Complex parts require more than a single operation. Features such as contours, chamfers, engraved details, and precision holes often demand multiple tooling strategies working together throughout the machining process.
In the video below, watch a single component progress from a block of Ti-6Al-4V to a finished part through more than 10 machining applications, each supported by specialized Harvey Tool solutions.
Operations throughout the process utilize a range of tooling, including Variable Pitch End Mills for Titanium, Miniature Ball End Mills, Miniature Chamfer End Mills, High Performance Drills for Prehardened Steels, and Engraving Cutters.Each step demonstrates how selecting the right tool contributes to accuracy, surface finish, and overall part quality.
Explore the full range of solutions available in the 2026 Harvey Tool Catalog, featuring more than 31,000 miniature and specialty cutting tools designed to support even the most demanding applications.
View the 2026 Harvey Tool Catalog
Helical’s End Mills for Hardened Steels Geometry
February 6, 2025/0 Comments/in Tools In Action/by Harvey Performance Company
Check out the unique geometry of Helical’s End Mills for Hardened Steels.
Featuring variable pitch geometry, a massive core diameter, and premium Tplus coating, Helical’s End Mills for Hardended Steels have been meticulously tested to provide outstanding performance in hardened steels over 60 HRC with extensive testing in 62 HRC D2 tool steel.
Click Here to explore Helical’s End Mills for Hardened Steels
https://www.harveyperformance.com/wp-content/uploads/2025/02/Feature-Image-Hardened-Steel-Geometry.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2025-02-06 12:48:302025-02-06 12:50:00Helical’s End Mills for Hardened Steels Geometry
Customer Video: Helical’s 3 Flute End Mill in Aluminum
December 20, 2024/0 Comments/in Tools In Action/by Harvey Performance Company
Watch this great video from @go.manufacturing shared to @helicaltools Instagram, which features Helical’s 3 Flute 45° Helix Square End Mill for Aluminum in action.
“Sit back and enjoy the raw sights and sounds of a @helicaltools 1/4” endmill taking a .050” stepover cut through .900” of aluminum at 100 ipm. ✌️”
Designed for outstanding performance and accelerated material removal rates in aluminum and non-ferrous materials, this tool’s 45° high helix makes it ideal for finishing due to its high shear angle and cutting aggressiveness. In addition, the high helix and 3 flute design simultaneously create efficient chip evacuation and metal removal rates.
Click Here to explore the full Helical Solutions Material Specific End Mill Offering
Do you love machining? Us, too! Share your machining pictures and videos with us on Instagram at any Harvey Performance Company page: @harveytool, @helicaltools, @micro100, or @titan.usa. We’d love to share your work and give your shop a shout-out on In the Loupe!
https://www.harveyperformance.com/wp-content/uploads/2024/12/Featured-Image-Tools-in-Action-Go.Manufacturing-IMG.png 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2024-12-20 13:53:312024-12-20 13:53:33Customer Video: Helical’s 3 Flute End Mill in Aluminum
CoreHog’s Finishing Core Tools Cruising Through Nomex®
November 20, 2024/0 Comments/in Tools In Action/by Harvey Performance Company
Watch this video of CoreHog’s Medium Finishing Core Tools shear through Nomex® with ease!
Optimized for shaping and finishing smaller complex surfaces, bevels, and external radii of honeycomb core materials, this “assembly style” CNC tooling is comprised of different CoreHoggers and Coreslicers, each engineered for specific material densities to provide a customized machining experience.
Click Here to Explore CoreHog’s Full Offering of Honeycomb Core Tools
Do you love machining? Us, too! Share your machining pictures and videos with us on Instagram at any Harvey Performance Company page: @harveytool, @helicaltools, @micro100, @titan.usa, or @corehog. We’d love to share your work and give your shop a shout-out on In the Loupe!
https://www.harveyperformance.com/wp-content/uploads/2024/11/Feature-Image-Core-Finishing-Tool-Vid.png 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2024-11-20 12:32:522024-11-26 11:16:35CoreHog’s Finishing Core Tools Cruising Through Nomex®
August 25, 2023/0 Comments/in CNC Machining, CNC Machining Videos, Steels, Tools In Action/by Harvey Performance Company
Don Grandt, Harvey Performance Company National Application Engineer, met up with Jesse Trinque at the Mastercam Manufacturing Lab to demo some Helical Solutions End Mills and discuss Continuous Time In Cut (CTIC).
Continuous Time in Cut (CTIC) is the amount of time that a tool is engaged with a material. When an end mill is in a cut for too long, the friction can build and surface foot can be sacrificed, greatly affecting the performance and wear of a tool.
Check out this video to watch Jesse and Don test out how different levels of CTIC directly affect tool life and performance. This series of tests, which were facilitated by Mastercam, were conducted in Okuma’s GENOS M560-V, and utilized tool paths from Mastercam. For tooling, a standard ½” Helical Solutions HEV-6, a 6 flute, variable pitch end mill with a .03” corner radius, was used to machine 17-4 stainless steel.
All tests used the same cutting parameters, setup, material, and tool, with altered CTIC.
Take a Deeper Dive Into CTIC
Tune into this episode of In The Loupe TV to learn how you can manipulate Continuous Time In Cut (CTIC) and surface foot to reduce heat in your machining applications.
https://www.harveyperformance.com/wp-content/uploads/2023/08/featured-image-Mastercam-CTIC-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2023-08-25 11:10:362025-11-12 15:57:44Helical x Mastercam: Continuous Time in Cut (CTIC)
High Feed End Mill Roughing 4140 Steel With Helical
December 1, 2022/1 Comment/in Tools In Action/by Harvey Performance Company
Watch this video of Helical Solutions’ High Feed End Mill roughing out a 4140 steel part at 4,202 RPM, 429 IPM, and 550 SFM.
Engineered with a specialized end profile for optimal tool engagement and reduced cutting forces, this offering of Helical’s High Feed End Mills features tooling proven to achieve maximum feed rates in steels up to 45 Rc. Equipped with variable pitch geometry for decreased chatter and harmonics and Tplus coated for maximum performance in difficult-to-machine materials, these tools are engineered to impress you.
To learn more about High Feed End Mills, read In the Loupe’s “The Secret Mechanics of High Feed End Mills” and “5 Things to Know About Helical’s High Feed End Mills.”
Click Here to Explore Helical’s Full Offering of High Feed End Mills
https://www.harveyperformance.com/wp-content/uploads/2022/11/Feature-Image-Helical-High-Feed-Mill-Vid.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-12-01 13:48:502025-11-12 16:00:53High Feed End Mill Roughing 4140 Steel With Helical
Helical 5 Flute Chipbreaker Rougher for Steel
November 16, 2022/1 Comment/in Tools In Action/by Harvey Performance Company
Watch this video of Helical Solutions’ 5 Flute Variable Pitch Chipbreaker Rougher making Steel chips fly in Mastercam’s lab.
These End Mills are engineered with 5 flute variable pitch and offset chipbreaker geometry to keep chips small and increase chip evacuation while keeping cutting forces low. Specially engineered to excel in High Efficiency Milling (HEM) applications, these high performance tools offer outstanding performance in a wide range of ferrous materials, including low and medium alloy steels, tool steels, cast iron, titanium, and titanium alloys.
Click Here to Explore Helical’s Full Offering of Roughers for Steels
https://www.harveyperformance.com/wp-content/uploads/2022/11/Feature-Image-Helical-HEV-C-5-Video.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-11-16 15:50:382025-11-12 15:49:27Helical 5 Flute Chipbreaker Rougher for Steel
6 Flute End Mill: HEM and Helical Interpolation
November 11, 2022/2 Comments/in Tools In Action/by Harvey Performance Company
Watch this video of Helical Solutions’ 6 Flute Variable Pitch End Mill High Efficiency Mill (HEM) and helically interpolate a 1018 Steel part.
Known to outlast the competition and maximize shop profitability, Helical’s 6 Flute Corner Radius Variable Pitch End Mills offer outstanding performance and high temperature resistance in a wide variety of ferrous materials, including low and medium alloy steels, tool steels, cast iron, titanium, and titanium alloys. Engineered to excel in light profiling, High Efficiency Milling (HEM), and finishing applications, these high performance end mills will pay serious dividends at your spindle.
Click Here to Explore Helical’s Full Offering of End Mills for Steels
https://www.harveyperformance.com/wp-content/uploads/2022/11/Feature-Image-Helical-HEV-6-1018-Video.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-11-11 11:30:292025-11-12 15:44:446 Flute End Mill: HEM and Helical Interpolation
Helical Solutions’ Multi-Axis Finishers With Mastercam
November 8, 2022/0 Comments/in Tools In Action/by Harvey Performance Company
Check out the clean finish left by Helical Solutions’ 4 Flute Taper Form Multi-Axis Finishing Tool in this video collaboration done with @mastercam.
Multi-Axis Finishers are Helical’s solution for operations with extremely high surface finish requirements. When switching from a traditional ball end mill, finish requirements can be dramatically improved, and cycle times can be cut down to a fraction of the time.
Designed to perfect your finishing operations, Helical’s Multi-Axis Finishers feature a specially defined profile with a large radius. This large radius allows for a greater stepover to be used pass-to-pass, while keeping the same cusp height as a ball end mill. Fully stocked in a variety of profiles and flute counts, these tools are offered for both Aluminum & Non-ferrous materials and Stainless Steels & High Temp Alloys.
Click Here to Explore the Full Helical Solutions Multi-Axis Finishers Offering
https://www.harveyperformance.com/wp-content/uploads/2022/11/Feature-Image-MAF-Video-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-11-08 17:32:452022-11-09 10:01:58Helical Solutions’ Multi-Axis Finishers With Mastercam
Harvey Tool’s Combination Drill/Thread Mill in Aluminum
November 4, 2022/5 Comments/in CNC Machining Videos, Tools In Action/by Harvey Performance Company
Check out this video of our Combination Drill/Thread Mill working its magic in some aluminum.
Designed for combined drilling, threading, thread relief cutting, and chamfering, Harvey Tool’s Combination Drill/Thread Mills are designed to perform four different operations. Save time by minimizing tool changes while preserving valuable room in your tool carousel with this unique 3 flute tool. CNC ground from solid carbide, this tool is fully stocked in a wide variety of different sizes and is offered TiB2 coated for extended tool life.
Running Harvey’s Combination Drill/Thread Mills
Infographic depicting combination drill/thread mills and their order of operations when engaging with a workpiece
Check out this video demonstration to watch how the Combination Drill/Thread Mill tackles blind holes with ease.
Click Here to Explore the Combination Drill/Thread Mill Offering
https://www.harveyperformance.com/wp-content/uploads/2022/11/Feature-Image-Combo-DrillThread-Mill-Tools-in-Action-Video.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-11-04 12:53:462023-09-21 13:40:37Harvey Tool’s Combination Drill/Thread Mill in Aluminum
Page 1 of 41234
