Tag Archive for: Chip Evacuation
The Secret Mechanics of High Feed End Mills
December 11, 2020/1 Comment/in Helical Solutions, Machining 101, Tool Information Guides/by Robert Keever
A High Feed End Mill is a type of High-Efficiency Milling (HEM) tool with a specialized end profile that allows the tool to utilize chip thinning to have dramatically increased feed rates. These tools are meant to operate with an extremely low axial depth so that the cutting action takes place along the curved edge of the bottom profile. This allows for a few different phenomena to occur:
  • The low lead angle causes most of the cutting force to be transferred axially back into the spindle. This amounts to less deflection, as there is much less radial force pushing the cutter off its center axis.
  • The extended curved profile of the bottom edge causes a chip thinning effect that allows for aggressive feed rates.
The Low Lead Angle of a High Feed End Mill
As seen in Figure 1 below, when a High Feed End Mill is properly engaged in a workpiece, the low lead angle, combined with a low axial depth of cut, transfers the majority of the cutting force upward along the center axis of the tool. A low amount of radial force allows for longer reaches to be employed without the adverse effects of chatter, which will lead to tool failure. This is beneficial for applications that require a low amount of radial force, such as machining thin walls or contouring deep pockets.
high feed mill roughing
Figure 1: Isometric view of a feed mill engaged in a straight roughing pass (left), A snapshot front-facing view of this cut (right)
Feed Mills Have Aggressive Feed Rates
Figure 1 also depicts an instantaneous snapshot of the chip being formed when engaged in a proper roughing tool path. Notice how the chip (marked by diagonal lines) thins as it approaches the center axis of the tool. This is due to the curved geometry of the bottom edge. Because of this chip thinning phenomenon, the feed of the tool must be increased so that the tool is actively engaged in cutting and does not rub against the workpiece. Rubbing will increase friction, which in turn raises the level of heat around the cutting zone and causes premature tool wear. Because this tool requires an increased chip load to maintain a viable cutting edge, the tool has been given the name “High Feed Mill.”
high feed end mill ad
Other Phenomena Due to Curved Geometry of Bottom Edge
The curved geometry of the bottom edge also sanctions for the following actions to occur:
  • A programmable radius being added to a CAM tool path
  • Scallops forming during facing operations
  • Different-shaped chips created during slotting applications, compared to HEM roughing
Programmable Radius
Helical Solutions’ High Feed End Mills has a double radius bottom edge design. Because of this, the exact profile cannot be easily programmed by some CAM software. Therefore, a theoretical radius is used to allow for easy integration.  Simply program a bullnose tool path and use the theoretical radius (seen below in Figure 2) from the dimensions table as the corner radius.
high feed mill programmable radius
Figure 2: Programmable radius of a double radius profile tool
Managing Scallops
A scallop is a cusp of material left behind by cutting tools with curved profiles. Three major factors that determine the height and width of scallops are:
  1. Axial Depth of Cut
  2. Radial Depth of Cut
  3. Curvature of Bottom Edge or Lead Angle
Figure 3 below is a depiction of the scallop profile of a typical roughing cut with a 65% radial step over and 4% axial depth of cut. The shaded region represents the scallop that is left behind after 2 roughing passes and runs parallel to the tool path.
roughing cut scallop profile
Figure 3: Back view of roughing cut with a 65% radial step over
Figures 4 and 5 show the effects of radial and axial depth of cuts on the height and width of scallops. These figures should be viewed in the context of Figure 3. Percentage by diameter is used rather than standard units of measurement to show that this effect can be predicted at any tool size. Figure 4 shows that a scallop begins to form when the tool is programmed to have a radial step over between 35% and 40%. The height increases exponentially until it is maximized at the axial depth of cut. Figure 5 shows that there is a linear relationship between the radial step over and scallop width. No relationship is seen between scallop width and axial depth of cut as long as ADOC and the radius of curvature of the bottom cutting edge remains consistent.
graph of scallop height versus depth of cut
Figure 4: Graph of Scallop Height vs. Depth of Cut
graph of scallop width versus depth of cut
Figure 5: Scallop Width vs. Depth of Cut
From the graphs in Figures 4 and 5 we get the following equations for scallop dimensions.
Notes regarding these equations:
  • These equations are only applicable for Helical Solutions High Feed End Mills
  • These equations are approximations
  • Scallop height equation is inaccurate after the axial depth of cut is reached
  • RDOC is in terms of diameter percentage (.55 x Diameter, .65 x Diameter, etc…)
Shop Helical Solutions’ Fully Stock Selection of High Feed End Mills
Curvature of the Bottom Edge of High Feed End Mills
The smaller the radius of curvature, the larger the height of the scallop. For example, the large partial radius of the Helical Solutions High Feed End Mill bottom cutting edge will leave a smaller scallop when compared to a ball end mill programmed with the same tool path. Figure 6 shows a side by side comparison of a ball end mill and high feed mill with the same radial and axial depth of cut. The scallop width and height are noticeably greater for the ball end mill because it has a smaller radius of curvature.
feed mill versus ball end mill
Figure 6: Scallop diagram of High Feed Mill and Ball End Mill with the same workpiece engagement
Full Slotting
When slotting, the feed rate should be greatly reduced relative to roughing as a greater portion of the bottom cutting edge is engaged. As shown in Figure 7, the axial step down does not equate to the axial engagement. Once engaged in a full slot, the chip becomes a complex shape. When viewing the chip from the side, you can see that the tool is not cutting the entirety of the axial engagement at one point in time. The chip follows the contour on the slot cut in the form of the bottom edge of the tool. Because of this phenomenon, the chip dips down to the lowest point of the slot and then back up to the highest point of axial engagement along the side. This creates a long thin chip that can clog up the small flute valleys of the tool, leading to premature tool failure. This can be solved by decreasing the feed rate and increasing the amount of coolant used in the operation.
high feed mill chip formation
Figure 7: Formation of a chip when a feed mill is engaged in a full slotting operation.
In summary, the curved profile of the bottom edge of the tool allows for higher feed rates when high feed milling, because of the chipping thinning effect it creates with its low lead angle. This low lead angle also distributes cutting forces axially rather than radially, reducing the amount of chatter that a normal end mill might experience under the same conditions. Machinists must be careful though as the curved bottom edge also allows for the formation of scallops, requires a programmable radius when using some CAM packages, and make slotting not nearly as productive as roughing operations.
https://www.harveyperformance.com/wp-content/uploads/2020/12/Featured-Image-Mechanics-of-High-Feed-EMs-IMG.jpg 525 1400 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2020-12-11 16:31:022024-11-07 16:13:55The Secret Mechanics of High Feed End Mills
Chipbreaker Tooling: Not Just for Roughing
April 17, 2020/2 Comments/in CNC Machining, Helical Solutions, High Efficiency Milling, Milling, Tool Geometry, Tool Information Guides/by Ben Holm
When many people think about solid carbide tools with chip breakers, they are usually tooling up for a roughing application. While the chipbreaker tool is a great choice for such applications, it can be utilized in a number of other areas too. In this post, we’ll examine many other benefits of the chip breaker style of tooling.
High Efficiency Milling (HEM)
High Efficiency Milling (HEM) uses CAM software to program advanced toolpaths that reduce cutting forces. These tool paths employ smaller end mills with a higher number of flutes (for a stronger core) running at higher speeds and feeds. This strategy includes a light radial depth of cut (RDOC), high axial depth of cut (ADOC), and a controlled angle of engagement.
Helical’s chipbreaking tools include serrated indents along the edge of flute for the entire length of cut. Because HEM utilizes heavy axial depths of cuts, these tools are able to break long chips into smaller ones. In addition to improving chip control and reducing cutting resistance, chipbreaker tools also help in decreasing heat load within the chips. This delays tool wear along the cutting edge and improves cutting performance.
chipbreaker in spindle
Check out this testimony from a Helical Solutions customer:
“We were able to get going with the 7 flute tools with the chipbreaker. I have to say the difference was INCREDIBLE! We can now rough the entire part with one tool. Also, the operator doesn’t have to open the door to clear chips hardly at all. We were able to rough and finish a 4.15 dia. bore 2 inches deep through the part without having to clear chips at all. Before we had to clear the chips out at least 15-20 times. Many thanks for your support.”
Explore Helical Solutions’ Chipbreaker Roughers Today
When slotting, a major concern is chip control. A large buildup of chips can cause the recutting of chips, which adds a lot of heat back into the tool. Chip buildup can also cause a heavy amount of chattering. Both of these conditions are detrimental to tool life. A chip breaking tool can help reduce chip build-up when slotting which will extend tool life. Remember when slotting that 4 flute tools should be utilized in steel. For aluminum and other non- ferrous materials, a 3 flute tool is best.
3 flute chipbreaker
Helical Solutions 3-Flute Chipbreakers
Trochoidal Slotting
Trochoidal slotting is a form of slotting that uses HEM techniques to form a slot. Trochoidal milling implements a series of circular cuts to create a slot wider than the cutting tool’s cutting diameter. Using the logic listed in the earlier paragraphs of this article, a chipbreaker should be used when performing this operation.
Advantages of Trochoidal Slotting:
Decreased cutting forces
Reduced heat
Greater machining accuracy
Improved tool life
Faster cycle times
One tool for multiple slot sizes
chipbreaker rougher ad
A little known fact about Helical’s chipbreaker style tool is that the chip breakers are offset flute to flute, which allows for a quality finish on the walls of the part. When utilizing light depths of cuts, high-quality finishes can be achieved.
https://www.harveyperformance.com/wp-content/uploads/2020/04/Feature-Image-Chipbreaker-Tooling-IMG.jpg 600 1599 Ben Holm http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Ben Holm2020-04-17 11:48:112021-11-19 08:35:51Chipbreaker Tooling: Not Just for Roughing
February 5, 2020/0 Comments/in Machining Techniques, Tech Tips, Tool Geometry, Tool Selection/by Harvey Performance Company
Helix Angles Rule of Thumb
Slow Helix Tool <40°
Benefits
Drawbacks
High Helix Tool >40°
Benefits
Drawbacks
https://www.harveyperformance.com/wp-content/uploads/2020/02/Feature-Image-High-and-Low-Helix-Angles-IMG.jpg 600 1599 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2020-02-05 16:07:562021-11-22 11:24:27Benefits & Drawbacks of High and Low Helix Angles
How to Select a Spindle
October 24, 2019/5 Comments/in Getting Started, How-To's, Machining Techniques/by Ben Holm
properly selecting a spindle
https://www.harveyperformance.com/wp-content/uploads/2019/10/Feature-Image-Select-Spindle-IMG-3.jpg 525 1400 Ben Holm http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Ben Holm2019-10-24 13:21:212022-06-08 11:13:34How to Select a Spindle
October 23, 2019/8 Comments/in CNC Machining, Holemaking, Micro 100, Tool Information Guides, Tool Selection, Turning/by Robert Keever
  • A greater finish quality
Micro100 Continues to Set the Standard for Boring Bars, Shop Today.
Geometries
boring bar geometric features
https://www.harveyperformance.com/wp-content/uploads/2019/10/Feature-Image-Boring-Bar-Geometries-IMG.jpg 525 1400 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2019-10-23 14:03:002022-12-12 08:59:23How Boring Bar Geometries Impact Cutting Operations
September 10, 2019/7 Comments/in CNC Machining, Harvey Tool, Machining Techniques, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
harvey tool slitting saw
  2. Undercutting Applications
  3. Slotting into Material
https://www.harveyperformance.com/wp-content/uploads/2019/09/Feature-Image-Slitting-Saws-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2019-09-10 09:30:532021-11-19 08:37:59The Geometries and Purposes of a Slitting Saw
Machining Precious Metals
July 1, 2019/10 Comments/in How-To's, Machining Techniques, Material Specific/by Robert Keever
About the Elements
  1. Ruthenium (Ru)
  2. Rhodium (Rh)
  3. Palladium (Pd)
  4. Silver (Ag)
  5. Osmium (Os)
  6. Iridium (Ir)
  7. Platinum (Pt)
  8. Gold (Au)
periodic table with a box around the 8 precious metals
material properties of precious metals in relation to 6061 and 4140
thermal conductivity of silver, gold, copper, and aluminum
pgm material properties
Tools for Precious Metals
variable helix square aluminum end mill from harvey tool
harvey tool pcd diamond square end mill
Speeds and Feeds charts:
speeds and feeds chart for precious metals
speeds and feeds chart for precious metals with a pcd end mill
https://www.harveyperformance.com/wp-content/uploads/2020/07/Machining-Precious-Metals.jpg 600 1599 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2019-07-01 12:58:512023-10-24 10:50:51Machining Precious Metals
May 6, 2019/0 Comments/in CNC Machining, CNC Programming, Machining Techniques, Specialty Tools, Tech Tips/by Harvey Performance Company
What is a Drop-Hole?
graphic showing holes with and without drop hole allowance
5 unique machining operations with drop hole allowance
When Not to Drop Hole
machining operations without drop hole allowance
Drop-Hole Placement
proper placement of hole when using drop hole allowance
graphic showing the use of a drop hole for o-ring seals between high and low pressure areas
https://www.harveyperformance.com/wp-content/uploads/2019/05/Feature-Image-Drop-Hole-Allowance-IMG-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2019-05-06 09:48:552023-10-24 10:53:22When to and Not to Use Drop Hole Allowance
What to Know About Helical Solution’s Zplus Coating
April 1, 2019/0 Comments/in Aluminum, CNC Machining, Helical Solutions, Machining Techniques, Material Specific, Tool Coatings, Tool Selection/by Harvey Performance Company
zplus coated helical chipbreaker end mill
zplus coating specification chart
Large Production Runs
3 flute corner radius end mill for aluminum
Finishing Applications
https://www.harveyperformance.com/wp-content/uploads/2019/04/Feature-Image-Zplus-Coatings-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2019-04-01 03:17:542023-10-24 10:53:44What to Know About Helical Solution’s Zplus Coating
February 15, 2019/3 Comments/in Helical Solutions, High Efficiency Milling, Machining 101, Machining Techniques, Tool Geometry, Tool Information Guides, Tool Selection/by Allyn Hood
Understanding the Two Styles
Chipbreaker End Mills
chipbreaker end mill standing straight up
Knuckle Roughers
straight up black knuckle rougher end mill
https://www.harveyperformance.com/wp-content/uploads/2019/02/Feature-Image-Chipbreakers-vs-Knuckle-Roughers-IMG.jpg 525 1400 Allyn Hood http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Allyn Hood2019-02-15 11:31:552023-10-24 10:54:38Chipbreaker vs. Knuckle Rougher End Mills
Page 1 of 41234
