Machining Precious Metals
About the Elements
- Ruthenium (Ru)
- Rhodium (Rh)
- Palladium (Pd)
- Silver (Ag)
- Osmium (Os)
- Iridium (Ir)
- Platinum (Pt)
- Gold (Au)
Tools for Precious Metals
Speeds and Feeds charts:
