Multi-Start Thread Reference Guide
A multi-start thread consists of two or more intertwined threads running parallel to one another. Intertwining threads allow the lead distance of a thread to be increased without changing its pitch. A double start thread will have a lead distance double that of a single start thread of the same pitch, a triple start thread will have a lead distance three times longer than a single start thread of the same pitch, and so on.
By maintaining a constant pitch, the depth of the thread, measured from crest to root, will also remain constant. This allows multi-start threads to maintain a shallow thread depth relative to their longer lead distance. Another design advantage of a multi-start thread is that more contact surface is engaged in a single thread rotation. A common example is a cap on a plastic water bottle. The cap will screw on in one quick turn but because a multi start thread was used there are multiple threads fully engaged to securely hold the cap in place.
multi-start thread
Figure 1 displays a triple start thread with each thread represented in a different shade. The left side of the image represents a triple start thread with just one of the three threads completed. This unfinished view shows how each individual thread is milled at a specific lead distance before the part is indexed and the remaining threads are milled. The right side of the image displays the completed triple start thread with the front view showing how the start of each thread is evenly spaced. The starting points of a double start thread begin 180° apart and the starting points of a triple start thread begin 120° apart.
multi-start thread
Figure 2 displays the triangle that can be formed using the relationship between the lead distance and the circumference of a thread. It is this relationship that determines the lead angle of a thread. The lead angle is the helix angle of the thread based on the lead distance. A single start thread has a lead distance equal to its pitch and in turn has a relatively small lead angle. Multi-start threads have a longer lead distance and therefore a larger lead angle. The graphic depicted on the right is a view of the lead triangle if it were to be unwound to better visualize this lead angle. The dashed lines represent the lead angle of a single start thread and double start thread of the same pitch and circumference for comparison. The colors represent each of the three intertwined threads of the triple start thread depicted in Figure 1.
Lead Angle Formula
multi-start thread
The charts below display the information for all common UN/Metric threads as well as the lead and lead angle for double and triple start versions of each thread. The lead angle represented in the chart is a function of a thread’s lead and major diameter as seen in the equation above. It is important to be aware of this lead angle when manufacturing a multi-start thread. The cutting tool used to mill the thread must have a relief angle greater than the lead angle of the thread for clearance purposes. All Harvey Tool Single Form Thread Milling Cutters can mill a single, double, and triple start thread without interference.
Machining a Multi-Start Thread
  1. Use the table or equation to determine the pitch, lead, and lead angle of the multi-start thread.
  2. Use a single form thread mill to helically interpolate the first thread at the correct lead. *The thread mill used must have a relief angle greater than that of the multi-start thread’s lead angle in order to machine the thread.
  3. Index to the next starting location and mill the remaining parallel thread/threads.
Click here for the full chart – starting on Page 2.
multi-start thread
Corner Engagement
corner engagement
corner engagement
corner engagement
Ramping to Success
ramping
What is Ramping?
ramping
Benefits of Ramping
climb milling
Climb Milling (Figure 3)
climb milling
How To Avoid Common Part Finish Problems
Cutting Circular Tool Paths
Internal Circular Tool Paths
External Circular Tool Paths
Optimize Your Performance
Use Proper Tooling
Axial Depth of Cut (ADOC)
To support the thin wall during the machining process, keep a wide-cross section behind it. We recommend utilizing a “stepped down” approach, which divides the total wall height to manageable depths while working each side of the wall. The Axial Depth of Cut (ADOC) dimension will vary depending on the material (and its hardness) being cut.
thin wall milling
Radial Depth of Cut (RDOC)
thin wall milling
  • Climb milling will help to keep tool pressure to a minimum.
  • Manual vibration dampening and wall stabilization can be achieved by using thermoplastic compounds, or wax, which can be thermally removed.
  • The use of ultra-high performance tool paths can optimize tool performance.
Avoid Tool Deflection
deep cavity milling
deep cavity milling
Achieve Optimal Finish
Deep Cavity Milling
Mill to the Required Depth
Evacuate Chips Effectively
that must be avoided.
Deep Cavity Milling
How To Combat Chip Thinning
Defining Chip Thinning
Chip Thickness
How Chip Thinning Occurs
radial chip thinning
Lasting Benefits
