Breaking and damaging an end mill is oftentimes an avoidable mistake that can be extremely costly for a machine shop. To save time, money, and your end mill it is important to learn some simple tips and tricks to extend your tool’s life.
tool life
tool life
helical end mill
tool life
heat generation in HEM
Chip Thinning Awareness
Consider Climb Milling
heat generation
Coolant
Tool Engagement
climb milling
Initial Workpiece Engagement
Gummy Materials Summarized
Recent  Advances
Increased Time Savings
Reduced Cycle Times
Improved Consistency
CNC Contouring planes
CNC Contouring ball end mill
helical reduced neck tool
Ensure a Secure Connection
ball nose
Shop Harvey Tool’s Vast Selection of Ball Profile End Mills – Click Here to Get Started
ball nose effective cutting diameter chart
ball nose cutting diameter calculation
ball nose compensated speed calculation
KEY
ADOC = Axial Depth of Cut
D = Cutting Diameter
R = Tool Radius (Dia./2)
RDOC = Radial Depth of Cut
SFM = Surface Feet per Minute
Sc = Compensated Speed
ball nose milling with tilt angle
KEY
Climb Milling (Figure 3)
climb milling
