  • Traditional Roughing
  • Slotting
  • Finishing
  • Contouring
  • Plunging
  • High Efficiency Milling
Material:
Application:
guide for proper end mill selection
Length of Cut & Reach
Tool Profile
end mill selection
  • Prolonged Tool life
  • Improved Chip Evacuation
Recent  Advances
Increased Time Savings
Reduced Cycle Times
Improved Consistency
CNC Contouring planes
CNC Contouring ball end mill
multiaxis machining
The Anatomy of an End Mill
Flutes
end mill flute patterns
End Mill Profiles
Square Profile End Mills
Ball Profile End Mills
end mill cutter diameter
Shank Diameter
end mill neck
End Mill Helix Angle
helix angle
Pitch
variable pitch
ball nose
Shop Harvey Tool’s Vast Selection of Ball Profile End Mills – Click Here to Get Started
ball nose effective cutting diameter chart
ball nose cutting diameter calculation
ball nose compensated speed calculation
KEY
ADOC = Axial Depth of Cut
D = Cutting Diameter
R = Tool Radius (Dia./2)
RDOC = Radial Depth of Cut
SFM = Surface Feet per Minute
Sc = Compensated Speed
ball nose milling with tilt angle
KEY
