https://www.instagram.com/p/Bl5lHGcHIiJ/?hl=en&taken-by=harveytool
What is a thread?
Thread Designations
Metric Thread Designations
M12 x 1.75 – 4h – LH
UN Thread Designations
¾ 10 UNC 2A LH
ACME Thread Designations
A 1 025 20-X
How are threads measured?
Thread Milling Considerations
There is no substitute for adequate tooling. To avoid tool failure and machining mishaps, opt for a quality manufacturer for High Performance Drills for your starter holes, as well as for your thread milling solutions. Harvey Tool fully stocks several types of threadmills, including Single Form, Tri-Form, and Multi-Form Thread Milling Cutters. In addition, the 60° Double Angle Shank Cutter can be used for thread milling.
thread milling
Image Courtesy of  @Avantmfg
3. Ensure You’re Comfortable with Your Tool Path
Just looking at a threading tool can be confusing – it is sometimes hard to conceptualize how these tools are able to get the job done. But with proper understanding of call, methods, and best practices, machinists can feel confident when beginning their operation.
