Helical 5 Flute Chipbreaker Roughing 1018 Steel
July 18, 2022/10 Comments/in Tools In Action/by Harvey Performance Company
Watch this video of Helical Solutions’ 5 Flute Variable Pitch Chipbreaker Rougher End Mill roughing out 1018 Steel without any coolant.
Ground from solid carbide, Helical Solution’s wide selection of 5 Flute Variable Pitch Chipbreaker Rougher End Mills is specially engineered to reduce harmonics and increase feed rates in a wide range of ferrous materials. Aplus coated for added lubricity and high performance temperature resistance for faster speeds and feeds and improved tool life, these tools provide excellent performance in light profiling, High Efficiency Milling (HEM), and finishing applications.
Fully stocked and ready to ship today, Helical’s 5 Flute Variable Pitch Chipbreaker Rougher End Mills are offered in a variety of end profiles, neck designs, and sizes.
Click Here to Explore the Full Helical Solutions Product Offering
Do you love machining? Us, too! Share your machining pictures and videos with us on Instagram at any Harvey Performance Company page: @harveytool, @helicaltools, @micro100, @titan.usa, or @corehog. We’d love to share your work and give your shop a shout-out on In the Loupe!
https://www.harveyperformance.com/wp-content/uploads/2022/07/Feature-Image-HEV-6-Tools-in-Action-Video.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-07-18 10:31:042025-11-12 15:49:09Helical 5 Flute Chipbreaker Roughing 1018 Steel
  1. Chuck
    Chuck says:
    July 21, 2022 at 11:54 am
    What are the machining specifics (i.e. EM size, speeds, feeds, DOC, WOC, etc.) used in video?
      July 21, 2022 at 12:49 pm
      Hello Chuck,
      This is Helical EDP# 59406 which is a 1/2″ diameter end mill with a 1-1/4″ length of cut. We ran this tool at 7,639 RPM, 344 IPM and 1,000 SFM with 1/2″ ADOC and 15% RDOC.
      • Andy Warzecha
        Andy Warzecha says:
        July 28, 2022 at 1:30 pm
        Are You sure it is 6 flute? Helical’s 6 Flute End Mill Roughing 1018 Steel
        EDP shows 5 flute
        TOOL # 59406
        5 Flute, Corner Radius – Chipbreaker Rougher, Variable Pitch (Aplus), End Mills for Steels, Tool Steels, Cast Iron, & Titanium
        https://www.helicaltool.com/products/tool-details-59406
          July 28, 2022 at 2:04 pm
          Hello Andy,
          Great catch! This article is mislabeled currently. I will make sure this is updated to the correct title.
          • Jason
            Jason says:
            July 20, 2023 at 12:03 pm
            I’m having a hard time believing that’s a 1/2″ cutter also… that looks like a cat50 on a Haas and proportion wise….that looks like a 3/4″ tool
  2. Jared Henry
    Jared Henry says:
    October 20, 2022 at 1:00 pm
    How does running the tool both directions (climb and conventional) affect the tool life? It certainly does make the operation faster.
      October 24, 2022 at 10:50 am
      Hello Jared,
      Great question! When running both conventional and climb milling the tool life would decrease but since you are able to machine faster, your end mill should perform the same. If you want to run both styles at the same time we suggest weighing out the benefits, do you need longer tool life or do you need to machine faster?
  3. Mike
    Mike says:
    October 27, 2022 at 2:52 pm
    I see that you’re not using coolant. Is this recommended, or just for demonstration?
      October 27, 2022 at 3:16 pm
      Hello Mike,
      In this video we did not use it for demonstration but to prolong tool life, in a real-world situation, we would have used coolant. We recommend using coolant when available and when chip packing and heat are a possible issue.
  4. Zachary Williamson
    Zachary Williamson says:
    July 21, 2023 at 7:18 am
    What are the machining parameters used, SFM, FPT and step over?
