HEM Webinar Ad
Quick Definitions:
depth of cut
peripheral milling with roughing
slotting depth of cut
Traditional Strategy
  • Heavy RDOC
  • Light ADOC
  • Conservative Feed Rate
  • Light RDOC
  • Heavy ADOC
  • Increased Feed Rate
Click Here to Access Our Free Educational Webinar on High Efficiency Milling
depth of cut
Corner Engagement
corner engagement
Generating an inside part radius that matches the radius of the tool with a sweeping direction change is a more desirable approach for corner engagement. The smaller radial depths of cut (RDOC) in this example help to manage the angle of engagement, but at the final pass, the tool will still experience a very high engagement angle.  Common results of this approach will be chatter, tool deflection/breakage and poor surface finish.
corner engagement effective approach
Most Effective Approach For Corner Engagement (Figure 3)
corner engagement
Ramping to Success
ramping
What is Ramping?
circular and linear ramping
Benefits of Ramping
Ramping
conventional milling
Climb Milling (Figure 3)
climb milling
Cutting With Dovetails
Avoiding Tool Failure
dovetail cutters
nondrop-hole dovetail cutters
dovetail cutters with different neck diameters
microdovetailing with dovetail cutter
5. Failing to Climb Mill.
6. Improper Chip Flushing.
7. Giving the Job Away.
Harvey Tool’s Miniature High Performance Composite Drills are specifically designed with point geometry optimized for the unique properties of composite materials. Our Double Angle style is engineered to overcome common problems in layered composites and our Brad Point style is built to avoid the issues frequently experienced in fibrous composites.
Common Composite Problems
Drilling in composite materials is a unique challenge. There are a wide variety of regularly machined composites, each requiring different considerations and approaches. Overcome common composite holemaking problems by identifying and selecting the right tool for your job.
Defining Delamination
Delamination occurs when high drilling forces cause laminated layers to separate, yielding less structurally-sound parts. The more blunt a drill point is, the more force it will take to move through a part, increasing the chance of delamination.
Identifying Delamination
The separation of layers may be difficult to identify through visible scrutiny. Closely inspecting and testing the hole quality is ideal when looking for delamination.
Ideal Drill Choice
Double Angle Composite Drills
composite drills
Defining Uncut Fibers
Uncut fibers are largely caused by dull tooling. If a drill’s cutting edge is not sharp enough, fibers will remain uncut, frayed, or splintered, potentially ruining the part.
Identifying Uncut Fibers
Uncut fibers should be easily noticed: look for splintered or frayed fibers around the edges of your hole.
Ideal Drill Choice
Brad Point Composite Drills
composite drills
Defining Tear-Out
Rather than leaving uncut fibers hanging on to a workpiece, dull tools can also grab fibers and tear them out of the material altogether. This can leave voids in your material and cause damage to even greater areas of the workpiece.
Identifying Tear-Out
Tear-out can be more difficult to spot than uncut fibers. However, it is often seen as an area of material completely removed around the edge of a hole.
Ideal Drill Choice
Choose Your Tool
Harvey Tool’s new Composite Drills are engineered with point geometry optimized for fibrous and layered composite materials. Each design is specifically built to overcome common composite drilling challenges and achieve excellent results.
Avoid Delamination and Push-Out
composite drills Harvey
Harvey Tool’s Double Angle Composite Drills help combat delamination and push-out in layered composite materials with specialized point geometry. The primary 130° point angle allows the drill to efficiently engage laminated composites without lifting the top layer of material. The shallower secondary 60° point angle reduces the amount of force required to move the drill through the material, further reducing the probability of delamination. The higher shear angle also aids in reducing push-out at the back of the workpiece by more gradually breaking through the part.
Avoid Uncut Fibers and Tear Out
composite drills
Harvey Tool’s Brad Point Composite Drills are designed specifically for superior performance in fibrous materials. The trident-like brad point ensures that holes in fiber filled and reinforced materials come out clear and free of fraying. The outer points accurately score the outer diameter of drilled holes, eliminating uncut fibers, tear-out, and splintering.
For more information on Composite Drills and all of Harvey Tool’s new products, visit the Harvey Tool website.
Cutting Circular Tool Paths
Internal Circular Tool Paths
Circular Tool Paths
External Circular Tool Paths
Optimize Your Performance
Use Proper Tooling
To support the walls during thin wall milling, keep a wide-cross section behind it. We recommend utilizing a “stepped down” approach, which divides the total wall height to manageable depths while working each side of the wall. The Axial Depth of Cut (ADOC) dimension will vary depending on the material (and its hardness) being cut.
ADOC in thin wall milling
RDOC in thin wall milling
  • Climb milling will help to keep tool pressure to a minimum.
  • Manual vibration dampening and wall stabilization can be achieved by using thermoplastic compounds, or wax, which can be thermally removed.
  • The use of ultra-high performance tool paths can optimize tool performance.
Avoid Tool Deflection
tool deflection
progressive step drilling
Achieve Optimal Finish
Deep Cavity Milling
Mill to the Required Depth
Evacuate Chips Effectively
that must be avoided.
Deep Cavity Milling
Defining Chip Thinning
Chip Thickness
How Chip Thinning Occurs
radial chip thinning
IPT chip thinning formula
Lasting Benefits
