shank tolerances
Shank Tolerances, Collet Fits, & h6 Benefits
August 14, 2018/3 Comments/in CNC Machining, Machining 101, Machining Techniques, Tech Tips, Tool Selection/by Robert Keever
A cutting tool’s shank is one of the more vital parts of a tool, as it’s critical to the collet-tool connection. There are several types of shanks, each with their own tolerances and suitable tool holder methods. One of the most popular and effective tool holding styles is a shrink fit tool holder, which works with h6 shanks, but what does this mean and what are the benefits of it? How is this type of shank different from a shank with standard shank tolerances? To answer these questions, we must first explore the principals of tolerances.
The Principals of Tolerances
Defining Industry Standard Tolerances
There are two categories of shank tolerances that machinists and engineers operating a CNC machine should be familiar with: hole basis and shank (or shaft) basis. The hole basis system is where the minimum hole size is the starting point of the tolerance. If the hole tolerance starts with a capital “H,” then the hole has a positive tolerance with no negative tolerance. The shank basis system is where the maximum shank size is the starting point. This system is relatively the same idea as the hole basis system but instead, if the tolerance starts with a lowercase “h,” the shank has a negative tolerance and no positive tolerance.
Letter Designations
The limits of tolerance for a shank or hole are designated by the appropriate letter indicating the deviation. For instance, the letter “k” has the opposite minimum and maximum designations as “h”. Tolerances beginning with “k” are exclusively positive, while tolerances beginning with “h” are exclusively negative. The number following the given letter denotes the International Tolerance (IT) grade. For example, a tolerance with the number 6 will have a smaller tolerance range than the number 7, but larger than the number 5. This range is based on the size of the shank. A hole that has a 0.030” diameter will have an h6 tolerance of (+0.0000,-0.0002), while a 1.00” hole with have an h6 tolerance band of (+0.0000,-0.0005).
It is important to note that most sources list IT tolerances in millimeters, while the graph below has been translated to inches. Operations that require more precise manufacturing, such as reaming, will have lower IT grades. Operations that do not require manufacturing to be as precise will have higher IT grades.
graph showing shank tolerances vs diameter
Preferred Collet Fits
Different types of combinations of hole basis and shank basis tolerances lead to different types of collet fits. The following table offers insight into a few different types of preferred fits and the shank tolerances that are required for each.
infographic of collet fits and the associated clearance
Image: Machinery’s Handbook 29th Edition.
Shrink Fit Tool Holders
The shrink fit holder is one of the more popular styles of tool holders because of its ability to be more customizable, as evident in the chart above. In this method, a collet is heated to expand, then cooled to contract around the shank of a tool. At room temperature, a cutting tool should not be able to be inserted into a shrink fit holder – only when the holder has undergone thermal expansion due to the introduction of a significant amount of heat should the tool fit. As the holder cools, the tool is held tighter and tighter in place. Typically, a holder is heated through a ring of coils by an induction heater. It is important to heat the holder uniformly, paying mind to not overheat it. Doing so could cause the shank that is being held to expand within the holder and remain stuck.
Benefits of Shrink Fit Tool Holders
  1. Gripping power. The shank is held flush and uniform against the holder, resulting in a tighter connection.
  2. Low runout. A more secure connection will result in extended tool life, and a higher quality surface finish.
  3. Better balance for high RPM. With a tighter tool-to-holder connection, the opportunity exists for more aggressive running parameters.
Explore More About Tool Holders With Our Cutting Tools Explained Webinar
Shank Tolerances Summarized
Understanding shank tolerances is an intricate part of the machining process as it impacts which tool holder is appropriate for your job. A secure holder connection is vital to the performance of the tool in your application. With an h6 shrink fit holder, the result is a secure connection with stronger gripping power. However, only certain shanks are able to be used with this type of holder. From the letter designation assigned to a shank, to whether that letter is upper or lowercase, each detail is vital to ensuring a proper fit between your tools shank and its corresponding shrink fit holder.
https://www.harveyperformance.com/wp-content/uploads/2018/08/Feature-Image-Shank-Tolerances-Collet-h6-Benefits-IMG.jpg 525 1400 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2018-08-14 08:23:422023-10-24 10:47:22Shank Tolerances, Collet Fits, & h6 Benefits
high efficiency machining Applying HEM to Micromachining
machining aluminum Attacking Aluminum: a Machining Guide
BrickTactical Brick Tactical – Featured Customer
  1. Dallen Helmer
    Dallen Helmer says:
    November 29, 2023 at 10:10 pm
    Are all harvey tools or at least most of them h6 shanks to be able to fit in heat shrinks? i don’t see it listed any where but using a iso chart based on size of the end mills most seems to fall in line
    • Greg Schranze
      Greg Schranze says:
      February 1, 2024 at 11:55 am
      Hi Dallen,
      The majority of our tools are held to a h6 tolerance, you can identify whether or not the tool family holds that specification at the top of the tool table in the catalog or our website. That h6 tolerance will ensure that the tooling you order is capable of being held in shrink fit tool holders!
Trackbacks & Pingbacks
  1. Weekly Blog Roundup: August 31, 2018. - BlackHawk Industrial Blog says:
    November 5, 2018 at 3:21 pm
    […] Shank Tolerances, Collet Fits, & h6 Benefits […]
