Contouring & 5-Axis Machining
 Recent Contouring Advances
1. Increased Time Savings
2. Reduced Cycle Times
3. Improved Consistency
Contouring Tips
1. Premature Tool Decay / Tool Failure
tool wear
2. Subpar Part Finish
3. Inefficient Coolant Usage
https://www.instagram.com/p/BY-_UWqAYVM/?hl=en&taken-by=harveytool
4. Not Taking Advantage of Tool Versatility
chamfer mills
5. High Machine Downtime
What use is a machine that’s not running? Minimizing machine downtime is a key way to ensure that your shop is reaching its efficiency pinnacle. This can be accomplished a variety of ways, including keeping like-parts together. This allows for a simple swap-in, swap-out of material to be machined by the same cutting tool. This saves valuable time swapping out tooling, and lets your machine to do its job for more time per workday. Production planning is a key factor to running an efficient machine shop.
A Growing Industry
Calculating MRR
Optimizing Efficiency
https://www.instagram.com/p/Bcpa9CCBnwj/?taken-by=helicaltools
2. Ensure a Secure Connection
tool chatter
decrease tool chatter
https://www.instagram.com/p/BVu7uHwByR5/?taken-by=helicaltools
Helical Part No. 33737
Material 4340 Steel
ADOC 2.545″
RDOC .125″
Speed 2,800 RPM
Feed 78 IPM
Why Flute Count Matters
Tool Geometry Basics
flute count core
Material Considerations
flute count
flute count
How to Avoid Composite Delamination with Compression Cutters
Using Compression Cutters in Composite Materials
delamination
compression cutters
Titanium Varieties
Titanium 6AL4V
Titanium Concerns
Workholding
Heat Generation
cutting tools for titanium
Galling and Built-Up Edge
Titanium Solutions
machining titanium
