machinist looking at end mill trying to understand nickel alloys
Understanding Nickel Alloys and Their Properties
April 4, 2022/2 Comments/in Helical Solutions, Material Specific/by Will Lauzon
What is Nickel Alloy?
Nickel-based alloys have been a cornerstone of manufacturing for decades, desirable for their broad range of varying resistances to heat, oxidation, and corrosion. Nickel alloys also have a high strength-to-weight ratio and superior electrical conductor abilities. Because of these mechanical and chemical properties, they are primarily used in aerospace, oil, electrical, and chemical industries.
Understanding this valuable metal and how to properly machine it is imperative to delivering an optimal final part.
cnc machining nickel alloys
Machining Nickel Alloys. Image source: IMS-Stainless.com
Nickel Alloy Chemical Composition and Classification
Nickel is commonly found in the form of an alloy, as its crystalline structure allows the element to be paired well with other metals. These atoms are arranged in a face centered cubic lattice; this structure is shown in figure 1 below.
Drawing that shows lattice structure of Nickel
Lattice structure of Nickel. Image source: PriyamStudyCentre.com
The Atomic Configuration of Nickel
According to Priyam Study Centre’s Learning Chemistry, an open face lattice has the highest atomic packing number (the number of atoms per unit volume) of any metallic lattice configuration, with an atom present at each of the 6 faces and 8 corners of the cube. This structure is largely responsible for nickel’s strength and ability to create strong metallic bonds to chromium, cobalt, iron, and molybdenum, the most common metals found in these alloys.
Categorization of Nickel Alloys
According to City Special Metals’ article on Machining Nickel and Nickel Alloys, nickel alloys are organized into five main categories: Groups A through E. These groups are determined through the percentage of nickel present, as well as the most prominent metal that the nickel is chemically bonded with.
Table 1 displays the breakdown of these groups, showing each group’s chemical composition and a few examples of common types of nickel alloys found in that category.
GroupPercentage of NickelPaired MetalsExamples
Group A95% and greaterAlmost pure nickelNickel 200, 201, 205, and 212
Group B29% to 42%CopperMonel 400, Invar 36
Group C70% to 75%Chromium and ironInconel 600, Monel K-500, and Nickel 270
Group D50% to 56%Chromium and ironInconel 718, Inconel 625, and Hastelloy C-22
Group E63%Copper and ironMonel R405 is the only Nickel alloy in this category
Table 1: Categories of nickel alloys and their chemical compositions. Table data source: Machining Nickel and Nickel Alloys: A Guide from CSM; Nickel Based Alloys: Everything You Need to Know.
Significance of Understanding Composition
Understanding your workpiece material is just as important as understanding your machinery and tools. According to Global Market Insights (GMI), the nickel alloy market has been growing over 4% each year since 2017, and this growth is seeing an upward trend. As these alloys increase in popularity and demand, knowing the chemical compositions and classification of your specific workpiece will play a key role in successfully machining it.
Fabricating products made of nickel alloys present common struggles in every machine shop. Learn how to select proper tooling and implement machining techniques to overcome these challenges by reading CNC Machining Nickel Alloys: Avoiding All-Too-Common Mishaps.
Will Lauzon( Harvey Performance Company Technical Associate )
As a member of Harvey Performance Company’s technical team, Will works with customers to answer questions regarding tool selection, speeds & feeds, custom tool design and tool applications. Will earned his Bachelor’s degree in Mechanical Engineering from UNH.
https://www.harveyperformance.com/wp-content/uploads/2022/04/Feature-Image-Nickel-Alloys-1-IMG.jpg 525 1400 Will Lauzon http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Will Lauzon2022-04-04 11:34:292025-11-20 09:50:25Understanding Nickel Alloys and Their Properties
  1. Jessie Holloway
    Jessie Holloway says:
    January 25, 2023 at 11:16 am
    I love how you point out that nickel alloys are able to withstand corrosion and heat better than their counterparts. My uncle has a large project going on his property and he’s been talking about needing some metal alloys for the next few steps. We’ll have to look into finding a supplier to help him get the metal he needs.
  2. Kevin Dsouza
    Kevin Dsouza says:
    January 18, 2025 at 1:00 am
    I found the blog on Nickel Alloys by Harvey Performance to be highly informative. It provides an excellent overview of the chemical composition and classification of various nickel alloys. The detailed breakdown of the different categories—such as Group A and Group D alloys—was exactly the information I needed. Understanding the lattice structure and material properties of nickel-based alloys is key to selecting the right material for various industrial applications. I’ll definitely be referencing this guide in future projects.
