Hi,
I would like to know if there is a cost attached to the use of Machining Advisor Pro. I am retired and doing some hobby cnc milling with wood at home. Unfortunately I would not be able to pay much since I do not have any income. If there is a cost attached perhaps you could recommend some other source to get the information for the few cutters I have.
Thanking you in advance,
Gerd Rutkowski
There is no cost associated with Machining Advisor Pro, the application is completely free to use!
