diamond tool coatings
Amorphous Diamond Coating
amorphous diamond coating
CVD Diamond Coating
Polycrystalline Diamond (PCD)
Coating Hardness & Thickness
Flute Styles
PCD Diamond end mill
PCD Ball End Mill
CVD Diamond end mill
CVD Ball End Mill
Proper Uses
Cut to the Point
Drill/End Mills
drill mills
drill mill operations
Undercutting End Mills
undercutting end mills
Double Angle Shank Cutters
double angle shank cutters
Flat Bottom Tools
flat bottom tools
flat bottom tools
Adjustable Chamfer Cutters
adjustable chamfer cutters
chamfer cutter inserts
High Precision Tools
hand deburring
cnc deburring
cnc deburring
Flat Bottom Drills
Flat Bottom Drill
Flat Bottom Drill Operations
Thin Plate Drilling
Crosshole Drilling
Angled Drilling
Half Hole Drilling
Flat Bottom Counterbore Operations
Bore & Finish Drilled Holes
Straighten Misaligned Holes
Remove Drill Points
Remove End Mill Dish
The Anatomy of an End Mill
Flutes
end mill flute patterns
End Mill Profiles
Square Profile End Mills
Ball Profile End Mills
end mill cutter diameter
Shank Diameter
end mill neck
End Mill Helix Angle
helix angle
Pitch
variable pitch
Keyseat Cutter Geometry
keyseat cutter geometry
Harvey Tool Keyseats
Harvey Tool Keyseat Geometries
Radial Depth of Cut
Understanding a keyseat cutter’s radial depth of cut is critical to choosing the correct tool, but understanding how it affects your tool path is necessary for optimal results. While it may be tempting to make a cut using a keyseat cutter’s maximum RDOC, this will result in increased stress on the tool, a worse finish, and potential catastrophic tool failure. It is almost always better to use a lighter depth of cut and make multiple passes (Figure 2).
keyseat cutter RDOC
Desired Slot Size
desired slot size
staggered toot
Having trouble finding the perfect keyseat for your job? Harvey Tool offers over 2,100 keyseat cutter options, with cutter diameters from 1/16” to 1-1/2” and cutter widths from .010” to ½”.
metal chips in cnc mill form chipbreaking
Helical Part No.33737
Material4340 Steel
ADOC2.545″
RDOC.125″
Speed2,800 RPM
Feed78 IPM
Why Flute Count Matters
Click Here to Get Started.
Tool Geometry Basics
flute count core
Material Considerations
end mill flute count
flute count
How to Avoid Composite Delamination With Compression Cutters
Using Compression Cutter End Mills in Composite Materials
compression cutters
