    • ITC
In the Loupe TV: Helix Angles
August 5, 2022/0 Comments/in In the Loupe TV/by Harvey Performance Company
Join Harvey Performance Company National Applications Engineer Don Grandt in the fourth episode of In the Loupe TV: Helix Angles.
While many factors impact the outcome of a machining operation, one often overlooked factor is the cutting tool’s helix angle. The helix angle of a tool is measured by the angle formed between the centerline of the tool and a straight line tangent along the cutting edge. Tune into this episode of In the Loupe TV to learn about helix angles and what angle you should be opting for in your next CNC machining application.
Watch More From In the Loupe TV
https://www.harveyperformance.com/wp-content/uploads/2022/08/ITLTV-Ep-4.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2022-08-05 09:42:322022-11-07 14:25:59In the Loupe TV: Helix Angles
In the Loupe TV: Material Removal Rate Triangle
In the Loupe TV: Minimizing Chips With Chipbreakers
In the Loupe TV: Cutting Tool Coatings
In the Loupe TV: Harvey Tool Spring 2024 Highlights
In the Loupe TV: Using High Feed End Mills
In the Loupe TV: Back Taper On Drills
