April 25, 2017/7 Comments/in CNC Machining, How-To's, Machining 101, Quick Tips, Troubleshooting Tips/by Harvey Performance Company
Part Finish Reference Guide
Common Finishing Problems
  • Burrs
  • Scallop marks
  • Chatter Marks
Factors That Influence Part Finish
  • Specific material and hardness
  • Cutting tool speeds & feeds
  • Tool design and deployment
  • Tool projection and deflection
  • Tool-to-workpiece orientation
  • Rigidity of workholding
  • Coolant and lubricity
  • Final-pass depth of cut
Finishing Problem Solutions
  • Tools with high helix angles and flute counts work best for finishing operations. Softer materials show great results with higher helices, while harder materials can benefit greatly from increased flute counts.
  • Increase your RPM and lower your IPT (Figure 2).
  • Ensure that tool runout is extremely minimal.
  • Use precision tool holders that are in good condition, are undamaged, and run true.
  • Opt for a climb milling machining method.
  • Use tooling with Variable Pitch geometry to help reduce chatter.
  • A proper radial depth of cut (RDOC) should be used. For finishing operations, the RDOC should be between 2 and 5 percent of the tool’s Cutter Diameter.
  • For long reach walls, use reduced neck tooling which help to minimize deflection (Figure 3).
  • Extreme contact finishing (3x cutter diameter), may require a 50% feed rate reduction.
part finish guide
length of cut
Common Surface Finish Nomenclature
Ra = Roughness average
Rq = RMS (Root Mean Square) = Ra x 1.1
Rz = Ra x 3.1
part finish guide
  1. Juan Lugo
    Juan Lugo says:
    August 11, 2018 at 10:02 am
    What is IPT?
    • Tim Lima
      Tim Lima says:
      August 13, 2018 at 8:18 am
      Hi Juan! IPT = Inches Per Tooth. Chip load per tooth is the appropriate amount of material that one cutting edge of the tool should remove in a single revolution. This is measured in IPT.
  2. Paul Pela
    Paul Pela says:
    April 1, 2021 at 10:47 am
    I’m going have to disagree with you — Increase your RPM and lower your IPT (Figure 2). ??? did a machinist write this – i think not – he would know better
    • russel ay
      russel ay says:
      April 28, 2022 at 12:07 pm
      Uhm, yes? Increasing your finishing usually gives a better finishing. Decrasing your IPT reduces the “steps” in your final finish (You can also choose using a bigger diameter tool, when posible)
  3. Pete
    Pete says:
    April 1, 2021 at 3:15 pm
    Why don’t you make some high flute count alu finishers? This would really speed up alu finishing passes. I could really use a 1/4”, .75loc, 6 or so flute alu finisher.
      April 2, 2021 at 11:09 am
      Hello Pete,
      Thank you for your suggestion, we will pass this along to our New Product Development team so they can look into this further.
  4. David Zelonis
    David Zelonis says:
    July 2, 2021 at 8:07 pm
    I have been machining for several decades.
    That’s how I would get a better (Ra) surface finish, slower feed per tooth and/or a higher RPM.
https://www.harveyperformance.com/wp-content/uploads/2017/04/Feature-Image-Part-Finish-Reference-Guide-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-04-25 12:30:242022-06-08 09:21:37How to Avoid Common Part Finish Problems
Micro 100 Holiday Giveaway
BrickTactical Brick Tactical – Featured Customer
CNC Woodworking: Understanding Wood Properties
2023 CNC Cutting Tool Survey
  1. Juan Lugo
    Juan Lugo says:
    What is IPT?
    • Tim Lima
      Tim Lima says:
  2. Paul Pela
    Paul Pela says:
    • russel ay
      russel ay says:
  3. Pete
    Pete says:
      Hello Pete,
  4. David Zelonis
    David Zelonis says:
