Tag Archive for: chip flushing
How to Select a Spindle
October 24, 2019/5 Comments/in Getting Started, How-To's, Machining Techniques/by Ben Holm
properly selecting a spindle
https://www.harveyperformance.com/wp-content/uploads/2019/10/Feature-Image-Select-Spindle-IMG-3.jpg 525 1400 Ben Holm http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Ben Holm2019-10-24 13:21:212022-06-08 11:13:34How to Select a Spindle
October 23, 2019/8 Comments/in CNC Machining, Holemaking, Micro 100, Tool Information Guides, Tool Selection, Turning/by Robert Keever
  • A greater finish quality
Micro100 Continues to Set the Standard for Boring Bars, Shop Today.
Geometries
boring bar geometric features
https://www.harveyperformance.com/wp-content/uploads/2019/10/Feature-Image-Boring-Bar-Geometries-IMG.jpg 525 1400 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2019-10-23 14:03:002022-12-12 08:59:23How Boring Bar Geometries Impact Cutting Operations
May 15, 2018/1 Comment/in CNC Machining, Machining Techniques, Quick Tips, Tech Tips/by Harvey Performance Company
What is a Tight Tolerance?
harvey tool sample table heading showing tool tolerances in D1 and L2 callouts
How Are Tolerances Used?
tooling tolerances of an end mill in dia and LOC
Spotting Drills
spotting drill with dimension callouts
Reamers
miniature reamers with dimension callouts
Be Wary of Deflection
Maintaining tolerances when machining walls is made difficult by tool deflection, or the curvature a tool experiences when a force is applied to it. Where an angle is appearing on a wall due to deflection, opt for a reached tool to allow for less deflection along the tool’s neck. Further, take more axial depths of cut and machine in steps with finishing passes to exert less pressure on the tool. For surface finish tolerances, a long fluted tool may be required to minimize evidence of a tool path left on a part.infographic showcasing cutting forces and tool deflection in machining
Tolerances Summarized
https://www.harveyperformance.com/wp-content/uploads/2018/05/Featured-Image-Tight-Tolerances-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-05-15 09:22:382023-10-24 10:25:19Tips for Maintaining Tight Tolerances
May 10, 2018/5 Comments/in CNC Machining, Tool Coatings, Tool Selection/by Robert Keever
diamond tool coatings
Amorphous Diamond Coating
amorphous diamond coating graphic showcasing thickness added
CVD Diamond Coating graphic showcasing thickness added by coating
Polycrystalline Diamond (PCD)
PCD Diamond Coating showcasing brazed on cutting edgeHow Diamond Coatings Differ
Coating Hardness & Thickness
Flute Styles
PCD Diamond ball end mill
PCD Ball End Mill
CVD Diamond ball end mill
CVD Ball End Mill
Proper Uses
Cut to the Point
https://www.harveyperformance.com/wp-content/uploads/2018/05/Feature-Image-Diamond-End-Mills-IMG.jpg 525 1400 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2018-05-10 10:51:482024-02-12 15:37:16Shining a Light on Diamond End Mills
April 19, 2018/0 Comments/in Drilling, Drilling & Holemaking, Harvey Tool, Holemaking, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
Harvey Tool stocks several different types of miniature drills, but which option is right for you, and how does each drill differ in geometry and overall tool coating?
https://www.harveyperformance.com/wp-content/uploads/2018/04/Featured-Image-Miniature-Drill-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-04-19 08:00:482024-11-07 16:28:32Selecting the Right Harvey Tool Miniature Drill
April 19, 2018/1 Comment/in CNC Machining, Holemaking, How-To's, Machining 101/by Harvey Performance Company
What are Pecking Cycles?
aluminum pecking cycles
hardened steels chart
prehardened steels chart
https://www.harveyperformance.com/wp-content/uploads/2018/04/Featured-Image-Pecking-Cycle-IMG-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-04-19 07:44:542022-01-17 10:16:34Choosing the Right Pecking Cycle Approach
March 5, 2018/2 Comments/in Getting Started, Machining 101, Machining Techniques, Troubleshooting Tips/by Harvey Performance Company
close up view of excessive tool wear on a cutting edge
Subpar Part Finish
Inefficient Coolant Usage
two helical solutions chamfer mills
https://www.harveyperformance.com/wp-content/uploads/2018/03/Featured-Image-Shop-Inefficient-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-03-05 14:30:062023-10-12 14:34:385 Ways Your Shop is Inefficient
December 5, 2017/9 Comments/in CNC Machining, Quick Tips, Tech Tips, Titan USA, Troubleshooting Tips/by Harvey Performance Company
https://www.harveyperformance.com/wp-content/uploads/2017/12/Feature-Image-Coolant-for-CNC-Machining-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-12-05 15:09:342022-04-20 16:52:22What You Need to Know About Coolant for CNC Machining
November 8, 2017/26 Comments/in CNC Machining, How-To's, Quick Tips, Troubleshooting Tips/by Harvey Performance Company
What is Chatter in Machining?
zoomed in image of excessive tool wear from cnc machining
An example of a tool with excessive wear.
Shut Up Tool Chatter With Harvey Tool’s Material Specific Tooling
How to Reduce Chatter in Machining
Use Material Specific Tooling
helical reduced neck tool in cnc machine next to part
Consider Tool Length
Ensure a Secure Connection
Tool Holder & Shank Relationship
image of three end mills secured in their respective tool holders
Choosing Collet Types
harvey tool material specific tooling ad with 4 end mills pictured side-by-side
Selecting a Chatter Minimizing Strategy
How a tool is run can mean the difference between stellar job results and a ruined part. This includes both the parameters a tool is run at, as well as the direction by which it rotates – either a Conventional Milling or a Climb Milling technique. The key distinction between these two methods lies in the relationship between the cutter’s rotation and the direction of the feed.
In conventional milling, the chip width starts from zero and increases gradually, causing the process of heat generation onto the workpiece rather than the chips. Heat generation causes deformities and tool failure such as work hardening, creating more headaches for a machinist. For this reason, conventional milling is generally only recommended for tools with high toughness or for breaking into case hardened materials.
conventional milling example with feed and rotation direction showcasing chip thickness
climb milling illustration with rotation and feed directions and chip thickness relation
https://www.harveyperformance.com/wp-content/uploads/2017/11/Feature-Image-Tool-Chatter-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-11-08 09:30:472023-12-01 16:08:473 Steps to Shutting up Tool Chatter
October 24, 2017/8 Comments/in CNC Machining, Helical Solutions, Tool Information Guides, Tool Selection, Troubleshooting Tips/by Harvey Performance Company
What is Chipbreaker Tooling?
up close image of chipbreaker end mill
small metal chips in cnc machine resulting from the use of a chipbreaker end mill
Helical Part No.33737
Material4340 Steel
ADOC2.545″
RDOC.125″
Speed2,800 RPM
Feed78 IPM
Chipbreaker Geometry is often utilized in aluminum jobs and with other materials where long, stringy chips are common. Materials that produce a powdery chip, such as graphite, should not be machined with a chipbreaker tool, as chip evacuation would not be a concern. Helical Solutions’ line of chipbreaker tooling includes a 3-flute option for aluminum and non-ferrous materials, and its reduced neck counterpart. Additionally, Helical offers a 4-flute rougher with chipbreaker geometry for high-temp alloys and stainless steels. Harvey Tool’s expansive product offering includes a composite cutting end mill with chipbreaker geometry.
helical solutions 7 flute chipbreaker end mill cutting edges
https://www.harveyperformance.com/wp-content/uploads/2017/10/Feature-Image-Chipbreaker-Tooling-IMG.jpg 600 1599 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-10-24 16:52:132024-03-07 16:04:28Optimize Roughing With Chipbreaker Tooling
Page 1 of 212
