Tag Archive for: Amorphous Diamond
Machining Precious Metals
About the Elements
  1. Ruthenium (Ru)
  2. Rhodium (Rh)
  3. Palladium (Pd)
  4. Silver (Ag)
  5. Osmium (Os)
  6. Iridium (Ir)
  7. Platinum (Pt)
  8. Gold (Au)
machining metals
precious metals
machining metals
machining metals
Tools for Precious Metals
machining metals
machining metals
Speeds and Feeds charts:
machining metals
machining metals
  • Increased tool life.
While many manufacturers will specially coat a standard end mill at your request, this takes added time and cost. In its Material Specific catalog sections, Harvey Tool offers coated tools stocked and ready to ship. For instance, their Hardened Steels and Exotic Alloys categories utilize AlTiN Nano coating. This is a unique nanocomposite coating that has a max working temperature of 2,100° F and shows improved performance in materials such as Hardened Steels, Titantium Alloys, and Inconel, among others.
Miniature End Mill
Part Number: 836408
Material: 6061 Aluminum
Application: Slotting
Speed: 10,000 RPM
Chip Load: .00124 IPT
Linear Feed: 37.2 IPM
DOC: .04375
Part Number: 942308
Speed: 10,000 RPM
Chip Load: .00165 IPT
Linear Feed: 49.5 IPM
DOC: .0625
Extensive Cost Savings
material specific tooling benefit chart
Composite Materials
  2. Uncut Fibers
  3. Fiber tear-out
  4. Uneven tool wear
Straight Flute End Mill
straight flute end mill
Compression Cutters
compression cutter end mill
Chipbreaker Cutter
Diamond Cut End Mill
Composite Finisher
Coating or No Coating?
