Tag Archive for: Chip Thinning
The Secret Mechanics of High Feed End Mills
December 11, 2020/1 Comment/in Helical Solutions, Machining 101, Tool Information Guides/by Robert Keever
A High Feed End Mill is a type of High-Efficiency Milling (HEM) tool with a specialized end profile that allows the tool to utilize chip thinning to have dramatically increased feed rates. These tools are meant to operate with an extremely low axial depth so that the cutting action takes place along the curved edge of the bottom profile. This allows for a few different phenomena to occur:
  • The low lead angle causes most of the cutting force to be transferred axially back into the spindle. This amounts to less deflection, as there is much less radial force pushing the cutter off its center axis.
  • The extended curved profile of the bottom edge causes a chip thinning effect that allows for aggressive feed rates.
The Low Lead Angle of a High Feed End Mill
As seen in Figure 1 below, when a High Feed End Mill is properly engaged in a workpiece, the low lead angle, combined with a low axial depth of cut, transfers the majority of the cutting force upward along the center axis of the tool. A low amount of radial force allows for longer reaches to be employed without the adverse effects of chatter, which will lead to tool failure. This is beneficial for applications that require a low amount of radial force, such as machining thin walls or contouring deep pockets.
high feed mill roughing
Figure 1: Isometric view of a feed mill engaged in a straight roughing pass (left), A snapshot front-facing view of this cut (right)
Feed Mills Have Aggressive Feed Rates
Figure 1 also depicts an instantaneous snapshot of the chip being formed when engaged in a proper roughing tool path. Notice how the chip (marked by diagonal lines) thins as it approaches the center axis of the tool. This is due to the curved geometry of the bottom edge. Because of this chip thinning phenomenon, the feed of the tool must be increased so that the tool is actively engaged in cutting and does not rub against the workpiece. Rubbing will increase friction, which in turn raises the level of heat around the cutting zone and causes premature tool wear. Because this tool requires an increased chip load to maintain a viable cutting edge, the tool has been given the name “High Feed Mill.”
high feed end mill ad
Other Phenomena Due to Curved Geometry of Bottom Edge
The curved geometry of the bottom edge also sanctions for the following actions to occur:
  • A programmable radius being added to a CAM tool path
  • Scallops forming during facing operations
  • Different-shaped chips created during slotting applications, compared to HEM roughing
Programmable Radius
Helical Solutions’ High Feed End Mills has a double radius bottom edge design. Because of this, the exact profile cannot be easily programmed by some CAM software. Therefore, a theoretical radius is used to allow for easy integration.  Simply program a bullnose tool path and use the theoretical radius (seen below in Figure 2) from the dimensions table as the corner radius.
high feed mill programmable radius
Figure 2: Programmable radius of a double radius profile tool
Managing Scallops
A scallop is a cusp of material left behind by cutting tools with curved profiles. Three major factors that determine the height and width of scallops are:
  1. Axial Depth of Cut
  2. Radial Depth of Cut
  3. Curvature of Bottom Edge or Lead Angle
Figure 3 below is a depiction of the scallop profile of a typical roughing cut with a 65% radial step over and 4% axial depth of cut. The shaded region represents the scallop that is left behind after 2 roughing passes and runs parallel to the tool path.
roughing cut scallop profile
Figure 3: Back view of roughing cut with a 65% radial step over
Figures 4 and 5 show the effects of radial and axial depth of cuts on the height and width of scallops. These figures should be viewed in the context of Figure 3. Percentage by diameter is used rather than standard units of measurement to show that this effect can be predicted at any tool size. Figure 4 shows that a scallop begins to form when the tool is programmed to have a radial step over between 35% and 40%. The height increases exponentially until it is maximized at the axial depth of cut. Figure 5 shows that there is a linear relationship between the radial step over and scallop width. No relationship is seen between scallop width and axial depth of cut as long as ADOC and the radius of curvature of the bottom cutting edge remains consistent.
graph of scallop height versus depth of cut
Figure 4: Graph of Scallop Height vs. Depth of Cut
graph of scallop width versus depth of cut
Figure 5: Scallop Width vs. Depth of Cut
From the graphs in Figures 4 and 5 we get the following equations for scallop dimensions.
Notes regarding these equations:
  • These equations are only applicable for Helical Solutions High Feed End Mills
  • These equations are approximations
  • Scallop height equation is inaccurate after the axial depth of cut is reached
  • RDOC is in terms of diameter percentage (.55 x Diameter, .65 x Diameter, etc…)
Shop Helical Solutions’ Fully Stock Selection of High Feed End Mills
Curvature of the Bottom Edge of High Feed End Mills
The smaller the radius of curvature, the larger the height of the scallop. For example, the large partial radius of the Helical Solutions High Feed End Mill bottom cutting edge will leave a smaller scallop when compared to a ball end mill programmed with the same tool path. Figure 6 shows a side by side comparison of a ball end mill and high feed mill with the same radial and axial depth of cut. The scallop width and height are noticeably greater for the ball end mill because it has a smaller radius of curvature.
feed mill versus ball end mill
Figure 6: Scallop diagram of High Feed Mill and Ball End Mill with the same workpiece engagement
Full Slotting
When slotting, the feed rate should be greatly reduced relative to roughing as a greater portion of the bottom cutting edge is engaged. As shown in Figure 7, the axial step down does not equate to the axial engagement. Once engaged in a full slot, the chip becomes a complex shape. When viewing the chip from the side, you can see that the tool is not cutting the entirety of the axial engagement at one point in time. The chip follows the contour on the slot cut in the form of the bottom edge of the tool. Because of this phenomenon, the chip dips down to the lowest point of the slot and then back up to the highest point of axial engagement along the side. This creates a long thin chip that can clog up the small flute valleys of the tool, leading to premature tool failure. This can be solved by decreasing the feed rate and increasing the amount of coolant used in the operation.
high feed mill chip formation
Figure 7: Formation of a chip when a feed mill is engaged in a full slotting operation.
In summary, the curved profile of the bottom edge of the tool allows for higher feed rates when high feed milling, because of the chipping thinning effect it creates with its low lead angle. This low lead angle also distributes cutting forces axially rather than radially, reducing the amount of chatter that a normal end mill might experience under the same conditions. Machinists must be careful though as the curved bottom edge also allows for the formation of scallops, requires a programmable radius when using some CAM packages, and make slotting not nearly as productive as roughing operations.
https://www.harveyperformance.com/wp-content/uploads/2020/12/Featured-Image-Mechanics-of-High-Feed-EMs-IMG.jpg 525 1400 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2020-12-11 16:31:022024-11-07 16:13:55The Secret Mechanics of High Feed End Mills
July 2, 2020/2 Comments/in CNC Machining, Harvey Tool, Machining 101, Milling, Tool Information Guides/by Harvey Performance Company
Whether your tool is a 1” diameter powerhouse rougher or a .032” precision end mill, slotting is one of the hardest operations on the tool. During slotting operations, a lot of force and pressure is placed on the entire cutting edge of the tool. This results in slower speeds and feeds and increased tool wear, making it one of the nastier processes even for the best cutting tools.
With miniature tooling (for the purposes of this blog, under 1/8” diameter) the game changes. The way we approach miniature tooling is completely different as it relates to slotting. In these instances, it is vitally important to select the correct tool for these operations. A few of the suggestions may surprise you if you are used to working with larger tooling, but rest assured, these are tried and tested recommendations which will dramatically increase your success rate in miniature slotting applications.
Use as Many Flutes as Possible
When running traditional slotting toolpaths, the biggest concern with the cutting tool is getting the best chip evacuation by using the proper flute count. Traditionally speaking, you want to use the fewest amount of flutes possible. In Aluminum/Non-Ferrous jobs, this is typically no more than 2/3 flutes, and in Steel/Ferrous applications, 4 flutes is recommended. The lower flute count leaves room for the chips to evacuate so you are not re-cutting chips and clogging the flutes on your tool in deep slots.
Achieve Increased Efficiency With Miniature Tooling – Utilize Harvey Tool’s Speeds & Feeds Charts Today
When slotting with miniature tools, the biggest concerns are with tool rigidity, deflection, and core strength. With micro-slotting we are not “slotting”, but rather we are “making a slot”. In traditional slotting, we may drive a ½” tool down 2xD into the part to make a full slot, and the tool can handle it! But this technique simply isn’t possible with a smaller tool.
graphic showing difference between core sizes on 3 flute and 5 flute slotting tools
For example, let’s take a .015” end mill. If we are making a slot that is .015” deep with that tool, we are likely going to take a .001” to .002” axial depth per pass. In this case, chips are no longer your problem since it is not a traditional slotting toolpath. Rigidity and core strength are now key, which means we need to add as many flutes as possible! Even in materials like Aluminum, 4 or 5 flutes will be a much better option at smaller diameters than traditional 2/3 flute tools. By choosing a tool with a higher flute count, some end users have seen their tool life increase upwards of 50 to 100 times over tools with lower flute counts and less rigidity and strength.
Use the Strongest Corner Possible When Slotting
Outside of making sure you have a strong core on your miniature tools while making a slot, you also need to take a hard look at your corner strength. Putting a corner radius on your tooling is a great step and does improve the corner strength of the tool considerably over a square profile tool. However, if we want the strongest tip geometry, using a ball nose end mill should also be considered.
A ball nose end mill will give you the strongest possible tip of the three most common profiles. The end geometry on the ball nose can almost work as a high feed end mill, allowing for faster feed rates on the light axial passes that are required for micro-slotting. The lead angle on the ball nose also allows for axial chip thinning, which will give you better tool life and allow you to decrease your cycle times.
.078" harvey tool ball nose end mill for slotting
A .078″ ball nose end mill was used for this miniature slotting operation
Finding the Right Tool for Miniature Slotting Operations
Precision and accuracy are paramount when it comes to miniature tooling, regardless of whether you are slotting, roughing, or even simply looking to make a hole in a part. With the guidelines above, it is also important to have a variety of tooling options available to cater to your specific slotting needs. Harvey Tool offers 5 flute end mills down to .015” in diameter, which are a great option for a stronger tool with a high flute count for slotting operations.
miniature .010" harvey tool end mill
Harvey Tool offers many miniature end mill options, like the .010″ long reach end mill above.
If you are looking to upgrade your corner strength, Harvey Tool also offers a wide selection of miniature end mills in corner radius and ball nose profiles, with dozens of reach, length of cut, and flute count options. Speeds and feeds information for all of these tools is also available, making your programming of these difficult toolpaths just a little bit easier.
speeds and feeds chart ad
Achieving Slotting Success: Summary
To wrap things up, there are three major items to focus on when it comes to miniature slotting: flute count, corner strength, and the depth of your axial passes.
It is vital to ensure you are using a corner radius or ball nose tool and putting as many flutes as you can on your tool when possible. This keeps the tool rigid and avoids deflection while providing superior core strength.
For your axial passes, take light passes with multiple stepdowns. Working your tool almost as a high feed end mill will make for a successful slotting operation, even at the most minuscule diameters.
https://www.harveyperformance.com/wp-content/uploads/2020/07/Featured-Image-Slotting-Miniature-Tools-IMG.jpg 237 632 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2020-07-02 12:12:532021-11-19 08:11:43Successful Slotting With Miniature Cutting Tools
January 30, 2020/2 Comments/in News/by Harvey Performance Company
Locking Depths of Cut
Machining Advisor Pro Mobile
Smoother User Experience
https://www.harveyperformance.com/wp-content/uploads/2020/01/MAP-1.5-Featured.jpg 600 1599 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2020-01-30 10:55:552021-05-24 16:47:05Machining Advisor Pro Updated With New Improvements
Helical HVTI Cutter: High Efficiency Milling Titanium
January 3, 2020/2 Comments/in Gummy Materials, Helical Solutions, High Efficiency Milling, Material Specific, Tool Information Guides, Tools In Action/by Harvey Performance Company
End Mills for Titanium
Helical HVTI Titanium
WATCH THE HVTI IN ACTION
https://www.harveyperformance.com/wp-content/uploads/2020/01/Feature-Image-HVTI-IMG-1.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2020-01-03 10:00:302025-11-12 15:45:27Helical HVTI Cutter: High Efficiency Milling Titanium
Machining Precious Metals
July 1, 2019/10 Comments/in How-To's, Machining Techniques, Material Specific/by Robert Keever
About the Elements
  1. Ruthenium (Ru)
  2. Rhodium (Rh)
  3. Palladium (Pd)
  4. Silver (Ag)
  5. Osmium (Os)
  6. Iridium (Ir)
  7. Platinum (Pt)
  8. Gold (Au)
periodic table with a box around the 8 precious metals
material properties of precious metals in relation to 6061 and 4140
thermal conductivity of silver, gold, copper, and aluminum
pgm material properties
Tools for Precious Metals
variable helix square aluminum end mill from harvey tool
harvey tool pcd diamond square end mill
Speeds and Feeds charts:
speeds and feeds chart for precious metals
speeds and feeds chart for precious metals with a pcd end mill
https://www.harveyperformance.com/wp-content/uploads/2020/07/Machining-Precious-Metals.jpg 600 1599 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2019-07-01 12:58:512023-10-24 10:50:51Machining Precious Metals
October 25, 2018/1 Comment/in High Efficiency Milling, How-To's, Machining Techniques, Quick Tips/by Harvey Performance Company
heat generation in standard versus hem milling and their associated depths of cut
Chip Thinning Awareness
Chip thinning occurs when tool paths include varying radial depths of cut, and relates to chip thickness and feed per tooth. HEM is based off of the principal of chip thinning. However, if not properly executed, chip thinning can cause a lot of heat generation. When performing HEM, you effectively reduce your stepover and increase your speeds and feeds to run your machine at high rates. But if your machine isn’t capable of running high enough speeds and feeds, or you do not adjust accordingly to your reduced stepover, trouble will occur in the form of rubbing between the material and tool. Rubbing creates friction and mass amounts of heat which can cause your material to deform and your tool to overheat. Chip thinning can be good when used correctly in HEM, but if you fall below the line of reduced stepover without higher speeds and feeds, you will cause rubbing and tool failure. Because of this, it’s always important to be aware of your chips during machining. Understanding chip thinning is paramount to success in in machining.
infographic showcasing chip thinning in relation to step over
Consider Climb Milling
infographic showing climb versus conventional milling in feed path and end mill direction
https://www.harveyperformance.com/wp-content/uploads/2018/10/Feature-Image-Reduce-Heat-Generation-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-10-25 11:26:402025-02-12 09:59:35Effective Ways to Reduce Heat Generation
October 16, 2018/0 Comments/in CNC Machining, Getting Started, Machining 101, Machining Techniques, Tool Selection/by Harvey Performance Company
  • Traditional Roughing
  • Slotting
  • Finishing
  • Contouring
  • Plunging
  • High Efficiency Milling
Material:
Application:
graphic showcasing the tool face of end mills from 2 to 12 flutes
Length of Cut & Reach
Tool Profile
end mill graphic with dimension callouts
  • Prolonged Tool life
  • Improved Chip Evacuation
multiple end mills after being coated, zoomed in on cutting faces
https://www.harveyperformance.com/wp-content/uploads/2018/10/Feature-Image-5-Questions-IMG-2.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-10-16 09:00:242023-10-24 10:42:255 Questions to Ask Before Selecting an End Mill
June 19, 2018/17 Comments/in CNC Machining, Helical Solutions, Material Specific, Tech Tips, Trending Now/by Harvey Performance Company
stainless steel machining
The axial engagement of a tool in a slotting operation should be suitable for the specific tool employed, as depicted in Figure 3. Employing an unsuitable method may result in tool deflection, potential damage, and compromised part quality. Chip evacuation is going to be key for slotting in stainless steel. For this reason, 4 flute tools are the best choice because the lower flute count allows for more efficient chip evacuation. Tools with chipbreaker geometry also make for effective slotting in stainless steel, as the smaller chips are easier to evacuate from the cut.
High Efficiency Milling (HEM) can be a very effective machining technique in stainless steels if the correct tools are selected. Chipbreaker roughers would make an excellent choice, in either 5 or 7 flute styles, while standard 5-7 flute, variable pitch end mills can also perform well in HEM toolpaths.
HEV-5
machining advisor pro ad
https://www.harveyperformance.com/wp-content/uploads/2018/06/Feature-Image-Slaying-Stainless-Steel-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-06-19 15:30:022023-12-15 15:25:56Slaying Stainless Steel: Machining Guide
May 15, 2018/11 Comments/in CNC Machining, Helical Solutions, Tech Tips/by Harvey Performance Company
bag of copper chips from cnc machining
Coolant
Tool Engagement
infographic showcasing the rotation and movement of a cutting tool in climb milling
Initial Workpiece Engagement
Gummy Materials Summarized
https://www.harveyperformance.com/wp-content/uploads/2018/05/Featured-Image-Gummy-Materials-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-05-15 16:47:142023-10-24 10:21:46Tips for Machining Gummy Materials
April 19, 2018/0 Comments/in Drilling, Drilling & Holemaking, Harvey Tool, Holemaking, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
Harvey Tool stocks several different types of miniature drills, but which option is right for you, and how does each drill differ in geometry and overall tool coating?
https://www.harveyperformance.com/wp-content/uploads/2018/04/Featured-Image-Miniature-Drill-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-04-19 08:00:482024-11-07 16:28:32Selecting the Right Harvey Tool Miniature Drill
Page 1 of 212
