NEXT GENERATION 6
Innovative, patent-pending geometry, developed and engineered by ATA, to accelerate the manufacturing process and increase product life.
We’re always up for a challenge and here at ATA, we took your challenge to research and develop the next generation of carbide burs, that would have a longer life, grind material faster, grind for longer, perform better, and yet still give a great finish.
Now we offer you this new innovation – the NEXT GENERATION 6 Carbide Bur.
NEXT GENERATION 6, revolutionising the market.
Demonstrated to remove up to 75% more stock on Mild Steel during the first 5 minutes of grinding when tested against other leading premium-quality comparable burs.
- With the ACCELERATOR coating, the rate of stock removal is up to DOUBLE that of other leading comparable burs.
- The NEXT GENERATION 6, along with the ACCELERATOR coated option, outperforms all comparable carbide burs on Steel, Stainless Steel, Mild Steel and Cast Iron.
When manufacturing and fabricating with heavy metals in challenging industries, the NEXT GENERATION 6 geometry gives you a faster, more aggressive stock removal without negatively affecting user comfort.
