cnc deburring
March 13, 2018/14 Comments/in CNC Machining, Machining 101, Machining Techniques, Quick Tips, Specialty Tools, Titan USA, Tool Selection/by Harvey Performance Company
High Precision Tools
red hand deburring tool
examples of cnc undercutters and chamfer mills
machinist hand deburring with a motorized hand tool
https://www.harveyperformance.com/wp-content/uploads/2018/03/Feature-Image-Stop-Deburring-by-Hand-IMG-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-03-13 16:26:182024-02-12 14:37:41Why You Should Stop Deburring by Hand
Tib2 coating What to Know About Harvey Tool’s TiB2 Coating
contouring Contouring Considerations
HSS vs Cobalt vs Carbide: Choosing a Tool Substrate
tolerance stacking Best Practices of Tolerance Stacking
  1. randy
    randy says:
    March 15, 2018 at 10:50 am
    Can you show a picture of an edge chamfered with a Deburring Chamfer Cutter looks like? Particularly in aluminum. Thanks.
  2. Robby
    Robby says:
    March 15, 2018 at 11:00 am
    What is the advantage of these deburring tools over standard cutting endmills with the same profiles?
      March 15, 2018 at 11:28 am
      Hi Robby,
      While some of the deburring tools have the same profiles as standard end mills, the deburring tools have a higher flute count to allow for higher speeds and feeds and a superior finish. They also have a double cut flute style and bur geometry made specifically for removing burrs.
      These tools wouldn’t cut like a regular end mill – they are specifically designed for deburring.
      You can learn more about these tools by visiting our website: http://www.harveytool.com/cat/Deburring-Solutions/Browse-Our-Products_266.aspx
  3. Paul Mutzek
    Paul Mutzek says:
    March 17, 2018 at 3:32 pm
    A video would be nice, especially cnc deburring the type of part that would take an hour by hand that you mentioned. Those types of parts would need more “deburring” programming than just a standard 2D contouring op. I’d like to see what you’re suggesting in action.
    • Edward F.
      Edward F. says:
      August 24, 2021 at 11:59 am
      I agree, there’s a lot of marketing wank in this post, screw all the claims, show us some proof. Trying to program a tool to de-burr small nooks and crannies is a pain in the ass, at that point it’s more cost effective to just hand finish them.
  4. Chris
    Chris says:
    April 10, 2018 at 10:48 am
    Pauk Mutzek is right, show us what these can do! Teach us how to use these tools and I promise we’ll buy them!
      April 10, 2018 at 10:55 am
      Hi Chris,
      Thank you for the feedback and interest in the tools! We will work towards having some more videos and content around these tools for you, Paul, and many others who have asked!
  5. Cory M. PIO
    Cory M. PIO says:
    May 10, 2018 at 10:18 pm
    To Paul and Chris if you want to debut complex 3d contours in a program like mastercam I would be happy to show you email me at [email protected]. there is a certain workflow to this and once you see the right way to do it you’ll never go back to your old ways especially with high value and high quantity orders.
  6. Sandra Patterson
    Sandra Patterson says:
    May 2, 2019 at 7:31 pm
    I think it is really cool how CNC deburring tools have double cut patterns and multiple flutes versus a hand deburring tool that only has one blade. In my personal opinion, that sounds a lot more efficient than using the hand tool to clean up a piece of machined metal. I also thought it was interesting how you said that these new tools leave much more consistent and controlled edge breaks.
  7. Dave Anderson
    Dave Anderson says:
    May 21, 2019 at 2:27 pm
    That is interesting that there is a sharp hook-shaped blade that scrapes off burrs. It would be good to get a machine to do these micromachining processes. Then I wouldn’t have to worry about my hand cramping up or anything when paying attention to detail.
  8. Thomas Westgren
    Thomas Westgren says:
    May 30, 2019 at 2:49 pm
    It’s really nice how you said that CNC machining can help to finish parts in one go, rather than multiple sessions. This would be really helpful because it would help you to save time and money. Your parts would be of a higher quality as well!
  9. Sergio Ramirez
    Sergio Ramirez says:
    January 14, 2020 at 12:41 pm
    I would like to see some undercutting deburr tools , deburring the backside of a port. A video would be nice. I’m ordering some now, and will test them out.
      January 14, 2020 at 12:53 pm
      Thank you for the feedback Sergio. We are always wondering what people want to see, we will work on gathering video of a Deburring Undercutter!
  10. Chris
    Chris says:
    July 31, 2020 at 11:31 am
    I agree with previous comments… Videos!!
