September 15, 2025/0 Comments/in CNC Machining, Harvey Tool, Large Featured, Machining 101, Machining Techniques, Milling, Milling, Specialty Tools, Tool Coatings, Tool Geometry, Tool Selection, Troubleshooting Tips/by Harvey Performance Company
CNC engraving is a process that removes a small amount of material to create detailed images or shapes. Many manufacturers use this method for labeling parts or creating complex designs; however, not everyone is aware of the key techniques necessary for optimal results. When using an engraving tool, it is essential to consider several challenges that could affect both the tool and the operation.
Advantages of CNC Engraving
Compared to other engraving methods, CNC engraving is fast, consistent, and cost-effective. Thanks to their repeatability, CNC machines deliver consistent results when paired with a high-quality engraving tool. We suggest running the tool at a minimum of 6,000 RPM.
If your machine supports it, increasing the RPM can lead to even greater results. Running at lower speeds can negatively impact tool life. Choosing the right engraving tool requires considering production volume and tool engagement time. Key factors such as tip design, angle, and coating play a crucial role in maximizing efficiency and durability.
Proper Engraver Tool Selection
Most machinists understand that a square-corner end mill does not last as long as a corner-radius or ball-end mill due to its fragile cutting edge.
The same principle applies to CNC engraving tools. An engraver that comes to a sharp point is more fragile than one with a tipped-off or radius tip. For long production runs, consider using a tip-off or rounded tip design, as these geometries distribute cutting forces more evenly across the cutting edge, improving tool longevity. A tip-flat design will last longer than a pointed tip but not as long as a radius tip. If high-detail work is required, a pointed tip is preferable because it provides greater precision.
Pointed Tip Engraving Cutters
Tipped Off Engraving Cutters
Tip Radius Engraving Cutters
Environment and Detail Considerations
Similar to tip geometry, the engraving angle plays a critical role in visibility. The environment in which the engraving is used affects how well it can be seen. If the engraving is exposed to harsh conditions with elements like snow, mud, or dirt, debris can accumulate in the grooves, making it difficult to see and clean. A larger angle creates a wider groove, improving visibility and ease of cleaning.
The image below illustrates three different engraving angles offered by Harvey: the leftmost groove is 30° included, the middle groove is 60° included, and the rightmost groove is 120° included. Each of these engravings is only 0.009 inches deep.
Notice that the 120° engraving is more visible at a distance due to increased surface exposure. If a job requires precision and detail, a smaller angle is preferable. While geometry significantly impacts engraving visibility and tool longevity, another key factor in tool performance is the choice of coating.
Choosing a Tool Coating
A coated engraving tool will last longer than an uncoated one because the coating provides a protective barrier between the tool and the workpiece. Additionally, coatings help reduce heat absorption, increase lubricity, and decrease tool wear. Selecting the right coating depends on the material being machined.
For example, our AlTiN and AlTiN-Nano coatings perform best in stainless steel and nickel alloys. For non-ferrous materials such as aluminum or copper, our Amorphous Diamond coating is ideal. As an alternative to our Amorphous Diamond coating, we also offer ZrN or TiB2 coatings.
A common misconception is that diamond-coated tools can be used on ferrous materials. Instead, this leads to rapid heat generation and premature tool failure.
Successfully Running Your Engraver
Selecting the correct engraving tool is just as important as understanding how to operate it properly. Even the highest-quality tool will be wasted if not used correctly. As with any machining operation, you must consider depth of cut, work holding methods, and appropriate speeds and feeds
Cutting Speeds and Feeds for Engraving
The tip is the most delicate area of the tool which makes running at the correct speed and feed rate crucial. Running at an incorrect speed and feed rate can cause deflection, which will lead to an inaccurate engraving, chipping, breaking, or a poor surface finish.
At Harvey, we recommend a minimum spindle speed of 6,000 RPM. Operating at higher RPMs, when possible, offers even better support for tool tip integrity.
Higher speeds ensure tool stability as it will be less likely to cause vibration and reduces heat buildup during operation. Running too slowly generates excess heat and vibration leading to chipping, breakage, or having a poor surface finish. To help maintain tool tip integrity, it is important to follow the recommended depth of cut and consider the way the engraver enters the material.
Determining Depth of Cut
Many machinists are unaware that taking cuts deeper than 0.009 inches can shorten the lifespan of a Harvey engraving tool. For depth of cut ranging from 0.001 inch to 0.009 inches, you can operate within our stated speed and feed guidelines. If the operation requires a deeper groove, the chip load must be reduced accordingly. For depths between 0.010 inches and 0.015 inches, reduce the chip load by 20%. For depths ranging from 0.016 inches to 0.020 inches, reduce the chip load by 30%. Depth of cut also influences visibility. A deeper cut made with a tool that has a smaller angle can provide similar visibility to a shallower cut made with a tool that has a larger angle.
The image below illustrates different engraving depths using a 30° included angle. From left to right, the depths are 0.009 inches, 0.015 inches, and 0.020 inches. As depth increases, visibility improves. When engaging the tool with the workpiece, it is best to ramp into the material to protect the tool tip.
We recommend a ramp angle of 1° to 3° for ferrous materials such as stainless steel, and 3° to 10° for non-ferrous materials like aluminum or copper. If ramping is not an option, you may plunge the tool into the material. However, the chip load must be reduced by 50% during entry. Once the desired depth is reached, you can return to the recommended running parameters. Another key consideration is ensuring the workpiece is securely held in place.
Workholding Considerations
Runout or vibration during engraving can result in uneven cuts and tool failure. To prevent this, ensure that engraving tools are held in a sturdy toolholder and that the workpiece is secured. A shrink-fit toolholder minimizes runout and provides excellent stability. While ER collets are acceptable, they wear overtime. To verify an ER collet’s suitability, place an indicator on the tool shank and rotate the tool within the collet. The goal is to achieve the least possible runout, ideally no more than 0.0003 inches.
The workpiece should also be properly secured, either in a vise or a fixture. To detect vibrations during operation, listen for irregular noise or feel for vibrations through the CNC machine door. For cooling, coolants are recommended for metallic workpieces, while an air blast is preferable for non-metallic materials such as plastic.
When selecting an engraving tool, it is essential to choose the correct geometry for the operation, as well as the appropriate coating for the material being machined. Regardless of tip geometry, the engraving tool’s tip is its most fragile part. Proper speed, feed rate, and depth of cut are crucial for maximizing tool life.
For metallic workpieces, a cooling method such as coolant is necessary, while non-metallic workpieces require an air blast. Before starting a new engraving operation, double-check tool runout and ensure that the workpiece is securely held in place.
By following these best practices, CNC engraving operations can achieve high precision, longevity, and optimal tool performance.
Are You Ready to Put Your Engraving Knowledge to Use?
Browse Harvey Tool’s full selection of precision engravers, coatings, and geometries designed for optimal performance in a wide range of materials.
HREM vs HEM: Titanium Milling Test Results
July 30, 2025/2 Comments/in CNC Machining, Harvey Tool, Helical Solutions, High Efficiency Milling, Large Featured, Machining Techniques, Milling/by Harvey Performance Company
Harvey Performance Company’s Don Grandt Employs a Novel “Heavy Radial Efficiency Milling” or “HREM” Technique to Boost Tool Life and Minimize Heat Generation in Titanium
For all the characteristics that make Titanium ideal for extreme conditions, such as its high strength, low density, and corrosion resistant properties, it also makes it very difficult to machine. A modern approach to machining, High Efficiency Milling (HEM), helps. It involves using the theory of chip thinning by applying a smaller Radial Depth of Cut (RDOC), and a larger Axial Depth of Cut (ADOC). This method puts the vast majority of an end mill’s cutting edge to work, evenly distributing heat throughout it. An HEM toolpath works by taking more radial passes with a lower RDOC.
But from experience, Harvey Performance Company National Applications Engineer and “Cutting Tool Counselor,” Don Grandt, has found that there’s a better way to machine titanium. Rather than HEM, Don employs a strategy he calls “Heavy Radial Efficiency Milling (HREM)”, something he’s developed over time with a tried and true “Theory, Science, Experience (TSE) Triple Knowledge Approach” to machining.
The Theory:
In switching from a regular toolpath to a standard HEM toolpath, machinists are permitted to increase the surface foot and boost material removal rates because there is less heat generated at the cutting edge due to the lighter radial depth of cut being utilized.
In titanium, specifically, recommended parameters for HEM are often in the ballpark of 400-500 SFM and 121-152 M/Min, with a radial step over of 6% of the cutting diameter. This allows you to increase the speed to achieve higher feed rates.
However, Don has noticed that most of the heat is coming from the SFM or M/Min when machining titanium, and not the RDOC, thus prematurely fatiguing the cutting edge of the tool in HEM toolpaths. He uses the “MRR Triangle” to compensate for this.
In a 2022 episode of In the Loupe TV, a collection of videos Don creates to educate the machining industry on popular machining methods, tips, tricks, and more, he dives into the Material Removal Rate Triangle, explaining that it’s a representation of how IPM, ADOC, and RDOC interact.
“Each one of these things…contributes to your MRR, material removal rate. I know I don’t want to change that, I don’t want to stop it, and I don’t want to slow the customer down. So what do I do?
Three things (IPM, ADOC, and RDOC) are bringing in the heat. Which one’s causing the most heat? That’s what I want to find out. Because guess what? If I find out which one’s causing the most heat, and I can bring that down, then I can bring one of my other things over, adjust it, keep my MRR, and stay productive.”
In this case, Don opts to increase the RDOC while running the tool at lower SFM-M/MIN, the backbone of the “HREM” toolpath. An illustration of this toolpath, compared to a traditional and standard HEM toolpath, is below.
The Science:
While Don’s strategy can be utilized using any End Mill for Titanium, including Harvey Tool’s offering of Variable Pitch End Mills for Titanium Alloys, the below comparison of HEM vs. HREM toolpaths showcases a 6 Flute Helical Solutions End Mill for Titanium.
HEM vs. HREM Parameters Comparison (3.51 Cubes of Material)
HEM Parameters for ½”, 6 Flute Tool in Ti6AL4VHREM Parameters for ½”, 6 Flute Tool in Ti6AL4v
ADOC1.01.0
RDOC.030/6% Stepover.130/27% Stepover
SFM400220
RPM30561680
FPT.0064.0026
IPM11827
Spindle Load31%40%
This chart compares an HEM toolpath to an HREM toolpath, using the same Helical Solutions End Mill in Ti6AL4V Titanium.
Notice that in this independent study, the ADOC remains consistent, the IPM decreases, but the RDOC is substantially increased.
The change in parameters, utilizing the MRR Triangle as a model, generates consistent results in both time and MRR output, so what’s the benefit of making the change? Tool life. And again, it boils down to heat generation.
Toolpath Results
Traditional HEM Strategy
“HREM” Strategy
Max Tangential Force228397
Peak Tool Temperature1,218° F / 660° C857° F / 458° C
Cubes of Material Removed3.51 Cubes of Ti6AL4V3.51 Cubes of Ti6AL4V
Here, we can identify that, though more max tangential force is applied to the tool in the HREM method, significantly less heat is generated.
While any cutting tool will generate heat, controlling it is pivotal to prolonging the life of your tool.
The Experience:
From the example above, where the same Helical Solutions End Mill for Titanium was utilized, you can see that by simply increasing the RDOC and slowing down the feed, while accommodating the chip with more flutes, the MRR remains consistent but the cutting edge of the tool faired much better.
Toolpath Results
HEM Example
HREM Example
Before Utilizing an HREM Strategy
While HREM can be beneficial in extending the life of your cutting tool when machining titanium, there are several things that machinists must be mindful of before beginning. Notably, an HREM strategy will add more tangential force to your setup, meaning that fixturing, horsepower, and bending force must be properly accounted for.
In addition, the longer the tool’s length of cut, the less radial there is to be had. This means that if a tool’s length of cut is 2x the diameter, the maximum RDOC will be 27%. With 2.5x length of cut, the maximum radial will only be 20%. As the length of cut increases, the radial decreases, meaning that machinists must make adjustments accordingly to reduce the SFM and, in turn, reduce heat generation and built-up edge (BUE).
Harvey Performance Company Brand Tooling Best Suited for HREM
Leading cutting tool brands Helical Solutions and Harvey Tool offer several cutting tool options specifically designed for the machining of Titanium Alloys. Helical’s offering is extensive, with options ranging from roughers to 5, 6, 7, and multi-flute finishers. Included in this range of fully stocked product is the popular HVTI-6 line, which is optimized specifically for advanced machining toolpaths, such as HEM and HREM, in Titanium.
Harvey Tool’s Material Specific End Mill offering includes options for Titanium Alloys, as well. Featuring variable pitch geometry, options include both square and corner radius profiles. A new Variable Pitch End Mills for Titanium Alloys – Ball offering is set to be released in August 2025.
By rethinking conventional titanium machining strategies, Don’s “Heavy Radial Efficiency Milling” (HREM) approach challenges the standard High Efficiency Milling (HEM) model with proven results. Through his “Theory, Science, Experience” methodology, Don demonstrates that increasing radial engagement while reducing surface speed can significantly lower tool temperatures and extend tool life, all without sacrificing productivity. Backed by data and real-world trials, HREM offers a compelling alternative for shops looking to optimize titanium machining performance in the most demanding applications.
Copyright © 2025 Harvey Performance Company, LLC. All rights reserved. This article may not be reproduced or distributed without permission.
https://www.harveyperformance.com/wp-content/uploads/2025/07/1400x525-Featured-Image-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2025-07-30 10:26:362026-03-31 09:47:34HREM vs HEM: Titanium Milling Test Results
January 29, 2025/0 Comments/in CNC Machining, Helical Solutions, Machining 101, Machining Techniques, Milling, Specialty Tools, Tool Geometry, Tool Information Guides, Tool Selection/by Thomas Donahue
Helical Solutions offers a variety of Tapered End Mills designed to enhance performance and efficiency in tapered wall applications. In this blog post, we’ll dive into the geometry of tapered end mills and explore their common applications to understand when they could be utilized to optimize your CNC machining application.
Tapered End Mill Geometry
Tapered End Mills bring many advantages to machining compared to standard end mills, but what is a Tapered End Mill? A standard end mill will have the same cutting diameter throughout the whole length of cut, whereas a taper mills starts at the shank or neck at a larger diameter and tapers down at a specific angle.
The angle of the taper can vary, but Helical Solutions’ tools feature angles ranging from .05° to 5°, which allows for a broad spectrum of cutting operations. A tapered length of cut or tapered neck can also provide increased strength and rigidity, compared to that of a standard end mill. Having a tapered length of cut makes it easier to create flat tapered walls on 3-axis machines and leads to a better finish.
Tapered End Mill
Standard End Mill
Common Taper Mill Applications
Tapered End Mills are used in any machining process that requires an angled surface. These tools are engineered for light profiling and finishing applications in mold and die pockets and other tapered wall applications.
Mold & Die Applications
Mold and die applications are a mass production manufacturing method that consists of shaping different types of metals and other materials. Molds are used to shape metals, allowing them to become solid in the mold, while dies use a mechanical force to cut the material into the desired shape.
A couple examples of mold and die applications are plastic bottles, car body parts, electronic components, cutlery, coins, and metal stamping parts.
Mold Tool & Die Example
Tapered End Mills Profiles
Taper mills are great for profiling with the ball nose version, and for light finishing and creating required draft angles with the square version. Which style is right for you?
Ball Nose Taper Mills
Ball Nose Tapered End Mills are great for profiling because the full radius at the bottom eliminates sharp edges, which leads to a smoother process.
Square Profile Tooling
The square version of the tapered end mill has a higher flute count and helix angle with a sharp cutting edge. This is better for light finishes on the walls of tools.
The draft angle determined in the design process is the amount of mold design can be tapered. A draft angle is a strategic angle or slope designed in the mold. The tapered angle in the tool allows for the draft angle to be formed easier compared to a straight shanked end mill. Having a draft angle in the mold allows for easier removal of the part so it does not get stuck to the mold.
Helical Solutions’ Tapered End Mills
Helical Solutions’ offering of Tapered End Mills feature a tapered profile design, variable pitch geometry for reduced harmonics and increased feed rates, and Aplus coating for increased performance in Cast Iron, Steel, and even Stainless Steel. These tools are offered in a 4 Flute Ball style, and a 5 Flute Square style, so you can select the end profile that best suits your specific toolpath.
Helical’s Tapered End Mills
4 Flute Ball (HTPR-4)
Helical’s 4 Flute Ball Tapered End Mills (HTPR-4) are fully stocked in 6 different angles per side (0.5°, 1°, 1.5°, 2°, 3°, 5°), and in 3 different cutter diameters (1/8”, 3/16”, ¼”). These tools feature a ball nose profile, allowing them to excel in a variety of different applications from 3D contouring and profiling to slotting. A Ball Nose End Mill has a full form radius, allowing machinists to utilize the entire radius when contouring and finishing a 3D surface.
5 Flute Square (HPTR-5)
Helical’s 5 Flute Square Tapered End Mills (HTPR-5) is also is also fully stocked 6 different angles per side (0.5°, 1°, 1.5°, 2°, 3°, 5°), and in 3 different cutter diameters (1/8”, 3/16”, ¼”). These tools feature a square profile for more precise finishing and the 5 flute design creates a larger core, allowing for better tool strength in roughing applications.
Taper Mill Tooling Wrapped-up
By understanding the unique features and advantages of this tooling, machinists can make informed decisions and achieve superior results in their projects. These feature unique geometry that enhances machining capabilities and ensures reliability and accuracy across a range of tapered wall applications.
https://www.harveyperformance.com/wp-content/uploads/2025/01/DSC_0434.jpg 525 1400 Thomas Donahue http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Thomas Donahue2025-01-29 15:55:382025-01-30 09:14:54A Closer Look at Helical Solutions’ Tapered End Mills
December 10, 2024/4 Comments/in CNC Machining, Drilling, Drilling & Holemaking, Getting Started, Holemaking, Large Featured, Machining 101, Machining Techniques, Material Specific, Tool Geometry, Tool Information Guides, Tool Selection/by Emily Van Volkom
When it comes to achieving precision in CNC drilling applications, the choice of tools and techniques can make a significant difference in the outcome. One essential element that often doesn’t get the spotlight it deserves is the Pilot Drill. This blog post will explore the importance of pilot drills, their applications, and best practices for integrating them into your CNC machining processes.
What is a Pilot Drill?
A pilot drill is used to create a guide hole in deep drilling applications where precision is required. This guide hole keeps the drill on center, maintaining straightness throughout the cut. By creating a pilot hole, machinists can also improve the quality of the finished product and extend the life of their tools.
The Importance of Pilot Drills in CNC Machining
1. Enhanced Accuracy
The primary advantage of using a pilot drill is the enhanced accuracy it provides. When working with harder materials or complex geometries, a small pilot hole helps maintain the alignment of the longer drill, reducing the risk of misalignment and defects.
2. Extended Tool Life
Using a pilot drill can significantly extend the life of your deep-hole drilling tools. By first creating a pilot hole, the chasing drill experiences less stress, reducing wear and tear, and the chance of breakage, ultimately leading to cost savings from longer tool life.
3. Improved Chip Removal
Pilot drilling can enhance chip removal, particularly in deep-hole drilling scenarios. The smaller pilot hole allows for better coolant flow, which is crucial for effective chip evacuation and maintaining optimal cutting temperatures.
Applications of Pilot Drills
Pilot drills are versatile and can be used in various applications, including:
  1. Deep-hole Drilling: Pilot holes create a guide when drilling deep holes for improved centering and straightness.
  2. Tapping Operations: A pilot hole can facilitate easier and more accurate tapping.
  3. Reaming: When preparing for reaming operations, a pilot drill can ensure the hole is properly aligned and sized.
  4. Screw and Bolt Holes: Pilot holes are essential for ensuring screws and bolts are inserted correctly and securely.
Best Practices for Using Pilot Drills
1. Application
Piloting is recommended for tighter tolerance holes when drilling at depths of 8xD or greater. Valor Holemaking provides a custom tolerance of +0.0002/+0.0005 (+0.005mm/+0.013mm) to create the perfect oversized guide hole for their traditional drill lines capable of drilling 8xD or greater. Valor Holemaking’s Pilot Drills also include a +2/+1 deg angle tolerance to ensure a larger angle than the chasing drill. Piloting depth is recommended as 3xD for all applications drilling 8xD or greater.
2. Choose the Right Size and Point Angle
Selecting the appropriate size for your pilot drill is crucial. As a rule of thumb, the diameter of the pilot hole should be slightly larger than the diameter of the final hole. This allows for optimal support for the chasing drill while preventing excessive material removal. The pilot drill’s point angle should be equal to or larger than the succeeding drill. This allows the tip of the succeeding drill to engage the material before the flank does (see figure below).
3. Optimize Feed Rates
When using a pilot drill, ensure that the feed rates are optimized for both the pilot and the larger drill. Adjusting the feed rate can improve performance and reduce the risk of tool breakage. Valor Holemaking’s downloadable speeds and feeds tables and Machining Adviser Pro are excellent resources, and you can always consult Valor Holemaking’s Tech Team for further assistance!
4. Use Proper Coolants
Effective cooling and lubrication are vital in metal machining. Ensure that your pilot drill is adequately cooled with flood coolant or adjust speeds and feeds to maintain tool integrity and enhance cutting performance.
5. Maintain Tool Condition
Regularly check the condition of your pilot drills. Worn or damaged pilot drills can lead to inaccuracies and affect the performance of subsequent operations.
6. Integrate with CNC Programming
Incorporate pilot drilling into your CNC programs to ensure that it’s executed at the right stage of your machining process. Program one revolution or brief dwell at the bottom of the pilot hole to ensure a clean surface. This will help streamline operations and improve overall efficiency.
Pilot drills may seem like a small detail in the larger scope of CNC machining, but their impact on precision, tool life, and overall efficiency is significant. By understanding their importance and implementing best practices, machinists can enhance their processes and achieve superior results. Whether you’re a seasoned CNC operator or just starting out, incorporating pilot drills into your workflow is a smart move that can lead to greater accuracy and success in metal machining.
https://www.harveyperformance.com/wp-content/uploads/2024/12/Featured-Image-Pilot-Drills-IMG.jpg 525 1400 Emily Van Volkom http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Emily Van Volkom2024-12-10 13:53:412025-01-30 09:11:16Mastering Precision: Pilot Drills in CNC Machining
Traditional vs Free Cutting Honeycomb Core Tools
May 16, 2024/0 Comments/in CNC Machining, Composites, Machining Techniques, Material Specific, Milling, Tool Geometry, Tool Selection/by Harvey Performance Company
Precision cutting plays a pivotal role in the manufacturing of honeycomb core. CoreHog, a leading provider of composite cutting solutions, offers two distinct styles of Honeycomb Core Finishing Tools: Traditional Finishing Core Tools and Free Cutting Tools. In this post, we explore the advantages and limitations of both Traditional Finishing Core Tools and Free Cutting Core Tools, helping you determine the right choice for your unique manufacturing needs.
CoreHog’s Large Core Finishing Tool
Advantages of Traditional Honeycomb Finishing Tools:
CoreHog’s Finishing Core Tools are designed to handle substantial cutting tasks, efficiently. With three size ranges available, they excel at removing high volumes of material and boast excellent tool life, making them ideal for production applications.
assembly infographic of corehog's honeycomb core finishing tools
Assembly Configuration of CoreHog’s Large & Free Cutting Finishing Core Tools
However, these tools may pose limitations in specific applications. Traditional tools exert tool pressure, but depending on the tool geometry and part profile, the pressure may be too much for the part. This becomes more pronounced when cutting knife edge features such as chamfers and bevels, where the pressure exerted by the tool can cause the part to arch, dislodging it from the table, and ultimately causing it to deviate from specifications.
Introducing Free Cutting Core Finishing Tools:­­
To address the limitations of traditional honeycomb core finishing tools when cutting knife edge features, CoreHog offers Free Cutting Finishing Core Tools. The innovative design reduces tool pressure seen in both the Coreslicer and CoreHogger. The Free Cutting Coreslicer features a more acute and sharper angle, reducing the upward pressure exerted on the part during cutting.
 Differentiation of angle between the Large Coreslicer and the Free Cutting Coreslicer
Further, these tools feature a CoreHogger with a reduced diameter, allowing for greater offset between the CoreHogger and Coreslicer. This allows the Coreslicer to be more forward and free cutting, engaging with the material prior to the CoreHogger and reducing the resulting pressure typically exhibited by the CoreHogger.
large and free cutting honeycomb core finishing tools
Reduced diameter design of Free Cutting CoreHogger decreases tool pressure on the part.
When to Use Free Cutting Tools:
CoreHog’s Free Cutting Core Finishing Tools are particularly well-suited for applications involving chamfering, beveling, and cutting angled profiles in honeycomb core materials. By reducing pressure and preventing lifting on the part, these tools ensure precise cuts without compromising part quality.
­­Traditional vs. Free Cutting Core Finishing Tool: Summarized
In conclusion, choosing the right cutting tool is crucial for achieving precise results in composite manufacturing. While traditional finishing core tools excel in handling substantial tasks, they may pose challenges when cutting angled profiles in honeycomb core materials. CoreHog’s Free Cutting Core Finishing Tools offer a solution by minimizing pressure on the part, making them ideal for chamfering, beveling, and most other angled profiles. However, in finicky applications where the knife edge part is extremely shallow, a Valve Stem Cutter may still be necessary to achieve your desired cut. By understanding your specific cutting requirements, you can select the most suitable tool for your application, ensuring optimal results in your honeycomb manufacturing processes.
https://www.harveyperformance.com/wp-content/uploads/2024/05/Feature-Image-Free-Cutting-Core-Tools.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2024-05-16 14:41:282025-11-20 09:49:41Traditional vs Free Cutting Honeycomb Core Tools
Multi-Axis Finisher Q&A
March 29, 2024/2 Comments/in Helical Solutions, How-To's, Large Featured, Machining 101, Machining Techniques/by Tom Pyle
What is a Multi-Axis Finisher?
A tool that uses an extremely large radius to increase finishing performance in two different ways, depending on the needs of the machinist. Either the Multi-Axis Finisher will provide a better surface finish than a traditional Ball End Mill in the same amount of time, or will provide the same surface finish in far less time than a traditional Ball End Mill. A middle ground with improved surface finish and reduced cycle time is also easily achievable.
What Are Other Names for Multi-Axis Finishers?
Multi-Axis Finishers are oftentimes referred to as Barrel Cutters or Conical Barrel Mills or Circle Segment Cutters, among many others.
What Are the Different Forms of Multi-Axis Finishers, and How Do They Differ?
There are several different forms of Multi-Axis Finishers, including Lens, Taper, Oval, and Barrel. With a Lens Form, there’s a large radius on the end of the tool that’s in line with the tool axis. Taper Form, in contrast, has three tangential radii and a large radius defined at a specific angle relative to the tool axis. An Oval Form has two tangential radii, offering additional angle flexibility, while a Barrel Form has a large radius on the OD of the tool.
The most significant benefit is oftentimes observed utilizing a Taper Form Multi-Axis Finisher, as the radius of this tool can become vastly large on this form, while the others are more limited. However, this great benefit also comes with the least amount of flexibility in terms of approach to a workpiece.
What Are the Benefits of a Multi-Axis Finisher?
There are two clear benefits to using a Multi-Axis Finisher, compared to a Ball End Mill: Increased surface finish, and reduced cycle time (Or most likely both, concurrently).
What is a Benefit Multiple?
Helical Solutions is the industry’s premier manufacturer of Multi-Axis Finishers, and the Benefit Multiple is a significant reason why. Helical specifies the theoretical benefit that can be seen with its Multi-Axis Finishers, providing machinists direct insight into the gains that can be realized with these tools.
Benefit Multiple refers to the Cusp Height, correlated directly with the theoretically-achievable surface finish. Assuming the same cusp height from a Ball End Mill to a Multi-Axis Finisher, the Benefit Multiple relates to the time savings that could be seen in a machinists’ toolpath. For example, a Benefit Multiple of 4 would result in a toolpath ¼ as long as for a Ball End Mill of the same diameter. The stepover pass-to-pass would be 400% as much as a Ball End Mill to keep the same cusp.
When Should I Not Use a Multi-Axis Finisher?
Multi-Axis Finishers are best applied to wide-open surface areas; or large, smooth contours rather than small features or tight areas. Application of these tools will always be on a case-by-case basis. For help with your specific application, contact Helical Solutions Technical Support at 866-543-5422.
How Can I Get the Most Out of My Multi-Axis Finisher?
Multi-Axis finishers are best utilized when working further towards the OD of the tool. Tapered Form Multi-Axis Finishers are the most obvious choice for this, as its nose radius is small and has the least amount of efficiency. Similarly to a ball end mill, working near the center will have limited cutting ability, while the OD of the tool will see the full surface footage of the programmed RPM.
Taper Form Multi-Axis Finishers should be used when tilted at the specified taper angle. Oval Form Multi-Axis Finishers should be used towards the OD. Lens Form Multi-Axis Finishers should be tilted to avoid working on-center.
Lens Form Multi-Axis Finishers Look Like a High Feed End Mill. Can I Use it That Way?
Yes. However, there are differences in the form, and while a Lens Form Multi-Axis Finisher could theoretically be used as a High Feed End Mill, the two tools are not interchangeable.  A High Feed End Mill would not be the best choice for Multi-Axis Finishing, nor would a Lens Form Multi-Axis Finisher be our first recommendation for feed milling.
Do I need special software to program Multi-Axis Finishers?
Yes. A number of years ago, there were only a few CAM software packages that supported the programming of these specific forms. Nowadays, most CAM software providers have some degree of support for this method. Two of the first CAM software offerings to support this were MasterCAM and Hypermill, though many additional options exist today.
Why haven’t I heard of Multi-Axis Finishers Until Now?
In the grand scheme of things, Multi-Axis Finishers provide a very new approach to finishing, having been developed within the last handful of years.  Similar to High Efficiency Milling, these tools offer a new technique to approach your workpiece, offering increased efficiency and reduced cycle times.  Compared to the history of milling, modern tool manufacturing and CAM software have only just become able to program these unique forms.  Multi-axis finishers are positioned to revolutionize the world of finishing.
For more information on Multi-Axis Finishers, visit Multi-Axis Finishers: The Key to Amazing Surface Finish.
https://www.harveyperformance.com/wp-content/uploads/2024/03/Featured-Image-Multi-Axis-Finishers-QA.jpg 525 1400 Tom Pyle http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Tom Pyle2024-03-29 10:27:012024-11-07 16:12:11Multi-Axis Finisher Q&A
August 25, 2022/35 Comments/in CNC Machining, Drilling, Drilling & Holemaking, Harvey Tool, Holemaking, Machining Techniques, Milling, Titan USA, Tool Selection, Troubleshooting Tips/by Tom Pyle
Drilling an ultra-precise hole can be tough. Material behavior, surface irregularities, and drill point geometry can all be factors leading to inaccurate holes. A Spot Drill, if used properly, will eliminate the chance of drill walking and will help to ensure a more accurate final product.
Choosing a Spot Drill
Ideally, the center of a carbide drill should always be the first point to contact your part. Therefore, a spotting drill should have a slightly larger point angle than that of your drill. Common drill point angles range from 118° to 140° and larger. Shallower drill angles are better suited to harder materials like steels due to increased engagement on the cutting edges. Aluminums can also benefit from these shallower angles through increased drill life. While these drills wear less and more evenly, they are more prone to walking, therefore creating a need for a proper high performance spot drill in a shallow angle to best match the chosen drill.
Five Valor holemaking high performance spot drills displayed on top of a workpiece with a purple product packaging container in front
If a spotting drill with a smaller point angle than your drill is used, your drill may be damaged due to shock loading when the outer portion of its cutting surface contacts the workpiece before the center. Using a drill angle equal to the drill angle is also an acceptable situation. Figure 1 illustrates the desired effect. On the left, a drill is entering a previously drilled spot with a slightly larger angle than its point. On the right, a drill is approaching an area with an angle that is far too small for its point.
Proper Spot Angle Diagram
Marking Your Spot
A Spotting Drill’s purpose is to create a small divot to correctly locate the center of a drill when initiating a plunge. However, some machinists choose to use these tools for a different reason – using it to chamfer the top of drilled holes. By leaving a chamfer, screw heads sit flush with the part once inserted.
Spot Drill
What Happens if I Use a Spot Drill with an Improper Angle?
Using a larger angle drill will allow the drill to find the correct location by guiding the tip of the drill to the center. If the outer diameter of a carbide drill were to contact the workpiece first, the tool could chip. This would damage the workpiece and result in a defective tool. If the two flutes of the drill were slightly different from one another, one could come into contact before the other. This could lead to an inaccurate hole, and even counteract the purpose of spot drilling in the first place.
Avoiding CNC Drill Walking With a Spotting Drill
Few CNC machining applications demand precision like drilling. The diameter hole size, hole depth, part location, and finish are all important and provide little recourse if not up to specifications. That said, accuracy is paramount – and nothing leads to inaccurate final parts faster than drill walking, or the inadvertent straying from a drill’s intended location during the machining process. So how does drill walking occur, and how can one prevent it?
To understand drill walking, think about the act of striking a nail with a hammer, into a piece of wood. Firm contact to a sharp nail into an appropriate wood surface can result in an accurate, straight impact. But if other variables come into play – an uneven surface, a dull nail, an improper impact – that nail could enter a material at an angle, at an inaccurate location, or not at all. With CNC Drilling, the drill is obviously a critical element to a successful operation – a sharp, unworn cutting tool – when used properly, will go a long way toward an efficient and accurate final part.
To mitigate any variables working against you, such as an uneven part surface or a slightly used drill, a simple way to avoid “walking” is to utilize a Spotting Drill. This tool is engineered to leave a divot on the face of the part for a drill to engage during the holemaking process, keeping it properly aligned to avoid a drill from slipping off course.
When Won’t a Spot Drill Work for My Application?
When drilling into an extremely irregular surface, such as the side of a cylinder or an inclined plane, this tool may not be sufficient to keep holes in the correct position. For these applications, flat bottom versions or Flat Bottom Counterbores may be needed to creating accurate features.
Harvey tool spot drill zoomed in on the tip of the drill
Harvey Tool Spot Drill
https://www.harveyperformance.com/wp-content/uploads/2017/03/Feature-Image-Spotting-Drills-IMG.jpg 525 1400 Tom Pyle http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Tom Pyle2022-08-25 10:52:002023-10-18 08:19:12Spot Drilling: The First Step to Precision Drilling
Understanding Micro 100 Micro-Quik Tool Holders
July 19, 2021/0 Comments/in Large Featured, Machining 101, Machining Techniques, Micro 100, Tool Selection, Turning/by Harvey Performance Company
Did you know that, along with supplying the machining industry with premier turning tools, Micro 100 also fully stocks tool holders for its proprietary Micro-Quik Quick Change Tool Holder System? In fact, Micro 100’s Spring 2021 Product Catalog introduced new “headless” style tool holders, which are revolutionizing the machine setup process for turning operations.
This “In the Loupe” guide is designed to provide you with insight for navigating Micro 100’s offering, and to help you select the optimal holder style for your operation.
Micro 100 ad showing four different tool holders
Understanding Micro 100’s Micro-Quik
Micro 100’s Micro-Quik is unlike any other tool change system you may have seen from other tool manufacturers because of its incredible axial and radial repeatability and its ease of use. This foolproof system delivers impressive repeatability, tip-to-tip consistency, and part-to-part accuracy, all the while resulting in tool changes that are 90 % faster than conventional methods.
In all, a tool change that would regularly take more than 5 minutes is accomplished in fewer than 30 seconds.
Micro 100 Quick Change Tool Holder Selection
Straight Style, Headless Tool Holders
When using a straight style tool holder, you will enjoy significantly enhanced versatility during the machine set up process. These holders are engineered specifically for use in any Swiss, standard lathe, or multi-function lathe, and allow for adjustable holder depth in a tooling block. Radial coolant access ports provide easier access to coolant and the ability to utilize coolant through functionality in tooling blocks that share a static and live tool function, and cannot be plumbed through the back of the holder. Further, their headless design allows for installation through the backside of the tooling block in machines where the work envelope is limited, allowing for a simplified installation process.
Created by Harvey Performance Company Application Engineers, the following videos outline the simple process for inserting each style of Micro 100 Straight Tool Holder into a tooling block.
Micro 100 Straight Holder, Plumbed Style (QTS / QTSL)
In the video, you’ll notice that the first step is to place your Micro-Quik tool in this quick change holder, and align it with the locating pin. Then, tighten the locating and locking screw into the whistle notch. This forces the tool against the locking pin, and allows for repeatable accuracy, every time. From there, the quick change tool holder can be installed as a unit into a tooling block. When desired tool position is achieved, set screws can be tightened to lock the holder in place.
Micro 100 Straight Holder, Plumbed & Ported Style (QTSP / QTSPL)
This unique Micro 100 quick change tool holder style is plumbed and ported, allowing for enhanced versatility and coolant delivery efficiency. The setup process using this style of holder is also simple. First, place your Micro 100 quick change tool into the holder, and align it with the locating pin. From there, tighten the locating and locking screw into the whistle notch, forcing the tool against the locating pin and allowing for repeatable accuracy, every time. When plumbed coolant is being used, remove the plumbed plug in the back of the holder, and connect the appropriate coolant adapter and line. Then, the holder can be installed as a unit into the tooling block and locked into place with set screws.
When using ported coolant, make sure that the coolant plug in the back of the holder is tightly installed. Then, be sure to only use one of the radial ports. Simply plug the two that aren’t in use. Install the provided porting adapter to allow for coolant access. Porting options allow for coolant capabilities in machine areas where coolant is not easily accessible.
Headed Tool Holders
headed quick change tool holder
Micro 100’s original quick change tool holder for its Micro-Quik system, this style of tool holder for lathe applications features a unique “3 point” locking and locating system to ensure repeatability. When conducting a tool change with this tool holder style, you must follow a simple, 3-step process:
  1. Loosen the tool holder’s set screw
  2. Remove the used tool from the holder
  3. Insert the new tool and retighten the set screw
These headed holders are plumbed through the back of the holder for NPT coolant connection and are available in standard length and long length styles.
Try Micro 100’s “Headless” Tool Holders for Incredible Flexibility
Double-Ended Modular Tool Holder System
double ended quick change tool holder
For twin spindle and Y-axis tooling block locations, Micro 100 fully stocks a double-ended modular system. Similar to its single-ended counterparts, this modular is headless, meaning it enhances machine access during the tool block installation process, and the holder depth can be adjusted while in the block. Because this system is double-ended, however, there is obviously no plumbed coolant option through the end of the tool. Instead, coolant is delivered via an external coolant port, the adapter for which is included in the purchase of the modular system. Right hand and left hand tool holders are designed so the set screws are facing the operator for easy access. Both right and left hand styles are designed for right hand turning.
Enjoy Quick Change Tool Holding Confidence & Ease of Use
When opting for a quick change system, machinists long for simplicity, versatility, and consistency. Though many manufacturers have a system of their own, Micro 100’s Micro-Quik sets itself apart with axial and radial repeatability, and tip-to-tip consistency. Further, Micro 100 fully stocks several quick change tool holder options, allowing a machinist to select the style that best fits their application.
Micro100 also manufactures and stocks a wide variety of boring tools for the Micro-Quik. Click here to learn more.
For more information on selecting the appropriate quick change tool holder for your job, view our selection chart or call an experienced Micro 100 technical engineer at 800-421-8065.
quick change tool holder selection chart for Micro100
https://www.harveyperformance.com/wp-content/uploads/2021/07/Featured-Image-Quick-Change-Holders-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2021-07-19 11:28:002025-11-20 09:49:56Understanding Micro 100 Micro-Quik Tool Holders
The 3 Critical Factors of Turning Speeds and Feeds
May 13, 2021/4 Comments/in Machining 101, Machining Techniques, Micro 100, Small Featured, Turning/by Harvey Performance Company
Many factors come into play when determining a proper turning speeds and feeds and depth of cut strategy for turning operations. While three of these factors – the ones we deemed to be among the most critical – are listed below, please note that there are many other considerations that are not listed, but that are also important. For instance, safety should always be the main focus of any machining operation, as improper cutting tool parameters can test a machine’s limits, resulting in an accident that can potentially cause significant bodily harm.
Machine condition, type, capabilities, and set-up are all significantly important to an overall successful turning operation, as is turning tool and holder selection.
Turning Speeds and Feeds Factor 1: Machine Condition
The condition of your machine should always be considered prior to beginning a machining operation on a lathe. Older machines that have been used for production operations where hard or abrasive materials are machined tend to have a large amount of backlash, or wear, on the machine’s mechanical parts. This can cause it to produce less than optimal result and may require that a tooling manufacturer’s recommended speeds and feeds parameters need to be dialed back a bit, as to not run the machine more aggressively than it can handle.
turning machine engaging with workpiece
Factor 2: Machine Type and Capabilities
Before dialing in turning speeds and feeds, one must understand their machine type and its capabilities. Machines are programmed differently, depending on the type of turning center being used: CNC Lathe or Manual Lathe.
CNC Lathe Turning Centers
With this type of machine, the part and tool have the ability to be set in motion.
CNC lathe turning centers can be programmed as a G96 (constant surface footage) or G97 (constant RPM). With this type of machine, the maximum allowable RPM can be programmed using a G50 with an S command. For example, inputting a G50 S3000 into your CNC program would limit the maximum RPM to 3,000. Further, with CNC Lathe Turning Centers, the feed rate is programmable and can be changed at different positions or locations within a part program.
Manual Lathe Turning Centers
With this type of machine, only the part is in motion, while the tool remains immobile.
For manual lathe turning centers, parameters are programmed a bit differently. Here, the spindle speed is set at a constant RPM, and normally remains unchanged throughout the machining operation. Obviously, this puts more onus on a machinist to get speed correct, as an operation can quickly be derailed if RPM parameters are not optimal for a job. Like with CNC lathe turning centers, though, understanding your machine’s horsepower and maximum feed rate is critical.
Factor 3: Machine Set-Up
image demonstrating proper tool setup beside depiction of excessive tool stickout
Excessive Tool Stickout. Digital Image, Hass Automation. https://www.haascnc.com/service/troubleshooting-and-how-to/troubleshooting/lathe-chatter—troubleshooting.html
Machining Conditions
When factoring in your machine set-up, machining conditions must be considered. Below are some ideal conditions to strive for, as well as some suboptimal machining conditions to avoid for dialing in proper turning speeds and feeds.
Ideal Machining Conditions for Turning Applications
  • The workpiece clamping or fixture is in optimal condition, and the workpiece overhang is minimized to improve rigidity.
  • Coolant delivery systems are in place to aid in the evacuation of chips from a part and help control heat generation.
Suboptimal Machining Conditions for Turning Applications
  • Utilizing turning tools that are extended for reach purposes, when not necessary, causing an increased amount of tool deflection and sacrificing the rigidity of the machining operations.
  • The workpiece clamping or fixturing is aged, ineffective, and in poor condition.
  • Coolant delivery systems are missing, or are ineffective
  • Machine does not feature any guarding or enclosures, resulting in safety concerns.
Cutting Tool & Tool Holder Selection
As is always the case, cutting tool and tool holder selection are pivotal. Not all turning tool manufacturers are the same, either. The best machinists develop longstanding relationships with tooling manufacturers, and are able to depend on their input and recommendations. Micro 100, for example, has manufactured the industry’s highest quality turning tools for more than 50 years. Further, its tool holder offering includes multiple unique styles, allowing machinists to determine the product that’s best for them.
lathe tool holder next to micro 100 tool product packaging
Pro Tip: Be sure to take into consideration the machine’s horsepower and maximum feed rate when determining running parameters.
Bonus: Common Turning Speeds and Feeds Application Terminology
Vc= Cutting Speed
n= Spindle Speed
Ap=Depth of Cut
Q= Metal Removal Rate
G94 Feedrate IPM (Inches Per Minute)
G95 Feedrate IPR (Inches Per Revolution)
G96 CSS (Constant Surface Speed)
G97 Constant RPM (Revolutions Per Minute)
https://www.harveyperformance.com/wp-content/uploads/2021/05/turning-speeds.jpg 370 987 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2021-05-13 15:54:582023-09-27 10:45:04The 3 Critical Factors of Turning Speeds and Feeds
How to Optimize Miniature End Mill Performance
July 1, 2020/1 Comment/in Harvey Tool, How-To's, Machining Techniques, Milling, Milling/by Robert Keever
 The machining industry generally considers micromachining and miniature end mills to be any end mill with a diameter under 1/8 of an inch. This is also often the point where tolerances must be held to a tighter window. Because the diameter of a tool is directly related to the strength of a tool, miniature end mills are considerably weaker than their larger counterparts, and therefore, lack of strength must be accounted for when micromachining. If you are using these tools in a repetitive application, then optimization of this process is key.
Size comparison chart with square miniature end mill, ant leg, human hair, and grains of salt
Size Comparison for Harvey Tool’s #13901 Square Miniature End Mill
Key Cutting Differences Between Conventional and Miniature End Mills
Runout
Runout during an operation has a much greater effect on miniature tools, as even a very small amount can have a large impact on the tool engagement and cutting forces. Runout causes the cutting forces to increase due to the uneven engagement of the flutes, prompting some flutes to wear faster than others in conventional tools, and breakage in miniature tools. Tool vibration also impacts the tool life, as the intermittent impacts can cause the tool to chip or, in the case of miniature tools, break. It is extremely important to check the runout of a setup before starting an operation. The example below demonstrates how much of a difference .001” of runout is between a .500” diameter tool and a .031” diameter tool.
chart comparing tool diameter for runout in micromachining with miniature end mills
The runout of an operation should not exceed 2% of the tool diameter. Excess runout will lead to a poor surface finish.
Chip Thickness
The ratio between the chip thickness and the edge radius (the edge prep) is much smaller for miniature tools. This phenomena is sometimes called “the size effect” and often leads to an error in the prediction of cutting forces. When the chip thickness-to-edge radius ratio is smaller, the cutter will be more or less ploughing the material rather than shearing it. This ploughing effect is essentially due to the negative rake angle created by the edge radius when cutting a chip with a small thickness.
If this thickness is less than a certain value (this value depends of the tool being used), the material will squeeze underneath the tool. Once the tool passes and there is no chip formation, part of the plowed material recovers elastically. This elastic recovery causes there to be higher cutting forces and friction due to the increased contact area between the tool and the workpiece. These two factors ultimately lead to a greater amount of tool wear and surface roughness.
chart of edge radius in relation to chip thickness for micromachining
Figure 1: (A) Miniature tool operation where the edge radius is greater than the chip thickness (B) Conventional operation where the edge radius is small than the chip thickness
Tool Deflection in Conventional vs. Micromachining Applications
Tool deflection has a much greater impact on the formation of chips and accuracy of the operation in micromachining operations, when compared to conventional operations. Cutting forces concentrated on the side of the tool cause it to bend in the direction opposite the feed. The magnitude of this deflection depends upon the rigidity of the tool and its distance extended from the spindle. Small diameter tools are inherently less stiff compared to larger diameter tools because they have much less material holding them in place during the operation. In theory, doubling the length sticking out of the holder will result in 8 times more deflection. Doubling the diameter of an end mill it will result in 16 times less deflection. If a miniature cutting tool breaks on the first pass, it is most likely due to the deflection force overcoming the strength of the carbide. Here are some ways you can minimize tool deflection.
Workpiece Homogeny
Workpiece homogeny becomes a questionable factor with decreasing tool diameter. This means that a material may not have uniform properties at an exceptionally small scale due to a number of factors, such as container surfaces, insoluble impurities, grain boundaries, and dislocations. This assumption is generally saved for tools that have a cutter diameter below .020”, as the cutting system needs to be extremely small in order for the homogeny of the microstructure of the material to be called into question.
Surface Finish
Micromachining may result in an increased amount of burrs and surface roughness when compared to conventional machining. In milling, burring increases as feed increases, and decreases as speed increases. During a machining operation, chips are created by the compression and shearing of the workpiece material along the primary shear zone. This shear zone can be seen in Figure 2 below. As stated before, the chip thickness-to-edge radius ratio is much higher in miniature applications. Therefore, plastic and elastic deformation zones are created during cutting and are located adjacent to the primary shear zone (Figure 2a). Consequently, when the cutting edge is close to the border of the workpiece, the elastic zone also reaches this border (Figure 2b). Plastic deformation spreads into this area as the cutting edge advances, and more plastic deformation forms at the border due to the connecting elastic deformation zones (Figure 2c). A permanent burr begins to form when the plastic deformation zones connect (Figure 2d) and are expanded once a chip cracks along the slip line (Figure 2e). When the chips finally break off from the edge of the workpiece, a burr is left behind (Figure 2f).
burr formation mechanism using a miniature end mill
Figure 2: Burr formation mechanism using a miniature end mill
Tool Path Best Practices for Miniature End Mills
Because of the fragility of miniature tools, the tool path must be programmed in such a way as to avoid a sudden amount of cutting force, as well as permit the distribution of cutting forces along multiple axes. For these reasons, the following practices should be considered when writing a program for a miniature tool path:
Ramping Into a Part
Circular ramping is the best practice for moving down axially into a part, as it evenly distributes cutting forces along the x, y, and z planes. If you have to move into a part radially at a certain depth of cut, consider an arching tool path as this gradually loads cutting forces onto the tool instead of all at once.
Micromachining in Circular Paths
You should not use the same speeds and feed for a circular path as you would for a linear path. This is because of an effect called compounded angular velocity. Each tooth on a cutting tool has its own angular velocity when it is active in the spindle. When a circular tool path is used, another angular velocity component is added to the system and, therefore, the teeth on the outer portion of tool path are traveling at a substantially different speed than expected. The feed of the tool must be adjusted depending on whether it is an internal or external circular operation. To find out how to adjust your feed, check out this article on running in circles.
Slotting with a Miniature End Mill
Do not approach a miniature slot the same way as you would a larger slot. With a miniature slot, you want as many flutes on the tool as possible, as this increases the rigidity of the tool through a larger core. This decreases the possibility of the tool breaking due to deflection. Because there is less room for chips to evacuate with a higher number of flutes, the axial engagement must be decreased. With larger diameter tools you may be stepping down 50% – 100% of the tool diameter. But when using miniature end mills with a higher flute count, only step down between 5% – 15%, depending on the size of the diameter and risk of deflection. The feed rate should be increased to compensate for the decreased axial engagement. The feed can be increased even high when using a ball nose end mill as chip thinning occurs at these light depths of cut and begins to act like a high feed mill.
Slowing Down Your Feed Around Corners
Corners of a part create an additional amount of cutting forces as more of the tool becomes engaged with the part. For this reason it is beneficial to slow down your feed when machining around corners to gradually introduce the tool to these forces.
Climb Milling vs. Conventional Milling in Micromachining Applications
This is somewhat of a tricky question to answer when it comes to micromachining. Climb milling should be utilized whenever a quality surface finish is called for on the part print. This type of tool path ultimately leads to more predictable/lower cutting forces and therefore higher quality surface finish. In climb milling, the cutter engages the maximum chip thickness at the beginning of the cut, giving it a tendency to push away from the workpiece. This can potentially cause chatter issues if the setup does not have enough rigidity.  In conventional milling, as the cutter rotates back into the cut it pulls itself into the material and increases cutting forces. Conventional milling should be utilized for parts with long thin walls as well as delicate operations.
Combined Roughing and Finishing Operations
These operations should be considered when micromachining tall thin walled parts as in some cases there is not sufficient support for the part for a finishing pass.
Helpful Tips for Achieving Successful Micromachining Operations With Miniature End Mills
Try to minimize runout and deflection as much as possible when micromachining with miniature end mills. This can be achieved by using a shrink-fit or press-fit tool holder. Maximize the amount of shank contact with the collet while minimizing the amount of stick-out during an operation. Double check your print and make sure that you have the largest possible end mill because bigger tools mean less deflection.
  • Choose an appropriate depth of cut so that the chip thickness to edge radius ratio is not too small as this will cause a ploughing effect.
  • If possible, test the hardness of the workpiece before machining to confirm the mechanical properties of the material advertised by the vender. This gives the operator an idea of the quality of the material.
  • Use a coated tool if possible when working in ferrous materials due to the excess amount of heat that is generated when machining these types of metals. Tool coatings can increase tool life between 30%-200% and allows for higher speeds, which is key in micro-machining.
  • Consider using a support material to control the advent of burrs during a micromachining application. The support material is deposited on the workpiece surface to provide auxiliary support force as well as increase the stiffness of the original edge of the workpiece. During the operation, the support material burrs and is plastically deformed rather than the workpiece.
  • Use flood coolant to lower cutting forces and a greater surface finish.
  • Scrutinize the tool path that is to be applied as a few adjustments can go a long way in extending the life of a miniature tool.
  • Double-check tool geometry to make sure it is appropriate for the material you are machining. When available, use variable pitch and variable helix tools as this will reduce harmonics at the exceptionally high RPMs that miniature tools are typically run at.
side-by-side view of two end mills comparing variable pitch versus non-variable pitch
Figure 3: Variable pitch tool (yellow) vs. a non-variable pitch tool (black)
https://www.harveyperformance.com/wp-content/uploads/2020/07/Feature-Image-Machining-with-Miniature-End-Mills-IMG-1.jpg 525 1400 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2020-07-01 10:43:432025-11-12 15:59:31How to Optimize Miniature End Mill Performance
Page 1 of 6123›»
