Tag Archive for: back deburring mills
Drill/End Mills
drill mills
drill mill operations
Undercutting End Mills
undercutting end mills
Double Angle Shank Cutters
double angle shank cutters
Flat Bottom Tools
flat bottom tools
flat bottom tools
Adjustable Chamfer Cutters
adjustable chamfer cutters
chamfer cutter inserts
High Precision Tools
hand deburring
cnc deburring
cnc deburring
multiaxis machining
6 Uses of Double Angle Shank Cutters
Thread Milling
thread milling
Chamfering
chamfering with Double Angle Shank Cutter
Back Chamfering
back chamfering
Machining V-Grooves
machining v-grooves
Deburring
deburring with Double Angle Shank Cutter
Countersinking
Countersinking a part  is done so a screw, nail, or bolt is able to sit flush with the part surface. Using specialty profile tooling can help enlarge the rim of a drilled hole and bevel the sides for a screw to sit accurately. A Double Angle Shank Cutter can also perform this operation by using the bottom portion of its cutting face.
Double Angle Shank Cutter for countersinking
