Drill/End Mills
drill mills
drill mill operations
Undercutting End Mills
undercutting end mills
Double Angle Shank Cutters
double angle shank cutters
Flat Bottom Tools
flat bottom tools
flat bottom tools
Adjustable Chamfer Cutters
adjustable chamfer cutters
chamfer cutter inserts
Milling Machines vs. Lathe Machines
Most modern manufacturing centers have both milling machines and lathe machines. Each machine follows the same machining principle, known as subtractive machining, where you begin with a block of material and then shape that material into the desired specifications. How the part is actually shaped is the key difference between the two machines. Understanding the differences in more depth will help in putting the right part in the right machine to maximize their capabilities.
cnc lathe
An Example of a Lathe Machine
cnc milling machine
An Example of a Milling Machine
Operation
The major difference between a milling machine and a lathe machine is the relationship of the workpiece and the tool.
Lathe Machines
In a lathe, the workpiece that is being machined spins about it’s axis, while the cutting tool does not. This is referred to as “turning”, and is effective for creating cylindrical parts. Common operations done on a lathe include drilling, boring, threading, ID and OD grooving, and parting. When looking to create quick, repeatable, and symmetrical cylindrical parts, the lathe machine is the best choice.
cnc lathe
Milling Machines
The opposite is true for milling machines. The tool in a milling machine rotates about its axis, while the workpiece does not. This allows the tool to approach the workpiece in many different orientations that more intricate and complex parts demand. If you can program it, you can make it in a milling machine as long as you have the proper clearance and choose the proper tooling.
milling machines
Best Practice
The best reason to use a milling machine for an upcoming project is the versatility. The tooling options for a milling machine are endless, with hundreds of available specialty cutting tools and various styles of end mills which make sure you are covered from start to finish on each job. A mill can also cut more complex pieces than a lathe. For example, it would impossible to efficiently machine something like an intake manifold for an engine on a lathe. For intricate parts like that, a milling machine would be required for successful machining.
While lathe machines are more limited in use than a milling machine, they are superior for cylindrical parts. While a mill can make the same cuts that a lathe does, it may need multiple setups to create the same part. When continuous production of cylindrical parts is necessary, a lathe will outperform the mill and increase both performance and efficiency.
The Anatomy of an End Mill
Flutes
end mill flute patterns
End Mill Profiles
Square Profile End Mills
Ball Profile End Mills
end mill cutter diameter
Shank Diameter
end mill neck
End Mill Helix Angle
helix angle
Pitch
variable pitch
Speeds and Feeds 101
HEM Guidebook Ad
speeds and feeds formula
Material Removal Rate
speeds and feeds
Speeds and Feeds In Practice
hardness chart
speeds and feeds
Earn an Immediate Boost to Shop Efficiency: Download the HEM Guidebook Today
Spindle Speed Cap
Effective Cutter Diameter
cutter diameter calculation
Non-linear Path
non-linear path
adjusted internal feed
adjusted external feed
Built-In CAM Applications
Importance of Tooling to HEM
Best Tools for HEM:
Titanium Varieties
Titanium 6AL4V
Titanium Concerns
Workholding
Heat Generation
cutting tools for titanium
Galling and Built-Up Edge
Titanium Solutions
Tooling Solutions
machining titanium
Pre-Drilled Hole
tool entry predrill
Helical Interpolation
helical interpolation
Ramping-In
ramping
Hard/Ferrous Materials: 1°-3°
arching with end mill
Straight Plunge
tool entry
Straight Tool Entry
tool entry
Roll-In Tool Entry
tool entry
Defining Tool Wear
tool wear
tool wear
Abrasive Wear
tool wear
Chipping
tool wear
Thermal Cracking
end mill thermal cracking
Fracture
end mill fracture
ball nose
Shop Harvey Tool’s Vast Selection of Ball Profile End Mills – Click Here to Get Started
ball nose effective cutting diameter chart
ball nose cutting diameter calculation
ball nose compensated speed calculation
KEY
ADOC = Axial Depth of Cut
D = Cutting Diameter
R = Tool Radius (Dia./2)
RDOC = Radial Depth of Cut
SFM = Surface Feet per Minute
Sc = Compensated Speed
ball nose milling with tilt angle
KEY
6 Uses of Double Angle Shank Cutters
Thread Milling
thread milling
Chamfering
chamfering with Double Angle Shank Cutter
Back Chamfering
back chamfering
Machining V-Grooves
machining v-grooves
Deburring
deburring with Double Angle Shank Cutter
Countersinking
Countersinking a part  is done so a screw, nail, or bolt is able to sit flush with the part surface. Using specialty profile tooling can help enlarge the rim of a drilled hole and bevel the sides for a screw to sit accurately. A Double Angle Shank Cutter can also perform this operation by using the bottom portion of its cutting face.
Double Angle Shank Cutter for countersinking
