August 25, 2022/35 Comments/in CNC Machining, Drilling, Drilling & Holemaking, Harvey Tool, Holemaking, Machining Techniques, Milling, Titan USA, Tool Selection, Troubleshooting Tips/by Tom Pyle
Drilling an ultra-precise hole can be tough. Material behavior, surface irregularities, and drill point geometry can all be factors leading to inaccurate holes. A Spot Drill, if used properly, will eliminate the chance of drill walking and will help to ensure a more accurate final product.
Choosing a Spot Drill
Ideally, the center of a carbide drill should always be the first point to contact your part. Therefore, a spotting drill should have a slightly larger point angle than that of your drill. Common drill point angles range from 118° to 140° and larger. Shallower drill angles are better suited to harder materials like steels due to increased engagement on the cutting edges. Aluminums can also benefit from these shallower angles through increased drill life. While these drills wear less and more evenly, they are more prone to walking, therefore creating a need for a proper high performance spot drill in a shallow angle to best match the chosen drill.
Five Valor holemaking high performance spot drills displayed on top of a workpiece with a purple product packaging container in front
If a spotting drill with a smaller point angle than your drill is used, your drill may be damaged due to shock loading when the outer portion of its cutting surface contacts the workpiece before the center. Using a drill angle equal to the drill angle is also an acceptable situation. Figure 1 illustrates the desired effect. On the left, a drill is entering a previously drilled spot with a slightly larger angle than its point. On the right, a drill is approaching an area with an angle that is far too small for its point.
Proper Spot Angle Diagram
Marking Your Spot
A Spotting Drill’s purpose is to create a small divot to correctly locate the center of a drill when initiating a plunge. However, some machinists choose to use these tools for a different reason – using it to chamfer the top of drilled holes. By leaving a chamfer, screw heads sit flush with the part once inserted.
Spot Drill
What Happens if I Use a Spot Drill with an Improper Angle?
Using a larger angle drill will allow the drill to find the correct location by guiding the tip of the drill to the center. If the outer diameter of a carbide drill were to contact the workpiece first, the tool could chip. This would damage the workpiece and result in a defective tool. If the two flutes of the drill were slightly different from one another, one could come into contact before the other. This could lead to an inaccurate hole, and even counteract the purpose of spot drilling in the first place.
Avoiding CNC Drill Walking With a Spotting Drill
Few CNC machining applications demand precision like drilling. The diameter hole size, hole depth, part location, and finish are all important and provide little recourse if not up to specifications. That said, accuracy is paramount – and nothing leads to inaccurate final parts faster than drill walking, or the inadvertent straying from a drill’s intended location during the machining process. So how does drill walking occur, and how can one prevent it?
To understand drill walking, think about the act of striking a nail with a hammer, into a piece of wood. Firm contact to a sharp nail into an appropriate wood surface can result in an accurate, straight impact. But if other variables come into play – an uneven surface, a dull nail, an improper impact – that nail could enter a material at an angle, at an inaccurate location, or not at all. With CNC Drilling, the drill is obviously a critical element to a successful operation – a sharp, unworn cutting tool – when used properly, will go a long way toward an efficient and accurate final part.
To mitigate any variables working against you, such as an uneven part surface or a slightly used drill, a simple way to avoid “walking” is to utilize a Spotting Drill. This tool is engineered to leave a divot on the face of the part for a drill to engage during the holemaking process, keeping it properly aligned to avoid a drill from slipping off course.
When Won’t a Spot Drill Work for My Application?
When drilling into an extremely irregular surface, such as the side of a cylinder or an inclined plane, this tool may not be sufficient to keep holes in the correct position. For these applications, flat bottom versions or Flat Bottom Counterbores may be needed to creating accurate features.
Harvey tool spot drill zoomed in on the tip of the drill
Harvey Tool Spot Drill
Tom Pyle( Manager of Product Development )
As Harvey Performance Company Manager of Product Development, Tom oversees new product development for the Helical Solutions brand. He is responsible for ensuring top-quality and innovative product introductions that exceed our customers’ expectations.
https://www.harveyperformance.com/wp-content/uploads/2017/03/Feature-Image-Spotting-Drills-IMG.jpg 525 1400 Tom Pyle http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Tom Pyle2022-08-25 10:52:002023-10-18 08:19:12Spot Drilling: The First Step to Precision Drilling
end mill selection 5 Questions to Ask Before Selecting an End Mill
Workshop For Warriors Workshops for Warriors – Featured Customer
Helical Wish List Simplify Your Cutting Tool Orders
Micro 100 Holiday Giveaway
flat bottom tools 10 Reasons to Use Flat Bottom Tools
graphite machining Grappling With Graphite: A Machining Guide
  1. Daniel
    Daniel says:
    February 14, 2018 at 10:32 am
    Hi, this is a good summary, thanks!.
    Would you consider adding to this article consideration for the practice of spot drilling using a much smaller drill bit? I was taught that spotting with a smaller drill bit works just as well since the outer diameter of the final size drill will not engage first, it would be the core that would center and engage first.
    • BOB
      BOB says:
      June 16, 2022 at 9:59 am
      You never want to use a smaller drill to spot with. The whole point of spotting is to put a spot for your drill to follow/start with that is in the exact position that you want. A smaller drill as a spotting tool will flex and walk and your actual drill will follow that point and be off location or cut on an angle. You need to spot with a rigid and/or stubby tool so that it transfers exact location.
  2. Scott
    Scott says:
    July 16, 2018 at 11:27 am
    I’ve seen it recommended to spot with an angle smaller than the drill tip angle when using a H.S.S. drill. I’ve also seen the same recommendation for soft materials as aluminum vs steel. I’ve had the best results by always spotting with an angle greater than the drill angle, soft or hard materials, HSS or Carbide drills. I think HSS is more forgiving for sure vs carbide. I’ve used plain old center drills in stainless steel as they are cheap and hold up well then drilled with HSS drills. Works fine but I cannot attest to the accuracy as at that place we really never checked parts on a CMM.
  3. Mike
    Mike says:
    July 17, 2018 at 12:26 pm
    I dont feel this is correct. A drill tip magnified, you cant get a cutting edge. So if the tip touches first, for a split second it smears. I have spotted many 90 deg holes and never experienced “shock loading”. Thats why center drills are 60 deg. Lets the cutting edge of drill engage before the drill tip. Should you guys discontinue your 60 – 100 deg spot drills?
    • Tim Lima
      Tim Lima says:
      July 25, 2018 at 8:34 am
      Hi Mike! Thank you for your comment and reaching out to us with some inquisitive questions.
      When drilling, the chisel angle – the very tip of the point angle, comes in contact with the work piece. Because you have the two cutting lips overlapping here, you form a chisel angle where actual cutting is not happening. Here, you want enough thrust for the drill to penetrate the material and then the chisel angle starts to extrude the material. The longer the chisel angle, the more durable the tip is but you will need more thrust in order to penetrate the material. Bringing this into the context of spotting, we can see why if you just barely touch the material you will get more rubbing and less cutting. We feel like you bring up a great tip here, no pun intended, that when spotting you want to take enough of an axial depth in order to go past the chisel angle and actually start cutting the chip.
      Next, using the term “shock loading” may not be the best description on what is happening when you contact somewhere on the point angle first. Shock loading typically comes from interrupted cuts so as long as the point angle is symmetrical and located perfectly, that should not be happening. What we want to get across here is that this is not the ideal way of spotting because of how the drill will now wear unevenly along the point angle and may lead to chipping. For example, if the drill always contacts half way up the point angle, you will start to see more wear there than what is happening close to the chisel angle. Historically, and with softer materials, this was less of a concern but with the advent of tougher and high temp alloys, we would recommend staying away from this. A flatter point angle on the spotting drill will help relive extreme stress on the lip of a drill in these materials. Ultimately, it is up to the machinist to weigh the pros and cons of any operation and we just want our readers to understand more on what is going on.
      Finally, as mentioned before, everyone has their way of doing things. We have heard that our customer use spotting drills as a combination tool and leave a chamfer at the top of the hole with them. This is why we offer such a large range of included angles to help with ideal spotting situations to help saving room in your tool carousel. We hope you find this information useful and if you are having any more questions or any challenges with our line, from smearing to angle selection or anything between, please contact our experienced tech team at 800-645-5609 or email at [email protected].
      • Dave
        Dave says:
        August 4, 2019 at 3:13 pm
        Using a carbide drill in a CNC milling machine would be a poor choice. If you are peck drilling the carbide is going to take a beating. If the material is too hard I would use a carbide endmill in a High Speed milling machine. If possible I would use a undersized HSS drill when the material is soft……say prior to heat treat. Then finish the holes in a High Speed Milling machine with a 4 flute CEM.
        • William Lewis
          William Lewis says:
          May 20, 2020 at 11:49 am
          Carbide drills are excellent in cnc machines. most manual machines can’t even spin a carbide drill to it’s proper sfm. You can drill without pecks on a cnc
        • Justin Swan
          Justin Swan says:
          April 26, 2022 at 4:34 am
          I have to disagree here. We use carbide drills as small as 1.6mm to drill Inconel and titanium with great results in both tool life and accuracy, pecking is an absolute must as any “stringy” swarf build up in the flutes will snap your drills in no time. HSS drills are better suited to Softer materials up to 316 stainless steels.
        • Jamie Wheaton
          Jamie Wheaton says:
          April 4, 2024 at 6:24 am
          I drill cast aluminum with a .047 DIA 3 flute carbide drill made for aluminum from Harvey Tools. I do not use a spot drill and I do not peck drill. I drill almost to a 3xD depth and I can drill over 75.000 holes without having any issues with tool breakage. The holes are always in the correct position and I don’t have any issues with tools walking.
    • William Lewis
      William Lewis says:
      May 20, 2020 at 11:45 am
      A 60 degree spot drill is 1 degree wider than a 59 degree drill, so the drill’s point would touch first.
      • William Lewis
        William Lewis says:
        May 20, 2020 at 11:55 am
        Scratch that, I was thinking of 120 degree spots
    • Jake V.
      Jake V. says:
      March 14, 2023 at 9:19 am
      I disagree with the statement: “Thats why center drills are 60 deg. Lets the cutting edge of drill engage before the drill tip.”
      The main reason “center drills” are 60 degrees is so that you can prepare the end faces of lathe workpieces that need tailstock support. The most common tailstock centers are 60 degrees (included), hence the most common center drills are 60 degrees. Sounds like you are using a combined “center” drill as a spot drill.
  4. Aldam
    Aldam says:
    August 1, 2018 at 3:00 am
    Excellent way of telling, and nice paragraph to get data about my presentation topic, which i
    am going to deliver in college.
  5. Caden Dahl
    Caden Dahl says:
    January 30, 2019 at 8:11 pm
    If I had to drill into some concrete, I’d for sure make a spot drill. That way, I can be sure that my larger drill would be in the same place. However, I would have to go out and purchase all these tools as I don’t have any in my possession.
  6. Thomas Jameson
    Thomas Jameson says:
    June 20, 2019 at 11:20 am
    It’s good to know that you need to have the proper spot angle when drilling concrete. My brother wants to drill some concrete that he has on his property, and he wants to make sure he goes about doing it properly. I’ll pass this information along to his so that he can properly drill his concrete.
  7. vicky
    vicky says:
    October 16, 2019 at 5:54 am
  8. Curtis D. Workman
    Curtis D. Workman says:
    December 3, 2020 at 6:55 pm
    I’m surprised to see no mention of
    135° split point cobalt drills which I’ve used a lot with no spot drill necessary!
    I’ve also worked in Aerospace and NASA related hardware that mostly used tighter tolerances on hole location and sizing that required a chamfer or break all edges
    call out on the print. One company that I worked at was primarily making hydraulic, oil, and fuel filtration systems for many of our commercial airline industry and military fighting jets. We always utilized a 90° spot drill and most often followed with a 118° or a 135° dŕill and these surely had tight tolerances that were easily kept…
    Multi billion dollar company that made filtration for the F18’s all the way through the B2 Bomber that had a price of $250,000.00 for each one and it requires 8 total…
  9. Wood ship kit
    Wood ship kit says:
    June 4, 2021 at 1:16 am
    That’s really nice post. I appreciate your skills. Thanks for sharing.
  10. Tex Hooper
    Tex Hooper says:
    September 15, 2021 at 6:57 pm
    I appreciate what you said about using the center of the carbide drill. I need to hire a crew to drill a hole in the backyard. I want it wide enough for a pool.
  11. Brad B
    Brad B says:
    September 30, 2022 at 4:53 pm
    How do you choose the right diameter for a spot drill?
    Let’s say I’m cutting 1/4-20 UNC 2A internal threads and targeting a 0.201″Ø hole. I’m using a 0.2009″Ø drill (130° angle) and a 0.201″Ø reamer. I’d go with a 140° spot drill but what diameter?
      October 3, 2022 at 9:49 am
      Hello Brad,
      Great question! We recommend using a spot drill with the same diameter as the drill you are using.
      • Brad B
        Brad B says:
        October 3, 2022 at 2:46 pm
        Thanks Guy! The problem with using a spot diameter the same as the drill diameter is that Harvey doesn’t make a spot diameter in 0.2009″ (I doubt anybody does). There’s 0.187 and then 0.25. If I go with the smaller diameter then I fear the point angle will wear unevenly (“shock load”). If I go with the bigger diameter then, well, I’m making a bigger hole than I want.
          October 3, 2022 at 3:08 pm
          Hey Brad,
          In the circumstances like these, we suggest using a larger spot drill but do not drill fully to the OD of the spot drill.
          • Brad B
            Brad B says:
            October 3, 2022 at 5:56 pm
            🤦🏻‍♂️ Seems obvious now. Thanks.
            Last question: what’s the difference between your two types of spotting drills: on-center (type I) vs ahead-of-center (type II)?
            October 4, 2022 at 8:54 am
            On-center Spot Drills design reduces walking and minimizes the flat at the bottom of the spot. These tools are ideally suited for starting smaller-diameter drills and shallow spots. Ahead-of-center Spot Drills design improves tip strength. These tools are ideally suited for larger-diameter drills and tougher materials.
    • steven
      steven says:
      October 10, 2023 at 5:17 pm
      I use the largest spot drill that will fit in that area. rigidity. then I only spot to a depth to create a diameter .01/.015 over the desired diameter of the hole.
      if you’re drilling with a .02 drill then yes you need a small spot, smaller web. common sense then comes into play.
      we also use a lot of Dream Drills. no spot required and no pecking in 304 stainless. time savers and last forever running at the companies recommended feeds and speeds.
  12. Willie
    Willie says:
    August 12, 2023 at 10:39 am
    In the article, you mentioned the importance of matching the spot drill angle to the drill angle for optimal results. How does the material being drilled influence the choice of spot drill angle, especially when working with composite materials or layered materials with varying hardness?
    • Matt Daigle
      Matt Daigle says:
      December 14, 2023 at 11:40 am
      Hi WIllie,
      Typically you will see in drill design that the harder the material (or the more difficult it is to machine) the point angle increases. This allows for a stronger point. Also as you increase the point angle you reduce the radial forces so you start to see less pushout on the backside on through holes. The spotting drill’s geometry ensures a drill begins its job efficiently, where it will be doing most of the actual work.
      Spotting drills spend such little time in the cut, it should be chosen off of the drill angle. The drill angle is what should be dictated by the material.
  13. John
    John says:
    December 6, 2023 at 2:30 pm
    Somewhat random question I hope you can answer. I have googled and searched forums and have come up empty handed. When we say “NC Spot Drill” what does the NC stand for? I may feel dumb when I hear the answer, but no dumber than I do after pondering it…! Thanks.
  14. LEW PARK
    LEW PARK says:
    January 3, 2024 at 1:47 pm
    always use a lesser angle for spotting otherwise outer edges of drill will notch and break, more so with carbide drills
  15. GTD Desco
    GTD Desco says:
    June 4, 2024 at 8:15 am
    Thanks for sharing this informative blog.
  16. Zach
    Zach says:
    November 5, 2024 at 1:49 pm
    I’ve seen the recommendation to use a smaller angle when spotting for HSS drills and a larger angle when spotting for carbide drills. Do you have any thoughts on that? Would you recommend using a larger spotting angle regardless of the drill material or workpiece material?
    • Greg Schranze
      Greg Schranze says:
      November 19, 2024 at 11:36 am
      Hi Zach,
      Regardless of HSS/Carbide — You would want to choose a drill for your material and application first. You would then want to complement the drill you’ve selected with a spotting drill of a wider angle. The wider angle will ensure the drill engages the material safely (as “Figure 1” shows).
  17. SVE DRILLING TOOLS
    SVE DRILLING TOOLS says:
    May 29, 2019 at 6:15 am
    This is a good summary..
Trackbacks & Pingbacks
  1. Weekly Blog Post Round Up - BlackHawk Industrial Blog says:
    November 5, 2018 at 3:21 pm
    […] can be used for several machining operations including beveling, deburring, countersinking, and spotting. READ […]
