machining precious metals
Machining Precious Metals
July 1, 2019/10 Comments/in How-To's, Machining Techniques, Material Specific/by Robert Keever
About the Elements
  1. Ruthenium (Ru)
  2. Rhodium (Rh)
  3. Palladium (Pd)
  4. Silver (Ag)
  5. Osmium (Os)
  6. Iridium (Ir)
  7. Platinum (Pt)
  8. Gold (Au)
periodic table with a box around the 8 precious metals
material properties of precious metals in relation to 6061 and 4140
thermal conductivity of silver, gold, copper, and aluminum
pgm material properties
Tools for Precious Metals
variable helix square aluminum end mill from harvey tool
harvey tool pcd diamond square end mill
Speeds and Feeds charts:
speeds and feeds chart for precious metals
speeds and feeds chart for precious metals with a pcd end mill
https://www.harveyperformance.com/wp-content/uploads/2020/07/Machining-Precious-Metals.jpg 600 1599 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2019-07-01 12:58:512023-10-24 10:50:51Machining Precious Metals
end mill anatomy The Anatomy of an End Mill
machining advisor pro Get to Know Machining Advisor Pro
anderson prototypes Anderson Prototypes – Featured Customer
graphite machining Grappling With Graphite: A Machining Guide
stainless steel machining Slaying Stainless Steel: Machining Guide
  1. Richard
    Richard says:
    July 12, 2019 at 8:43 pm
    This article had some good info but it lacked any data relative to Sterling Silver and 10k-14k gold. I would find it really helpful if you were able to identify cutters withan 1/8″ shank that would do really well with Sterling silver and 14l gold.
    Would those PCB diamond tools be best or is there something better for longer life?
    Thanks
    • Jill Chergey
      Jill Chergey says:
      July 15, 2019 at 11:43 am
      Hi Richard- Sterling Silver is a Silver alloy with around 92% silver and 8% copper therefore a non-ferrous alloy cutter can be used at the recommended speeds and feeds under “Silver Alloys”. For machining 10K-14K gold it really depends on the nickel content as this is a hardening alloy and may be more difficult to machine. If you would like to play it safe a PCD cutter would have no trouble cutting through 10K-14K gold as these types of cutters can be used to cut pretty much anything that is non-ferrous. A PCD cutter will also give you the longest tool life.
  2. Shaylee Packer
    Shaylee Packer says:
    December 4, 2019 at 9:18 am
    The science behind creating these precious metals just blows my mind. It is so amazing that we are able to figure out what elements make up the metal and re-create it. I find it interesting that platinum has a high melting point, would that allow it to be used for higher temperature situations then other metals?
  3. Kelsey Hockenberry
    Kelsey Hockenberry says:
    August 7, 2020 at 1:34 pm
    Hello! I have a few drawings I would like to see if you would be able to quote for me ? Are you able to provide me an email I can send these for your review?
    Thank you so much!
      August 10, 2020 at 8:09 am
      Yes! Depending on the size and profile you can email [email protected] or [email protected].
  4. yoram rami
    yoram rami says:
    October 29, 2020 at 9:46 am
    Hi.
    thank you for the information.
    do you have any idea of pure silver circular saw cutting parameters?
      October 29, 2020 at 10:07 am
      Please send an email to [email protected] with all your information and application information and they will be able to help you.
  5. Tex Hooper
    Tex Hooper says:
    August 18, 2021 at 9:10 pm
    I didn’t know that different metals have different material properties. I need someone who can machine some steel pipes for me. I’ll have to consider getting a contractor who can weld everything for me.
  6. Slawek
    Slawek says:
    March 15, 2023 at 1:20 pm
    I have a tool with a diameter of 0.5mm (0.020in): 0.020×1/8×0.100×2-1/2 from Accupro. My CNC machine is a Haas OM-2. I have problems with processing platinum because the cutter breaks after an hour of work. The cutter performs work in an arc with an angle of 7.4 degrees to a depth of 1.6mm. The primary arc window is 0.4mm wide. the cutter is supposed to widen it to 0.5 so it collects only 0.05mm on the side. what feed rate and spindle speed to choose? I used spindle speed S2500 and feed rate F10. But the tool broke after making 8 windows (about 60 minutes of work).
    What can I improve in my work so that the cutter can withstand, for example, 20 windows.
    Thank you!
      March 15, 2023 at 2:28 pm
      Great question, I suggest reaching out to [email protected] with all the information about the application. One of our technical associates will be able to dive deeper into your application and find the best possible solution for you.
