five cnc composte holemaking tools
April 21, 2017/0 Comments/in CNC Machining, Composites, Drilling & Holemaking, Holemaking, Machining Techniques, Material Specific, Milling, Tool Selection/by Harvey Performance Company
Harvey Tool’s Miniature High Performance Composite Drills are specifically designed with point geometry optimized for the unique properties of composite materials. Our Double Angle style is engineered to overcome common problems in layered composites and our Brad Point style is built to avoid the issues frequently experienced in fibrous composites.
Common Composite Problems
Drilling in composite materials is a unique challenge. There are a wide variety of regularly machined composites, each requiring different considerations and approaches. Overcome common composite holemaking problems by identifying and selecting the right tool for your job.
Delamination
Defining Delamination
Delamination occurs when high drilling forces cause laminated layers to separate, yielding less structurally-sound parts. The more blunt a drill point is, the more force it will take to move through a part, increasing the chance of delamination.
Delamination and Push-Out
Identifying Delamination
The separation of layers may be difficult to identify through visible scrutiny. Closely inspecting and testing the hole quality is ideal when looking for delamination.
Ideal Drill Choice
Double Angle Composite Drills
Uncut Fibers
Defining Uncut Fibers
Uncut fibers are largely caused by dull tooling. If a drill’s cutting edge is not sharp enough, fibers will remain uncut, frayed, or splintered, potentially ruining the part.
Identifying Uncut Fibers
Uncut fibers should be easily noticed: look for splintered or frayed fibers around the edges of your hole.
Ideal Drill Choice
Brad Point Composite Drills
Tear-Out
Defining Tear-Out
Rather than leaving uncut fibers hanging on to a workpiece, dull tools can also grab fibers and tear them out of the material altogether. This can leave voids in your material and cause damage to even greater areas of the workpiece.
Tear Out
Identifying Tear-Out
Tear-out can be more difficult to spot than uncut fibers. However, it is often seen as an area of material completely removed around the edge of a hole.
Ideal Drill Choice
Choose Your Tool
Harvey Tool’s new Composite Drills are engineered with point geometry optimized for fibrous and layered composite materials. Each design is specifically built to overcome common composite drilling challenges and achieve excellent results.
Avoid Delamination and Push-Out
composite drills Harvey
v
Harvey Tool’s Double Angle Composite Drills help combat delamination and push-out in layered composite materials with specialized point geometry. The primary 130° point angle allows the drill to efficiently engage laminated composites without lifting the top layer of material. The shallower secondary 60° point angle reduces the amount of force required to move the drill through the material, further reducing the probability of delamination. The higher shear angle also aids in reducing push-out at the back of the workpiece by more gradually breaking through the part.
Avoid Uncut Fibers and Tear Out
composite drills
Harvey Tool’s Brad Point Composite Drills are designed specifically for superior performance in fibrous materials. The trident-like brad point ensures that holes in fiber filled and reinforced materials come out clear and free of fraying. The outer points accurately score the outer diameter of drilled holes, eliminating uncut fibers, tear-out, and splintering.
For more information on Composite Drills and all of Harvey Tool’s new products, visit the Harvey Tool website.
https://www.harveyperformance.com/wp-content/uploads/2017/04/Feature-Image-Composite-Holemaking-Challenges.jpg 525 1401 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-04-21 10:00:312024-11-06 13:16:28Overcoming Composite Holemaking Challenges
Hybrid Machining – Featured Customer
machining advisor pro Get to Know Machining Advisor Pro
made with micro Show Us What You #MadeWithMicro100
flute count Why Flute Count Matters
Heavy Duty Racing – Featured Customer
BrickTactical Brick Tactical – Featured Customer
