end mill for titanium
Helical HVTI Cutter: High Efficiency Milling Titanium
January 3, 2020/2 Comments/in Gummy Materials, Helical Solutions, High Efficiency Milling, Material Specific, Tool Information Guides, Tools In Action/by Harvey Performance Company
End Mills for Titanium
Helical HVTI Titanium
WATCH THE HVTI IN ACTION
https://www.harveyperformance.com/wp-content/uploads/2020/01/Feature-Image-HVTI-IMG-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2020-01-03 10:00:302025-11-12 15:45:27Helical HVTI Cutter: High Efficiency Milling Titanium
graphite machining Grappling With Graphite: A Machining Guide
machining advisor pro Machining Advisor Pro Updated With New Improvements
milling machines Milling Machines vs. Lathe Machines
Miniature tool on penny How to Adjust Running Parameters for Miniature Tooling
tight tolerances Tips for Maintaining Tight Tolerances
  1. Benjamin McLeod
    Benjamin McLeod says:
    January 19, 2024 at 2:10 am
    I do not like the internal tool paths shown. It looks like taking a full width accross the open section of the H, then retracting full width, and repeat. It seems faster to me, if the machine would cut a slot (can use a rotating path if necessary) part way into the open section, so that the remaining distance in is the same as the remaining distance to each side of the H. Then it could cut on 3 sides and only retract on one, which would be 3X cut distance to retract distance ratio until the section is complete. This would not reduce the total time by that ratio, because the retract speed is faster than cut speed and it is only part of the retract time that is saved, but would still reduce time by a significant amount and also leave a better final finish because the left-right sides of the section would be cut continuously instead of in steps as shown.
    • Brian Andersen
      Brian Andersen says:
      January 15, 2025 at 4:22 am
      Sorry, you have clearly not worked with titanium and dynamic cutting before. Titanium is a very bad heat conductor so what you want to do requires very slow surface speed for the slotting. Titanium has the tendency to work hardening if you are not careful with the heat. It’s better to take thin side cuts and ramp up the feedrate then big thick cuts that eventually kill the cutter or the material.
