Composite Materials
- Delamination of composite layers
- Uncut Fibers
- Fiber tear-out
- Uneven tool wear
- Poor surface finish due to “competing” materials
These problems are all caused by unique conditions created by composite materials, and can be very tricky to correct. The simple fact of cutting a combination of multiple materials at the same time introduces many factors that make it difficult to strike the right balance of the proper tool for the job and appropriate running parameters. The following tool styles provide solutions for a wide array of composite concerns. Composite Drilling Applications can face the same issues, and proper drill choice can help as well.
Straight Flute End Mill
Compression Cutters
Chipbreaker Cutter
Diamond Cut End Mill
Composite Finisher
Coating or No Coating?
Composite materials, especially those with glass or carbon fiber, can be particularly abrasive and have a tendency to wear down the cutting edge of carbide tools. If one is looking to achieve the best tool life and maintain a sharp cutting edge, then choosing an Amorphous Diamond coated tool is the best option. This thin coating improves lubricity and wear resistance over its uncoated counterpart. Using a tool with CVD diamond coating can be very beneficial in extreme cases, when fiber fill percentage is very large. This is a true diamond coating, and offers the best abrasion resistance, but a slightly less sharp cutting edge as it is a thicker coating. PCD diamond tooling offers the best tool life. If it a solid diamond wafer brazed to a carbide shank, and can maintain the sharpest edge of any diamond tooling. However, PCD is limited to straight flutes, and can come at a higher price.
