Downloading Tool Libraries
Selecting a Tool
Searching by Tool Number
Searching by Keyword
Searching by Tool Type
Searching by Tool Dimensions
Using Specialty Profile Tools
| Tool Name | Fusion 360 Name |
| Back Chamfer Cutter | Dovetail Mill |
| Chamfer Cutters | Chamfer Mill |
| Corner Rounding End Mill – Unflared | Radius Mill |
| Dovetail Cutter | Dovetail Mill |
| Drill/End Mill | Spot Drill |
| Engraving Cutter/Marking Cutter – Tip Radius | Tapered Mill |
| Engraving Cutter – Tipped Off & Pointed | Chamfer Mill |
| Keyseat Cutter | Slot Mill |
| Runner Cutter | Tapered Mill |
| Undercutting End Mill | Lollipop Mill |
| All Other Specialty Profiles | Form Mill |
Speeds and Feeds
Harvey Tool Speeds & Feeds
To access speeds and feeds information for your Harvey Tool product, head to http://www.harveytool.com/cms/SpeedsFeeds_228.aspx to find speeds and feeds libraries for every tool.
If you have further questions about speeds and feeds, please reach out to our Technical Support team. They can be reached Monday-Friday from 8 AM to 7 PM EST at 800-645-5609, or by email at [email protected].
To access speeds and feeds information for your Helical Solutions end mills, we recommend using our Machining Advisor Pro application. Machining Advisor Pro (MAP) generates specialized machining parameters by pairing the unique geometries of your Helical Solutions end mill with your exact tool path, material, and machine setup. MAP is available free of charge as a web-based desktop app, or as a downloadable application on the App Store for iOS and Google Play.
To learn more about Machining Advisor Pro and get started today, visit www.machiningadvisorpro.com. If you have any questions about MAP, please reach out to us at [email protected].
If you have further questions about speeds and feeds, please reach out to our Technical Support team. They can be reached Monday-Friday from 8 AM to 7 PM EST at 866-543-5422, or by email at [email protected].
For additional questions or help using tool libraries, please send an email to [email protected]. If you would like to request a Harvey Performance Company tool library be added to your CAM package, please fill out the form here and let us know! We will be sure to notify you when your CAM package has available tool libraries.
