In the Loupe TV: Avoiding Miniature Tool Breakage
January 3, 2025/4 Comments/in In the Loupe TV/by Harvey Performance Company
Have you ever broken a miniature tool? The “Cutting Tool Counselor,” Don Grandt is here to help! Miniature cutting tools, such as end mills, drills, and reamers, don’t run the same as a large standard end mills and adjustments must be made to run them optimally and to avoid tool failure. In this episode of in The Loupe TV, Don will walk you though what causes miniature tools to break and fail, and tips & tricks on how you can have success in your next miniature application.
Watch More From In the Loupe TV
https://www.harveyperformance.com/wp-content/uploads/2025/01/Feature-Image-Episode-28-ITLTV-Video.png 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2025-01-03 15:22:532025-01-03 15:22:55In the Loupe TV: Avoiding Miniature Tool Breakage
Itltv introduction to threadmills In the Loupe TV: Thread Mills vs. Taps
In the Loupe TV: Programming Thread Mills
In the Loupe TV: Continuous Time In Cut (CTIC)
In the Loupe TV: Helical 2024 Product Highlights
In the Loupe TV: Introduction to Circle Segment Machining
In the Loupe TV: Understanding Tool Engagement Angle
  1. James Chapman
    James Chapman says:
    February 5, 2025 at 1:51 pm
    I am using .090 dia. 2.25 long end mills to spot face to establish a flat surface for a 2.0mm spot drill. I need to stick them out 1.25 from toll holder nut due to parts being on an angle, tool holder nut could hit the parts. you did not cover plunge milling with micro tools on the miniature tool video. Any tips would be awesome. thank you
  2. James Chapman
    James Chapman says:
    February 5, 2025 at 1:52 pm
    I am using .090 dia. 2.25 long end mills to spot face to establish a flat surface for a 2.0mm spot drill. I need to stick them out 1.25 from toll holder nut due to parts being on an angle, tool holder nut could hit the parts. you did not cover plunge milling with miniature tools on the miniature tool video. Any tips would be awesome. thank you
  3. Rick
    Rick says:
    June 3, 2025 at 12:59 pm
    Using a .062 ball mill to add a relief to the side of a spline tooth. How deep do you suggest for each pass?
    • Greg Schranze
      Greg Schranze says:
      July 2, 2025 at 10:14 am
      Hi Rick,
      This question is best answered with more context regarding your flute count, what your tool SKU is, etc. Please reach out to our technicians in order to best assist you. You can give a call (800 645 5609 then 2 for tech) or email ([email protected]) in order to receive direct assistance from our team.
