NOTE: This article covers speeds and feed rates for milling tools, as opposed to turning tools.
- Chip load per tooth is the appropriate amount of material that one cutting edge of the tool should remove in a single revolution. This is measured in Inches Per Tooth (IPT).
- Chip load per tool is the appropriate amount of material removed by all cutting edges on a tool in a single revolution. This is measured in Inches Per Revolution (IPR).
Material Removal Rate
Speeds and Feeds In Practice
Spindle Speed Cap
Effective Cutter Diameter
Non-linear Path
