Tag Archive for: circular tool paths
Three Key Benefits
Indexing
Increased Feed Rates
Better Part Finish
Opt for a Smoother Operation
machining advisor pro mobile
Built-In CAM Applications
Importance of Tooling to HEM
Best Tools for HEM:
The following is just one of several blog posts relevant to High Efficiency Milling and High Speed Machining. To achieve a full understanding of this popular machining method, view any of the additional HEM posts below!
Introduction to High Efficiency Milling I How to Combat Chip Thinning I Diving into Depth of Cut I How to Avoid 4 Major Types of Tool Wear I Intro to Trochoidal Milling
With multiple techniques being described with somewhat similar terms, there is some confusion as to what each is referring to. High Efficiency Milling (HEM) and High Speed Machining (HSM) are two commonly used terms and techniques that can often be confused with one another. Both describe techniques that lead to increased material removal rates and boosted productivity.  However, the similarities largely stop there.
High speed machining is often used as an umbrella term for all high productivity machining methods including HEM. However, HEM and HSM are unique, separate machining styles. HSM encompasses a technique that results in higher production rates while using a much different approach to depth of cut and speeds and feeds. While certain HEM parameters are constantly changing, HSM uses constant values for the key parameters. A very high spindle speed paired with much lighter axial depths of cut results in a much higher allowable feed rate. This is also often referred to as feed milling. Depths of cut involve a very low axial and high radial components. The method in general is often thought of as z-axis slice machining, where the tool will step down a fixed amount, machine all it can, then step down the next fixed amount and continue the cycle.
Check out the video below to see HEM in action!
https://www.instagram.com/p/BV7voCVB4Ah/?taken-by=helicaltools
Decrease Cycle Times and Increase Shop Efficiency. Download Our HEM Guidebook.
Cutting Circular Tool Paths
Internal Circular Tool Paths
Circular Tool Paths
External Circular Tool Paths
Optimize Your Performance
