for both the environment and employees. However, it is important to note that most of the microorganisms aren’t growing in the cutting fluid but on the walls/pipes of the machine or buried in the residue of chips at the bottom of the tank.
Some ways of reducing microorganism build-up in your shop include:
  • Keeping machines clean – sludge, swarf, and chips can be a breeding ground for bacteria
  • Reduce organic contamination – spit, sweat, tobacco juice, and organic matter are all a food source for microorganisms
  • Reduce the amount of tramp oil – This can also be a food source
green manufacturing
A dirty pile of chips where bacteria will grow and stink up your machine.
Types of Cutting Fluids
A good cutting fluid should have a high flash point, good adhesiveness, high thermal stability, and high oxidative stability. A high flash point is necessary as the fluid should not catch fire at high temperatures (gasoline has a low flash point). Good adhesiveness allows fluid to stick to the surface of the workpiece. This creates a layer between the cutting tool and the workpiece, helping to separate them and thus, reducing friction. Greater amounts of friction leads to higher cutting force, which leads to higher cutting temperatures.
High cutting temperatures are problematic, as this causes the cutting tool to wear faster and can also cause your workpiece to workharden. High thermal stability means that at high temperatures, the fluid should have a low viscosity (an example of a fluid with high viscosity would be honey at room temperature). A lower viscosity in the cutting region allows for a lower amount of friction, and therefore lower amounts of heat and cutting force. A cutting fluids oxidative stability ultimately decides how long that cutting fluid can be used. After a while, oil begin to oxidize, which then causes its viscosity and amount of deposits of sludge to rise.
green manufacturing
Excessive amounts of coolants can mean an excessive amount of waste.
For the purpose of this article, cutting fluids will be placed into two broad categories: biodegradable and non-biodegradable.
Non-Biodegradable Coolants
Non-biodegradable coolants are petroleum-based. They have high human and ecological toxicity, which results in occupational health risks. They also have a complicated disposal processes.
Biodegradable coolants are plant-based. These are usually manufactured from vegetables such as soy, coconut and canola, or non-edible plants such as neem, karanja, and jatropha. This factor makes them a renewable resource and less toxic to humans, as well as the environment.
In recent years, some modified vegetable-based oils have surpassed petroleum based oils in performance in regards to surface finish, heat suppression and lubrication. One study, published in Science Direct, centered on turning in 304 stainless steel revealed that coconut oil with a boric acid additive was significantly better at combating tool flank wear and surface roughness when compared to two other cutting fluids. This was due to the vegetable-based solutions high thermal stability.
Another study, published in IOP Science, found that a combination of neem and karanja oil was superior to SAE 20W40 (petroleum based oil) in regards to lubrication when drilling mild steel. The results showed that the vegetable-based oil solution reduced the cutting force of the operation due to its higher viscosity and adhesiveness. This ultimately led to a better surface finish on the part.
Summary of Cost Efficient Coolant Changes You Can Make
  • Reduce microorganism build up in your machines by keeping the machines clean and reducing amount of outside contamination
  • Install a membrane microfiltration system
  • Switch to a more efficient and biodegradable cutting fluid
The Positive Green Machining Impact of Dry Machining
Dry machining should be utilized whenever the opportunity presents itself, as the costs and environmental issues associated with cutting fluid obtainment, management, and disposal are eliminated. Another benefit to dry machining is the absence of thermal shock. When the cutter exits the cut but coolant is still blasting, the large temperature fluctuation (thermal shock) will cause the cutting edge to break down quicker than if it were to run hot full time. Dry machining is most prevalent in machining operations with interrupted cuts or when cutting hardened steels. It is especially popular in milling operations with high speeds and feeds. Cutting with high running parameters allows for most of the heat to be dispersed into the chips rather than into the workpiece. This is also the case when machining hardened steels.
Ideal Tooling for Dry Machining
The ideal cutting tool should be more heat resistant, and less heat generative. Carbide is a good substrate as it is extremely hard and strong. Coated tools are the best option for dry machining as they have improved thermal insulation as well as improved self-lubrication.
The Positive Affect of Minimum Quantity Lubrication (MQL)
  • Significantly reduced fluid consumption
  • Safer cutting fluids and lubricants
  • Reduced health hazards for employees
  • Cleaner shop environment
  • Reduced maintenance
Because such a small quantity of fluid is used in MQL, this make it a perfect application to use slightly pricier vegetable-based oils. MQL has been found to be most effective in sawing and drilling operations.
The Benefits of Green Manufacturing
Taking a second look at your current machining operations through and environmentalist lens can save you time, money, and create a less hazardous work place for your employees. Using the techniques above, one can approximate shop efficiency and make appropriate changes for the benefit of current and future generations.
harvey tool slitting saw
  2. Undercutting Applications
  3. Slotting into Material
How to Advance Your Machining Career: 8 Tips From Machining Pros
Since we began shining a light on Harvey Performance Company brand customers via “In the Loupe’s,” Featured Customer posts, more than 20 machinists have been asked to share insight relevant to how they’ve achieved success in advancing their machining career. Each Featured Customer post includes interesting and useful information on a variety of machining-related subjects, including prototyping ideas, expanding a business, getting into machining, advantages and disadvantages of utilizing different milling machine types, and more. This post compiles 8 useful tips from our Featured Customers on ways to advance your machining career.
Tip 1: Be Persistent – Getting Your Foot in the Door is Half the Battle
With machining technology advancing at the amazing rate that it is, there is no better time to become a machinist. It is a trade that is constantly improving, and offers so many opportunities for young people. Eddie Casanueva of Nueva Precision first got into machining when he was in college, taking a job at an on-campus research center for manufacturing systems to support himself.
“The research center had all the workings of a machine shop,” Eddie said. “There were CNC mills, lathes, injection molding machines, and more. It just looked awesome. I managed to get hired for a job at minimum wage sweeping the shop floor and helping out where I could.
As a curious student, I would ask a million questions… John – an expert machinist – took me under his wing and taught me lots of stuff about machining. I started buying tools and building out my toolbox with him for a while, absorbing everything that I could.”
One of the best things about becoming a machinist is that there is a fairly low entry barrier. Many machinists start working right out of high school, with 12-18 months of on-the-job training or a one to two year apprenticeship. Nearly 70% of the machinist workforce is over the age of 45. The Bureau of Labor Statistics is predicting a 10% increase in the machinist workforce with opportunities for 29,000 additional skilled machinists by 2024, so it is certainly a great time to get your foot in the door.
Tip 2: Keep an Open Mind – If You Can Think of It, You Can Machine It
Being open-minded is crucial to becoming the best machinist you can be. By keeping an open mind, Oklahoma City-based company Okluma’s owner Jeff Sapp has quickly earned a reputation for his product as one of the best built and most reliable flashlights on the market today. Jeff’s idea for Okluma came to him while riding his motorcycle across the country.
“I had purchased what I thought was a nice flashlight for $50 to carry with me on the trip. However, two days in to the trip the flashlight broke. Of course, it was dark and I was in the middle of nowhere trying to work on my bike. I’m happy to pay for good tools, but that wasn’t what happened. Not only was there no warranty for replacement, there was no way to fix it. It was just made to be thrown away. That whole attitude makes me angry. When I got home, I decided I was going to put my new skills to work and design and build my own flashlight, with the goal of never running into an issue like I had on my trip ever again. I started by making one for myself, then four, then twenty. That was four years ago. Now I have my own business with one employee and two dogs, and we stay very busy.”
An awesome side benefit to working as a machinist is that you have all the resources to create anything you can dream of, like Jeff did with Okluma.
machining career
Image courtesy of Okluma.
Tip 3: Be Patient – Take Time to Ensure Your Job is Setup Correctly before Beginning
The setup process is a huge part of machining, but is often overlooked. Alex Madsen, co- owner of M5 Micro in Minnesota, has been working in manufacturing for more than 11 years. Alex is also a part owner of World Fabrication, and owns his own job shop called Madsen Machine and Design. Alex has spent countless hours perfecting his setup to improve his part times.
“It is certainly challenging to use little tools, but the key is to not get discouraged. You should plan on lots of trial and error; breaking tools is just a part of the game. You may buy ten end mills and break six, but once you dial one in it will last the rest of the job.
You should also make sure to put extra time and effort into understanding your machine when working on micromachining jobs. You need to know where there is any backlash or issues with the machine because with a tiny tool, even an extra .0003” cut can mean the end of your tool. When a difference of one tenth can make or break your job, you need to take your time and be extra careful with your machine, tool inspection, and programming before you hit run.”
Tip 4: Effort Pays Off In Your Machining Career – Long Hours Result in Shop Growth
Success isn’t earned overnight. That is especially true in the machining world. Becoming a good machinist takes a great deal of sacrifice, says Josh from Fleet Machine Co. in Gloucester, MA.
“Opening your own shop involves more than learning how to program and machine. You also need to be willing to sacrifice some of your free time by working long hours to build your business from the ground up. Being a great machinist is important, but you also need to understand the basics of business, and you need to be able to sell your service and maintain a certain level of quality to keep your customers coming back.”
Working hard is a common theme we hear from our featured customers. Brothers Geordan and Nace Roberts of Master Machine Manufacturing have similar advice.
“We often need to work odd hours of the day to maintain the business, but we do it in a way that makes sure we have our family time. There are many times where we will go home, have dinner and hang out with the family, and wait until they are all sleeping to go back to work until two or three a.m. We will get back home later that morning to sleep a little and have breakfast with the family and send them on their way before heading back into the shop.” Starting and growing a business takes time. Every machinist starts from the beginning and through hard work and determination, grows their business.
Liberty Machine cnc mill
Image courtesy of Liberty Machine Inc.
Tip 5: Utilize Tooling from Quality Manufacturers – All Tooling Isn’t Created Equal
When it comes down to it, tooling is singlehandedly the biggest choice you will make in your machining career. Grant Hughson, manufacturing engineer at Weiss Watch Company who works as a manufacturing instructor in his spare time, reflected on the importance of tooling.
“Tool to tool accuracy and performance is vital in this business, especially with our extremely tight tolerances. High quality tools make sure that we get the same performance time after time without needing to scrap parts. This saves us valuable time and money.”
While opting for cheaper tooling can appear to be beneficial when just starting out, before long, machinists are losing time and money because of unpredictability. Jonathan from TL Technologies echoed this point, saying:
“We feel that if we invested so much in these high-end machining centers, it would be criminal to put insufficient tooling and holders into them. We found that by selecting the proper tool with the appropriate sciences behind it we have been able to create products with a cost per cut that is not only competitive, but required to stay current. By keeping the quality as high as possible on the part making side of things, we’ve insured as much ease and reliability into our downstream process as we could. Quality tooling also provides predictability and added safety into the workflow. High-quality carbide tooling is the lifeblood of the business.”
Additional Thoughts Regarding Boosting Your Machining Career With Tooling:
Don’t Cheap Out
  • “The additional cost is always worth the payoff in the end knowing that you have a tool that will produce quality parts and shave valuable minutes off your cycle times. The slightly higher cost of the Harvey/Helical product is small change compared to the long term cost savings associated with their performance” – Seth, Liberty Machine
Consistency is Key
  • “We know the performance we are going to get from the tools is consistent, and we can always rely on getting immaculate finishes. While using the Harvey Tool and Helical product, we can confidently walk away from the machine and come back to a quality finished part every time.” – Bennett, RIT Baja SAE
Superior Specialty Tools
  • “One of the greatest things that I’ve experienced over the past year and a half is flexibility. We’ve asked for some specific tools to be made typically, the lead times that we found were beyond what we needed. We went through the Helical specials division and had them built within a couple of weeks. That was a game changer for us.” – Tom, John Force Racing
“Having high quality tooling like Helical is essential. Helical tools help us maintain a much higher machining efficiency because of the outstanding tool life, while also achieving more aggressive run times. In addition, we are able to consistently keep high tolerances, resulting in a better final product.” – Cameron, Koenig Knives
Tip 6: Get With the Times – Join the Social Media Community
Social media is a valuable tool for machinists. With ever-increasing popularity in networks such as Facebook, LinkedIn, Twitter, and Instagram, there will always be an audience to showcase new and unique products to. We asked a few of our featured customers how they incorporated social media into their machining career and the benefits that come along with it.
“A lot of our sales come through Instagram or Facebook, so I would recommend those platforms to anyone who is trying to start a business,” Jeff from Okluma said. “We have also had a lot of success collaborating with others in the community. Typically it is something we couldn’t do ourselves, or they couldn’t do themselves, so we share the labor and collaborate on some really cool items.”
Tip 7: Value Your Customers – Always Put Them First
“In the Loupe’s” featured customers repeatedly emphasized the importance of putting customers first. It’s a simple concept to master, and pays off immensely as you advance in your machining career. Repeat customers tell you that you are doing something right, said Brian Ross, owner of Form Factory.
“We have kept our customers happy and consistently deliver parts on time, so we get a lot of repeat business. Word definitely gets around on how you treat people so we try to treat everyone with respect and honesty which is key to running a good business.” Jeff from Okluma takes great pride in his customer service, saying “we only sell direct to consumers through our website so we can control our lifetime warranty. It has worked really well for us so far, so we have no plans to change that right now. I care more about our customers than any retailer is able to.”
man examining machined part for machining career
Image courtesy of MedTorque.
Tip 8: Never Stop Learning – Ask Questions Whenever You Can as Your Machining Career Advances
Hopefully some of these tips from our featured customers stuck with you in exploring a machining career. To leave you with a quote from of Seth Madore, owner of Liberty Machine, “Don’t stop learning. Keep your ears open and your mouth shut,” “That old guy in the shop has likely forgotten more than you will ever learn. The amount of tools in your Kennedy box doesn’t mean you’re a good machinist. Some of the best toolmakers I knew had small boxes with only the common tools. Learn how to excel with limited resources. Ask questions, and own up to your mistakes.”
What is a Drop-Hole?
drop hole allowance
drop hole allowance
When Not to Drop Hole
drop hole allowance
Drop-Hole Placement
drop hole allowance
drop hole allowance
Understanding the Two Styles
Chipbreaker End Mills
Knuckle Roughers
  • Increased tool life.
While many manufacturers will specially coat a standard end mill at your request, this takes added time and cost. In its Material Specific catalog sections, Harvey Tool offers coated tools stocked and ready to ship. For instance, their Hardened Steels and Exotic Alloys categories utilize AlTiN Nano coating. This is a unique nanocomposite coating that has a max working temperature of 2,100° F and shows improved performance in materials such as Hardened Steels, Titantium Alloys, and Inconel, among others.
Miniature End Mill
Part Number: 836408
Material: 6061 Aluminum
Application: Slotting
Speed: 10,000 RPM
Chip Load: .00124 IPT
Linear Feed: 37.2 IPM
DOC: .04375
Part Number: 942308
Speed: 10,000 RPM
Chip Load: .00165 IPT
Linear Feed: 49.5 IPM
DOC: .0625
Extensive Cost Savings
material specific tooling benefit chart
tool life
tool life
helical end mill
tool life
