December 10, 2024/4 Comments/in CNC Machining, Drilling, Drilling & Holemaking, Getting Started, Holemaking, Large Featured, Machining 101, Machining Techniques, Material Specific, Tool Geometry, Tool Information Guides, Tool Selection/by Emily Van Volkom
When it comes to achieving precision in CNC drilling applications, the choice of tools and techniques can make a significant difference in the outcome. One essential element that often doesn’t get the spotlight it deserves is the Pilot Drill. This blog post will explore the importance of pilot drills, their applications, and best practices for integrating them into your CNC machining processes.
What is a Pilot Drill?
A pilot drill is used to create a guide hole in deep drilling applications where precision is required. This guide hole keeps the drill on center, maintaining straightness throughout the cut. By creating a pilot hole, machinists can also improve the quality of the finished product and extend the life of their tools.
The Importance of Pilot Drills in CNC Machining
1. Enhanced Accuracy
The primary advantage of using a pilot drill is the enhanced accuracy it provides. When working with harder materials or complex geometries, a small pilot hole helps maintain the alignment of the longer drill, reducing the risk of misalignment and defects.
2. Extended Tool Life
Using a pilot drill can significantly extend the life of your deep-hole drilling tools. By first creating a pilot hole, the chasing drill experiences less stress, reducing wear and tear, and the chance of breakage, ultimately leading to cost savings from longer tool life.
3. Improved Chip Removal
Pilot drilling can enhance chip removal, particularly in deep-hole drilling scenarios. The smaller pilot hole allows for better coolant flow, which is crucial for effective chip evacuation and maintaining optimal cutting temperatures.
Applications of Pilot Drills
Pilot drills are versatile and can be used in various applications, including:
  1. Deep-hole Drilling: Pilot holes create a guide when drilling deep holes for improved centering and straightness.
  2. Tapping Operations: A pilot hole can facilitate easier and more accurate tapping.
  3. Reaming: When preparing for reaming operations, a pilot drill can ensure the hole is properly aligned and sized.
  4. Screw and Bolt Holes: Pilot holes are essential for ensuring screws and bolts are inserted correctly and securely.
Best Practices for Using Pilot Drills
1. Application
Piloting is recommended for tighter tolerance holes when drilling at depths of 8xD or greater. Valor Holemaking provides a custom tolerance of +0.0002/+0.0005 (+0.005mm/+0.013mm) to create the perfect oversized guide hole for their traditional drill lines capable of drilling 8xD or greater. Valor Holemaking’s Pilot Drills also include a +2/+1 deg angle tolerance to ensure a larger angle than the chasing drill. Piloting depth is recommended as 3xD for all applications drilling 8xD or greater.
2. Choose the Right Size and Point Angle
Selecting the appropriate size for your pilot drill is crucial. As a rule of thumb, the diameter of the pilot hole should be slightly larger than the diameter of the final hole. This allows for optimal support for the chasing drill while preventing excessive material removal. The pilot drill’s point angle should be equal to or larger than the succeeding drill. This allows the tip of the succeeding drill to engage the material before the flank does (see figure below).
3. Optimize Feed Rates
When using a pilot drill, ensure that the feed rates are optimized for both the pilot and the larger drill. Adjusting the feed rate can improve performance and reduce the risk of tool breakage. Valor Holemaking’s downloadable speeds and feeds tables and Machining Adviser Pro are excellent resources, and you can always consult Valor Holemaking’s Tech Team for further assistance!
4. Use Proper Coolants
Effective cooling and lubrication are vital in metal machining. Ensure that your pilot drill is adequately cooled with flood coolant or adjust speeds and feeds to maintain tool integrity and enhance cutting performance.
5. Maintain Tool Condition
Regularly check the condition of your pilot drills. Worn or damaged pilot drills can lead to inaccuracies and affect the performance of subsequent operations.
6. Integrate with CNC Programming
Incorporate pilot drilling into your CNC programs to ensure that it’s executed at the right stage of your machining process. Program one revolution or brief dwell at the bottom of the pilot hole to ensure a clean surface. This will help streamline operations and improve overall efficiency.
Pilot drills may seem like a small detail in the larger scope of CNC machining, but their impact on precision, tool life, and overall efficiency is significant. By understanding their importance and implementing best practices, machinists can enhance their processes and achieve superior results. Whether you’re a seasoned CNC operator or just starting out, incorporating pilot drills into your workflow is a smart move that can lead to greater accuracy and success in metal machining.
Emily Van Volkom
Emily is a Product Development Engineer for Valor Holemaking, bringing a strong foundation in mechanical engineering from Queen Mary University of London. Passionate about advancing cutting tool technology, Emily focuses on driving innovation and delivering solutions for machining challenges.
https://www.harveyperformance.com/wp-content/uploads/2024/12/Featured-Image-Pilot-Drills-IMG.jpg 525 1400 Emily Van Volkom http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Emily Van Volkom2024-12-10 13:53:412025-01-30 09:11:16Mastering Precision: Pilot Drills in CNC Machining
Harvey Tool Harvey Tool: Behind the Scenes
contouring Contouring Considerations
work hardening Work Hardening and When it Should Scare You
Miniature tool on penny How to Adjust Running Parameters for Miniature Tooling
  1. Kirk Woods
    Kirk Woods says:
    January 17, 2025 at 11:09 pm
    I don’t get it. OVERSIZED hole? How can it guide a drill if there is clearance between the wall and the smaller drill?
    • Darren Kern
      Darren Kern says:
      July 9, 2025 at 12:42 pm
      Hello Kirk, The +.0002/+.0005 on the diameter will eliminate any interference when you bring the deep hole drill into the pilot diameter. When the drill enters the point where the pilot stopped , it will have a max allowable deflection amount of .0002/.0005 on diameter, giving the margins a pilot surface to guide the deep hole drill to create a straight hole. I hope this helps.
  2. tito
    tito says:
    July 1, 2025 at 9:17 am
    this is not a pilot. this is a counterbore or a guide hole.
    • Darren Kern
      Darren Kern says:
      July 9, 2025 at 12:49 pm
      The term pilot and guide are similar. A pilot drill is used to create a slightly larger hole to aid in the guidance for a deep hole drill in a deep hole drilling operation.
