Complex parts require more than a single operation. Features such as contours, chamfers, engraved details, and precision holes often demand multiple tooling strategies working together throughout the machining process.
In the video below, watch a single component progress from a block of Ti-6Al-4V to a finished part through more than 10 machining applications, each supported by specialized Harvey Tool solutions.
Operations throughout the process utilize a range of tooling, including Variable Pitch End Mills for Titanium, Miniature Ball End Mills, Miniature Chamfer End Mills, High Performance Drills for Prehardened Steels, and Engraving Cutters.Each step demonstrates how selecting the right tool contributes to accuracy, surface finish, and overall part quality.
Explore the full range of solutions available in the 2026 Harvey Tool Catalog, featuring more than 31,000 miniature and specialty cutting tools designed to support even the most demanding applications.
View the 2026 Harvey Tool Catalog
August 25, 2023/0 Comments/in CNC Machining, CNC Machining Videos, Steels, Tools In Action/by Harvey Performance Company
Don Grandt, Harvey Performance Company National Application Engineer, met up with Jesse Trinque at the Mastercam Manufacturing Lab to demo some Helical Solutions End Mills and discuss Continuous Time In Cut (CTIC).
Continuous Time in Cut (CTIC) is the amount of time that a tool is engaged with a material. When an end mill is in a cut for too long, the friction can build and surface foot can be sacrificed, greatly affecting the performance and wear of a tool.
Check out this video to watch Jesse and Don test out how different levels of CTIC directly affect tool life and performance. This series of tests, which were facilitated by Mastercam, were conducted in Okuma’s GENOS M560-V, and utilized tool paths from Mastercam. For tooling, a standard ½” Helical Solutions HEV-6, a 6 flute, variable pitch end mill with a .03” corner radius, was used to machine 17-4 stainless steel.
All tests used the same cutting parameters, setup, material, and tool, with altered CTIC.
Take a Deeper Dive Into CTIC
Tune into this episode of In The Loupe TV to learn how you can manipulate Continuous Time In Cut (CTIC) and surface foot to reduce heat in your machining applications.
https://www.harveyperformance.com/wp-content/uploads/2023/08/featured-image-Mastercam-CTIC-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2023-08-25 11:10:362025-11-12 15:57:44Helical x Mastercam: Continuous Time in Cut (CTIC)
Harvey Tool’s Combination Drill/Thread Mill in Aluminum
November 4, 2022/5 Comments/in CNC Machining Videos, Tools In Action/by Harvey Performance Company
Check out this video of our Combination Drill/Thread Mill working its magic in some aluminum.
Designed for combined drilling, threading, thread relief cutting, and chamfering, Harvey Tool’s Combination Drill/Thread Mills are designed to perform four different operations. Save time by minimizing tool changes while preserving valuable room in your tool carousel with this unique 3 flute tool. CNC ground from solid carbide, this tool is fully stocked in a wide variety of different sizes and is offered TiB2 coated for extended tool life.
Running Harvey’s Combination Drill/Thread Mills
Infographic depicting combination drill/thread mills and their order of operations when engaging with a workpiece
Check out this video demonstration to watch how the Combination Drill/Thread Mill tackles blind holes with ease.
Click Here to Explore the Combination Drill/Thread Mill Offering
Do you love machining? Us, too! Share your machining pictures and videos with us on Instagram at any Harvey Performance Company page: @harveytool, @helicaltools, @micro100, @titan.usa, or @corehog. We’d love to share your work and give your shop a shout-out on In the Loupe!
https://www.harveyperformance.com/wp-content/uploads/2022/11/Feature-Image-Combo-DrillThread-Mill-Tools-in-Action-Video.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-11-04 12:53:462023-09-21 13:40:37Harvey Tool’s Combination Drill/Thread Mill in Aluminum
Customer Video: High Performance Chamfer Mills
May 6, 2022/1 Comment/in CNC Machining Videos, Tools In Action/by Harvey Performance Company
Watch this great video from @ekramer3 shared to @helicaltools‘ Instagram, which shows a ¼” Helical Solutions’ Tipped Off High Performance Chamfer Mill, featuring 5 flutes, .095″ length of cut and a 2-1/2” overall length chamfer some stainless steel.
“Stainless steel lanyard bead is flipped over in the ER40 collet to put some shiny chamfers on the bottom with this @helicaltools .25 inch 5-flute chamfer mill (part 59807). The bead is sitting on top of the remaining bar stock (not visible) so that the collet has something to clamp along its full length.”
Helically ground with positive axial rake and clearance to deliver high performance chamfering, Helical Solutions’ High Performance Chamfer Mills feature a helical flute geometry for superior part finish. These solid carbide tools are fully stocked Zplus coated for higher hardness and added lubricity, or Aplus coated for added lubricity and higher speeds and feeds in a wide variety of ferrous metals and titanium alloys. They’re offered in a Pointed Tip Style for precise application and detailed workpieces, or a Tipped Off Style for programming accuracy and increased strength.
Click Here to Explore the Full Helical Solutions High Performance Chamfer Mill Offering
Do you love machining? Us, too! Share your machining pictures and videos with us on Instagram at any Harvey Performance Company page: @harveytool, @helicaltools, @micro100, or @titan.usa. We’d love to share your work and give your shop a shout-out on In the Loupe!
https://www.harveyperformance.com/wp-content/uploads/2022/05/Feature-Image-HPCM-Video-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-05-06 11:23:502022-05-06 14:01:05Customer Video: High Performance Chamfer Mills
Customer Video: High Balanced End Mills in Aluminum
April 15, 2022/0 Comments/in CNC Machining Videos, Tools In Action/by Harvey Performance Company
Check out this video from @chipsmotorsports, shared to @helical’s Instagram, which features Helical Solutions’ 3 Flute, Corner Radius – Coolant Through – Reduced Neck, High Balanced End Mill in Aluminum.
Helical’s 3 Flute, Coolant Through, Reduced Neck, High Balance End Mills are specifically designed to provide outstanding performance in Makino MAG machining centers capable of elevated RPMs and feed rates. Built for accelerated Metal Removal Rates (MRR), these tools are precision balanced for high velocity machining in aluminum (up to 33,000 RPM) and feed rates, making them an excellent contender for High Efficiency Milling (HEM). They’re fully stocked in square and corner radius profiles in both two and three flute counts with reduced neck geometries for maximum strength in long reach and deep pocketing applications.
Click Here to Explore Helical’s High Balanced End Mills
https://www.harveyperformance.com/wp-content/uploads/2022/04/Feature-Image-High-Balanced-Video-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-04-15 19:00:072023-01-06 09:56:06Customer Video: High Balanced End Mills in Aluminum
Helical Solutions: Behind the Scenes
June 12, 2018/0 Comments/in CNC Machining, CNC Machining Videos, Tools In Action/by Harvey Performance Company
We have shown our end users bits and pieces of our manufacturing process on our website and via social media, but for the first time we decided to open our own doors to the public and show you every step behind how we manufacture and fulfill the Helical Solutions product. We partnered with John Saunders from NYC CNC to create a “Factory Tour” video, covering topics like our CNC grinding machines and setups, tool manufacturing, and our warehouse organization and fulfillment procedures.
In the video below, we first toured our Gorham, Maine manufacturing plan with Plant Manager Adam Martin. Then, we ran a few tests with the Helical tools on our Haas machine, before heading back to our warehouse in Massachusetts to talk about fulfillment and new products with Fulfillment Manager Megan Townsley.
We know you’re busy making amazing parts, and might not have time for the entire video. To save you time, here are some of the most important facts you should know about Helical.
We Take Quality Control Seriously
Our high performance end mills go through an extensive inspection and quality assurance process before they end up in your machine, with multiple inspection points along the manufacturing journey. At the 17 minute mark of the video, you can learn more about how we monitor the quality of the tools in batches as they are manufactured. If you skip ahead to the 29 minute mark, you can see some of our more advanced inspection machines in action.
We Stand Behind Our Tools with Our Renewal Services
Our Tool Renewal service is a great way to maximize your cost-savings and avoid having to re-purchase new tools without sacrificing any aspects of the original design. At Helical, we do not re-sharpen tools. Rather, we restore your tools to their original geometry. We will review the condition of your used tools and return the cutting edge to its original sharpness and strength, allowing the tool to retain its outstanding performance. The renewed tools go through the same rigorous inspection, edge prep, and coating process that we follow for all our of our new tools. To learn more about our Tool Renewal services, head to the 23:30 mark in the video.
Our Tool Coating Is Done In-House
We have multiple tool coating machines in-house which allow us to take the ground tools right off the line and transfer them to our coating room to have Aplus, Zplus, or Tplus coatings added. These machines also have the capability to create roughly 20 different coatings, which are reserved for specials and custom orders. If you want a close-up look at the coating room and learn how the PVD coating process actually works, head to the 35 minute mark.
Our Standard Catalog Items Are Stocked and Ready for Your Machine
We don’t make our standard catalog tools to order. All of our standard tools are stocked and ready to make some chips in your machine. We also introduce hundreds of new tools to our annual catalog to keep providing our customers with the latest in high performance tooling technology. You can check out our new tools for 2018, including our new High Balance Tools and Metric Tooling, by heading to 52:20, or take quick look at our rows of stocked tools in our warehouse by jumping to 56:55.
Diamond Wheels Grind Carbide Tools
Diamond grinding wheels are the essential tool (outside of the machine) when it comes to grinding carbide. We have a unique management system for our diamond wheels, and a redressing process which can see these wheels last up to a year or more before they need replacement. Adam goes through our “frozen wheel” room with John at the 32:45 mark in the video above.
We Track Every Batch of Tools With Laser Etching
Our tools are all laser etched on-site with our logo, phone number, and tool description, but also with a specific batch number. These batch numbers allow us full track-ability of every tool so we can quickly asses any questions or concerns a customer may have about a tool. With these numbers, we are able to track the tool’s journey all the way back to which machine it was made on, which grinding wheel was used, and who ran the program. We have a couple of these laser etching machines in Maine, which you can see in action at the 42 minute mark.
If You Can Dream It, We Have Probably Made It
We have had some crazy tool drawings come in to our custom tool program over the years, including oddly shaped form tools, tools with a crazy long length of cut, “paper cutters”, and more. You can see some cool examples of custom tools we have manufactured by jumping to the 20 minute mark. If you are more interested in how we actually make them, head to the 27 minute mark to see one of our large custom tools being ground on our Walter machines.
Our Technical Resources Are Second To None
We don’t leave you hanging after your purchase of Helical tools. We have a multitude of technical resources and How-Tos available here on our blog, and we also offer the HEM Guidebook, a complete guide to High Efficiency Milling techniques.
If you are looking for information on speeds and feeds, we suggest you try our Machining Advisor Pro application. This application is designed to increase metal removal rates and shop productivity by generating customizable running parameters optimized for your Helical Solutions end mills. You can click here to get started with Machining Advisor Pro today.
You Will Always Get a Real Person When You Call Helical
If you have technical questions about an upcoming job, a special application, or tooling selection, you can contact Helical by phone at 866-543-5422. Our technical experts are available over the phone Monday-Friday from 8 AM to 5 PM EST, and you will always get a real person to talk to with no automated systems to navigate through. You can also reach our team by email at [email protected].
Questions about where to buy Helical tools? You can give our team a call, or you can find your local distributor by using the “Find a Distributor” tool on our website. Simply choose your state to see a complete list of authorized distributors in your area.
We’re Hiring!
We have a current list of our open opportunities on our website! Open jobs include CNC Machinist, Quality Control Inspector, and Customer Service Representative.
https://www.harveyperformance.com/wp-content/uploads/2018/06/Helical-Behind-the-Scenes.jpg 435 1155 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-06-12 14:30:112022-10-17 10:18:39Helical Solutions: Behind the Scenes
February 19, 2018/3 Comments/in CNC Machining, CNC Machining Videos, CNC Programming, Machining 101, Machining Techniques, Tools In Action/by Jacob Concepcion
infographic showing x, y and z axii
https://www.harveyperformance.com/wp-content/uploads/2018/02/Featured-Image-Multiaxis-Machining-IMG.jpg 525 1400 Jacob Concepcion http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Jacob Concepcion2018-02-19 11:45:102023-10-12 14:31:04The Advances of Multiaxis Machining
