6 Uses of Double Angle Shank Cutters
Thread Milling
Chamfering
Back Chamfering
Machining V-Grooves
Deburring
Countersinking
Countersinking a part is done so a screw, nail, or bolt is able to sit flush with the part surface. Using specialty profile tooling can help enlarge the rim of a drilled hole and bevel the sides for a screw to sit accurately. A Double Angle Shank Cutter can also perform this operation by using the bottom portion of its cutting face.
Can we count left-hand threading, coarse threads, fine threads, and ultra fine threads to that exaggerated list? How about reaming? I bet we can even machine a knurl with it. Definitely can side-mill rasp teeth. If it has a radius, you could even surface radii and 3d surfaces! You can use it as a scoring tool to break the part off from stock. That’s 16 different uses!
