6 Uses of Double Angle Shank Cutters
June 20, 2017/1 Comment/in CNC Machining, Machining 101, Machining Techniques, Milling, Specialty Tools, Tool Geometry, Tool Selection/by Harvey Performance Company
Thread Milling
thread milling
Chamfering
chamfering with Double Angle Shank Cutter
Back Chamfering
back chamfering
Machining V-Grooves
machining v-grooves
Deburring
deburring with Double Angle Shank Cutter
Countersinking
Countersinking a part  is done so a screw, nail, or bolt is able to sit flush with the part surface. Using specialty profile tooling can help enlarge the rim of a drilled hole and bevel the sides for a screw to sit accurately. A Double Angle Shank Cutter can also perform this operation by using the bottom portion of its cutting face.
Double Angle Shank Cutter for countersinking
https://www.harveyperformance.com/wp-content/uploads/2017/06/Feature-Image-6-Uses-DASC.jpg 300 800 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-06-20 10:25:282024-11-07 13:59:176 Uses of Double Angle Shank Cutters
May 30, 2017/0 Comments/in CNC Machining, Machining 101, Machining Techniques, Tool Geometry, Tool Selection, Troubleshooting Tips/by Tom Pyle
tapered end mill straight versus tapered reach deflection
tapered reach end mill
Tapered Reach
following pros and cons:
• Increased tool strength
• Reduced tool deflection
• Less chatter, better finish
• Increased productivity
• Reduced clearance
tapered length of cut end mill
Tapered Length of Cut
infographic of ideal tapered end mill and standard end mill tool choices
https://www.harveyperformance.com/wp-content/uploads/2017/05/Feature-Image-Tapered-End-Mills-IMG.jpg 525 1400 Tom Pyle http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Tom Pyle2017-05-30 16:00:562023-10-12 08:49:26Increase Productivity With Tapered End Mills
April 27, 2017/8 Comments/in CNC Machining, Harvey Tool, Machining Techniques, Milling, Specialty Tools, Tool Selection, Troubleshooting Tips/by Harvey Performance Company
Cutting With Dovetails
Check our Harvey Tool’s Comprehensive Selection of Dovetail Cutters that Ship to You Today.
Avoiding Tool Failure
infographic examining drop hole allowance parameters with dovetails
nondrop-hole dovetail cutters
dovetail cutters with different neck diameters
microdovetailing with dovetail cutter
5. Failing to Climb Mill.
6. Improper Chip Flushing.
7. Giving the Job Away.
https://www.harveyperformance.com/wp-content/uploads/2017/04/Harvey_DovetailMistakes_Image.jpg 225 600 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-04-27 14:26:502024-02-12 10:42:50Dodging Dovetail Headaches: 7 Common Dovetail Mistakes
April 21, 2017/0 Comments/in CNC Machining, Composites, Drilling & Holemaking, Holemaking, Machining Techniques, Material Specific, Milling, Tool Selection/by Harvey Performance Company
Harvey Tool’s Miniature High Performance Composite Drills are specifically designed with point geometry optimized for the unique properties of composite materials. Our Double Angle style is engineered to overcome common problems in layered composites and our Brad Point style is built to avoid the issues frequently experienced in fibrous composites.
Common Composite Problems
Drilling in composite materials is a unique challenge. There are a wide variety of regularly machined composites, each requiring different considerations and approaches. Overcome common composite holemaking problems by identifying and selecting the right tool for your job.
Delamination
Defining Delamination
Delamination occurs when high drilling forces cause laminated layers to separate, yielding less structurally-sound parts. The more blunt a drill point is, the more force it will take to move through a part, increasing the chance of delamination.
Delamination and Push-Out
Identifying Delamination
The separation of layers may be difficult to identify through visible scrutiny. Closely inspecting and testing the hole quality is ideal when looking for delamination.
Ideal Drill Choice
Double Angle Composite Drills
Uncut Fibers
Defining Uncut Fibers
Uncut fibers are largely caused by dull tooling. If a drill’s cutting edge is not sharp enough, fibers will remain uncut, frayed, or splintered, potentially ruining the part.
Identifying Uncut Fibers
Uncut fibers should be easily noticed: look for splintered or frayed fibers around the edges of your hole.
Ideal Drill Choice
Brad Point Composite Drills
Tear-Out
Defining Tear-Out
Rather than leaving uncut fibers hanging on to a workpiece, dull tools can also grab fibers and tear them out of the material altogether. This can leave voids in your material and cause damage to even greater areas of the workpiece.
Tear Out
Identifying Tear-Out
Tear-out can be more difficult to spot than uncut fibers. However, it is often seen as an area of material completely removed around the edge of a hole.
Ideal Drill Choice
Choose Your Tool
Harvey Tool’s new Composite Drills are engineered with point geometry optimized for fibrous and layered composite materials. Each design is specifically built to overcome common composite drilling challenges and achieve excellent results.
Avoid Delamination and Push-Out
composite drills Harvey
v
Harvey Tool’s Double Angle Composite Drills help combat delamination and push-out in layered composite materials with specialized point geometry. The primary 130° point angle allows the drill to efficiently engage laminated composites without lifting the top layer of material. The shallower secondary 60° point angle reduces the amount of force required to move the drill through the material, further reducing the probability of delamination. The higher shear angle also aids in reducing push-out at the back of the workpiece by more gradually breaking through the part.
Avoid Uncut Fibers and Tear Out
composite drills
Harvey Tool’s Brad Point Composite Drills are designed specifically for superior performance in fibrous materials. The trident-like brad point ensures that holes in fiber filled and reinforced materials come out clear and free of fraying. The outer points accurately score the outer diameter of drilled holes, eliminating uncut fibers, tear-out, and splintering.
For more information on Composite Drills and all of Harvey Tool’s new products, visit the Harvey Tool website.
https://www.harveyperformance.com/wp-content/uploads/2017/04/Feature-Image-Composite-Holemaking-Challenges.jpg 525 1401 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-04-21 10:00:312024-11-06 13:16:28Overcoming Composite Holemaking Challenges
Selecting the Right Plastic Cutting End Mill
April 7, 2017/7 Comments/in CNC Machining, Harvey Tool, Material Specific, Plastics, Tool Information Guides, Tool Selection, Troubleshooting Tips/by Harvey Performance Company
three Harvey tool plastic cutting end mills
Choose Workholding Method
Chart of workholding parameters and their preferred selection to upcut or downcut as a result
Determine Heat Tolerance
The amount of heat generated should always be considered prior to any machining processes, but this is especially the case while working in plastics. While machining plastics, heat must be removed from the contact area between the tool and the workpiece quickly and efficiently to avoid melting and chip welding.
For plastics with a higher heat tolerance, a Two or Three Flute Plastic Cutting End Mill can be utilized. Because it has more cutting edges and allows for higher removal rates, its tool life is extended.
Chart of end mill flute count and their respective workpiece heat tolerance levels
The polymer arrangement in plastics can cause many burrs if the proper tool is not selected. Parts that require hand-deburring offline after the machining process can drain shop resources. A sharp cutting edge is needed to ensure that the plastic is sheared cleanly, reducing the occurrence of burrs. Three Flute Plastic Cutting End Mills can reduce or eliminate the need to hand-deburr a part. These tools employ an improved cutting action and rigidity due to the higher flute count. Their specialized end geometry reduces the circular end marks that are left behind from traditional metal cutting end mills, leaving a cleaner finish with minimal burrs.
Shop Harvey Tool Plastic Cutting End Mills Today
Flute Count Case Study
3 FLUTE PLASTIC FINISHER: A facing operation was performed on a separate acrylic piece with a specialized 3 Flute Plastic Finisher End Mill. The specialized cutting end left minimal swirling marks and resulted in a smoother finish.
Image of facing operation patterns from a standard 2 flute plastic cutter beside another image from a specialized 3 flute plastic finisher
Chart of plastic cutting end mills vs metal cutting end mills that compares values on their features
https://www.harveyperformance.com/wp-content/uploads/2017/04/Feature-Image-Plastic-Cutter-Selection-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-04-07 08:31:562023-09-21 13:29:01Selecting the Right Plastic Cutting End Mill
Page 7 of 7«‹567
