Contouring & 5-Axis Machining
 Recent Contouring Advances
1. Increased Time Savings
2. Reduced Cycle Times
3. Improved Consistency
Contouring Tips
Harvey Tool Voted #1 Top End Mill Brand
Rowley, MA – Harvey Tool is proud to announce that for the second consecutive year, it has been voted #1 Most Popular End Mill Brand by participants of the 2016 CNC Cookbook End Mill Survey, a questionnaire meant to gauge machinists’ most preferred manufacturers.
Of the nearly 1,300 votes cast for more than 90 different end mill brands, Harvey Tool earned the top spot with 90.3 percent of voters listing the Rowley-based company as a top choice end mill manufacturer. Following behind were Niagara (whom Harvey Tool tied with for the top spot last year), OSG, Accupro, Garr, SGS, Kennametal, and Micro100.
While the survey focused on overall brand popularity, it also asked respondents to rank end mill brands based on the categories of “combined value and performance” and “highest performance.” Harvey Tool was named the top choice for both categories, tallying 7.9 percent of votes for highest performance and 6.8 percent for combined value and performance. Simply, participants voted Harvey Tool the first choice for tools if money was no factor, while also listing them as having the best balance of performance and value.
Helical Solutions, whom Harvey Tool acquired in 2015, also performed well in the CNC Cookbook End Mill Survey, ranking in the top position within the Tier 2 list of end mill brands. This marks the first year that Helical has been named and ranked in this annual survey.
“We’re extremely proud of this accomplishment as it works to affirm the hard work and commitment our team exhibits every day for our customers,” said Harvey Tool Vice President of Marketing Garth Ely. “The results of this survey clearly express that Harvey Tool is a top choice for machinists, and there’s no better feeling than that.”
“Each member of our team played a vital role in making this possible,” Ely said. “It’s truly a cross functional effort here, which makes an accomplishment of this magnitude so much greater.”
“For us, this is just another accomplishment in what has been a tremendous year of growth and achievement,” said Harvey Tool Senior Vice President of Sales Jerry Gleisner. “To see both Harvey Tool and Helical Solutions perform so well is only added motivation for us to continue to push for an even better product for our customers in 2017.”
