June 19, 2018/17 Comments/in CNC Machining, Helical Solutions, Material Specific, Tech Tips, Trending Now/by Harvey Performance Company
stainless steel machining
Traditional Roughing
The axial engagement of a tool in a slotting operation should be suitable for the specific tool employed, as depicted in Figure 3. Employing an unsuitable method may result in tool deflection, potential damage, and compromised part quality. Chip evacuation is going to be key for slotting in stainless steel. For this reason, 4 flute tools are the best choice because the lower flute count allows for more efficient chip evacuation. Tools with chipbreaker geometry also make for effective slotting in stainless steel, as the smaller chips are easier to evacuate from the cut.
High Efficiency Milling
High Efficiency Milling (HEM) can be a very effective machining technique in stainless steels if the correct tools are selected. Chipbreaker roughers would make an excellent choice, in either 5 or 7 flute styles, while standard 5-7 flute, variable pitch end mills can also perform well in HEM toolpaths.
HEV-5
Machining Advisor Pro
machining advisor pro ad
https://www.harveyperformance.com/wp-content/uploads/2018/06/Feature-Image-Slaying-Stainless-Steel-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-06-19 15:30:022023-12-15 15:25:56Slaying Stainless Steel: Machining Guide
Traditional vs Free Cutting Honeycomb Core Tools
tight tolerances Tips for Maintaining Tight Tolerances
How to Combat Chip Thinning
cutting tool helix angles Benefits & Drawbacks of High and Low Helix Angles
Michigan FSAE University of Michigan Formula SAE Racing Team
Fusion HSM Tool Libraries Using Tool Libraries in Autodesk HSM & Fusion 360
  1. Stanley D Holland
    Stanley D Holland says:
    June 22, 2018 at 10:14 am
    I have a need for a 6.5 inch long 11/64ths (.171 inch) end mill or drill/mill that I can use to drill holes in steel then begin the side-to-side milling process. I do engraving work and I sometimes need to make my own jigs to hold various items to be engraved.
    I made my own drill tool using one of my broken cutters and it worked, but I am certain there has to be a better more efficient way of doing business.
      June 22, 2018 at 2:46 pm
      Hi Stanley,
      I would recommend giving our tech team a call to talk through this application and see how we can help. You can reach them by calling 800-645-5609 or by emailing to [email protected]
  2. Jasmine Paulos
    Jasmine Paulos says:
    January 18, 2019 at 6:11 am
    This is really very very interesting and informative too, You contain a lot of information in a single article regarding this, Thank you for sharing your knowledge. Keep updating us with your knowledge.
  3. Best Copper Slag Manufacturer in India
    Best Copper Slag Manufacturer in India says:
    January 30, 2019 at 1:45 am
    Thank you for this interesting blog
  4. Duraslide Pte Ltd
    Duraslide Pte Ltd says:
    March 19, 2019 at 7:57 am
    Very interesting, Good job and thanks for sharing such a good information.
  5. Anuj Sharma
    Anuj Sharma says:
    July 31, 2019 at 3:45 am
    Thanks a lot for sharing a valuable content
  6. Dylan Peterson
    Dylan Peterson says:
    September 9, 2019 at 1:36 pm
    It’s awesome that stainless steel is designed to resist corrosion due to their high chromium content. My boss has been telling me about how he wants to build a new machine this quarter for use outside, and he wants to make sure that it can stand up to the weather. I’ll pass this information along to him so that he can look further into his options for using stainless steel.
  7. Corten
    Corten says:
    February 21, 2021 at 1:35 am
    First time in my life I am seeing a machine. Good job and thanks for sharing such a piece of good information.
  8. Anna
    Anna says:
    March 20, 2021 at 11:22 am
    First off, you should know the difference between hard and soft steel. Hard steel is often used for things like bicycles and cars, while soft steel is usually what you will find used in machining. If you need a lot of precision, then you will probably want to get the hard steel, since it is often much more durable and better able to withstand the pressure that you are going to be putting on it. However, if you do not have a lot of extra money to spend, then you may want to consider soft steel, because it will still stand up to the pressure of the job, but it is not as dense as hard steel.
    Second, when you are looking to use a machine on the surface of the steel, it is important that you use the right tool for the job. For example, if you are going to be working on a soft steel, then you should not use a drill or a shredder, because these will likely scratch the surface of the material, making the entire thing less resistant to the processes that you are having done. Instead, you will want to use a special type of saw, one that cuts slits into the metal at different angles, in order to make small holes, rather than drilling the entire thing. This Slaying Stainless Steel: Machining Guide tip should help you with this, so that you can get the most accurate results from the equipment that you are using.
  9. Tex Hooper
    Tex Hooper says:
    September 7, 2021 at 9:07 pm
    It seems like HEV-5 is better for my project. I need to get a new CNC machine for the warehouse. I’ll have to get something with a remote power source.
  10. Alex hales
    Alex hales says:
    October 15, 2021 at 10:50 am
    I like how you said that stainless steel cookware can be seasoned and sealed to be more easily cleaned just like cast iron can be. My wife and I would really like to have some good nonstick pans. We’ll have to look into getting some good cookware that will give us those benefits, or that we can add the benefits to.
  11. okmarts company
    okmarts company says:
    October 25, 2021 at 1:12 am
    It’s amazing!! Learn a lot.
  12. TNN Engineering
    TNN Engineering says:
    January 20, 2022 at 2:06 am
    Nice content and guide that everyone can refer through.
  13. Builder Hardware
    Builder Hardware says:
    August 3, 2022 at 5:32 am
    I liked your content related to Machining Guide for stainless steel. You have well explained the guide for machinings.
  14. Daisy James
    Daisy James says:
    January 10, 2023 at 2:15 pm
    It was helpful when you said to choose the right tooling. My husband was telling me yesterday afternoon at lunch about how he plans on finding a disturb for stainless steel at his work in a couple of weeks. I’ll pass these tips along to him so he can know more about working with stainless steel properly.
  15. Tex Hooper
    Tex Hooper says:
    January 23, 2023 at 4:49 pm
    I appreciate what you said about using a 5 flute end. My office needs some steel sheets milled out. I’ll have to have a manufacturer design something to my specifications.
  16. Stainless Steel Fabrication Auckland
    Stainless Steel Fabrication Auckland says:
    April 3, 2023 at 1:28 am
    I was looking for this information relating to slaying stainless steel: machining guide. You have really eased my work, loved your writing skill as well. I like how you have researched and presented these exact points so clearly. Please keep sharing more!
