What is a Drop-Hole?
graphic showing holes with and without drop hole allowance
5 unique machining operations with drop hole allowance
When Not to Drop Hole
machining operations without drop hole allowance
Drop-Hole Placement
proper placement of hole when using drop hole allowance
graphic showing the use of a drop hole for o-ring seals between high and low pressure areas
What to Know About Helical Solution’s Zplus Coating
zplus coated helical chipbreaker end mill
zplus coating specification chart
Large Production Runs
3 flute corner radius end mill for aluminum
Finishing Applications
Understanding the Two Styles
Chipbreaker End Mills
chipbreaker end mill standing straight up
Knuckle Roughers
straight up black knuckle rougher end mill
Confidently Select Your Next Thread Mill
Thread Mill Product Offering
Single Form
single form harvey tool thread mill
  1. Ground Flat – Instead of a sharp point these tools have a ground flat to help ensure long tool life.
  2. Eccentric Relief – Gives the cutting edges extra strength for the high feeds at relatively low RPMs required for harder materials.
  3. AlTiN Nano Coating – Allows for superior heat resistance.
single form thread mill for hardened steels
Tri-Form
tri form thread mill from harvey tool
Multi-Form
coolant through multi form thread mill
Long Flute
long flute harvey tool thread mill
N.P.T. Multi-Form
npt thread mill from harvey tool
The first step of any machining job is selecting the correct end mill for your material and application. However, this doesn’t mean that there should not be an adequate amount of legwork done beforehand to ensure the right decision on a tool is being made. Harvey Tool, Helical Solutions, Titan USA, and Corehog have thousands of different tools for different operations – a vast selection which, if unprepared – can easily result in selecting a tool that’s not the best for your job. To start your preparation, answer the 5 Questions to Ask Before Selecting an End Mill to help you quickly narrow down your selection and better understand the perfect tool you require.
end mill being fed coolant cutting into a workpiece to extend tool life
Another factor to consider is the coating composition on a tool. Harvey Tool and Helical Solutions offer many varieties of tool coatings for different materials. Some coatings increase lubricity, slowing tool wear, while others increase the hardness and abrasion resistance of the tool. Not all coatings increase your tool’s life in every material, however. Be wary of coatings that don’t perform well in your part’s material – such as the use of AlTiN coating in Aluminum (Both coating and material are aluminum-based and have a high affinity for each other, which can cause built-up edge and result in chip evacuation problems).
three different end mills in tool holders
massive helical end mill in machinists hand
Harvey Performance Company offers the Machining Advisor Pro application, a free, cutting-edge resource that generates custom running parameters for optimized machining with all of Helical Solutions’ and Harvey Tool’s products.
machining advisor pro graphic for pc, laptops, and other devices
Understanding the Distinctions
harvey tool marking cutters ad
harvey tool doubled ended engraving cutter
Harvey Tool Product Offering
types of cnc engraver tips, pointed, radiused, and tipped-off
Choosing the Right Tool
heat generation in standard versus hem milling and their associated depths of cut
Chip Thinning Awareness
infographic showcasing chip thinning in relation to step over
Consider Climb Milling
infographic showing climb versus conventional milling in feed path and end mill direction
CNC Workholding Devices
Fixtures and Jigs
The 4 Fixture Bodies
cnc tombstone work holding fixture body
Locators
cnc workholding showcasing a workpiece in v-locator
Supports
cnc material support with parallel supports and rest buttons
Clamps
cnc workholding clamps
Hydraulic Workholding Systems
Pneumatic clamps
Key Guidelines to Follow
Ensure Proper Tolerancing
Bottom Line
  • Traditional Roughing
  • Slotting
  • Finishing
  • Contouring
  • Plunging
  • High Efficiency Milling
Material:
Application:
graphic showcasing the tool face of end mills from 2 to 12 flutes
Length of Cut & Reach
Tool Profile
end mill graphic with dimension callouts
  • Prolonged Tool life
  • Improved Chip Evacuation
multiple end mills after being coated, zoomed in on cutting faces
multi-form threadmill in holder
What is a Thread?
graphic showcasing a thread with all associated dimensional callouts
Thread Designations
Metric Thread Designations
M12 x 1.75 – 4h – LH
UN Thread Designations
¾ 10 UNC 2A LH
ACME Thread Designations
A 1 025 20-X
How Are Threads Measured?
Thread Milling Considerations
There is no substitute for adequate tooling. To avoid tool failure and machining mishaps, opt for a quality manufacturer for High Performance Drills for your starter holes, as well as for your thread milling solutions. Harvey Tool fully stocks several types of threadmills, including Single Form, Tri-Form, and Multi-Form Thread Milling Cutters. In addition, the 60° Double Angle Shank Cutter can be used for thread milling. Titan USA’s threadmill lineup features both Standard and Coolant Fed Internal/External Threadmills as well as NPT/NPTF Threadmills and Metric Mills.
threads being spun with a tool onto a workpiece
Image Courtesy of  @Avantmfg
3. Ensure You’re Comfortable With Your Tool Path
threadmill over a series of completed threaded holes
Titan USA Threadmill
Just looking at a thread milling tool can be confusing – it is sometimes hard to conceptualize how these tools are able to get the job done. But with proper understanding of call, methods, and best practices, machinists can feel confident when beginning their operation.
