Confidently Select Your Next Thread Mill
Do you know the key differences between a Single Form Thread Mill and a Multi-Form Thread Mill? Do you know which tooling option is best for your job? This blog post examines how several factors, including the tool’s form and max depth of thread, are important to ultimately making the appropriate Harvey Tool thread mill decision.
Thread Mill Product Offering
Similar to the standard single form thread mills, Harvey Tool’s thread mills for hardened steels offer machinists a quality option when dealing with hardened steels from 46-68 Rc. The following unique geometries helps this tool machine tough alloys:
- Ground Flat – Instead of a sharp point these tools have a ground flat to help ensure long tool life.
- Eccentric Relief – Gives the cutting edges extra strength for the high feeds at relatively low RPMs required for harder materials.
- AlTiN Nano Coating – Allows for superior heat resistance.
A key difference between the standard Single Form Thread Mill and the Single Form Thread Mills for Hardened Steels is that the thread mills for hardened steels are actually only capable of milling 83% of the actual thread depth. At first, this may seem detrimental to your operation. However, according to the Machinery’s Handbook 29th Edition, “Tests have shown that any increase in the percentage of full thread over 60% does not significantly increase the strength of the thread. Often, a 55% to 60% thread is satisfactory, although 75% threads are commonly used to provide an extra margin of safety.” With the ability to preserve tool life and effectively perform thread components, Harvey Tool’s single form thread mills for hardened steels are a natural choice when tackling a hardened material.
Tri-Form Thread Mills
Tri-Form thread mills are designed for difficult-to-machine materials. The tri-form design reduces tool pressure and deflection, which results in more accurate threading. Its left-hand cut, left-hand spiral design allows it to climb mill from the top of the thread to the bottom.
Multi-Form Thread Mills
Our multi-form thread mills are offered in styles such as UN, NPT, and Metric. Multi-Form Thread Mills are optimized to produce a full thread in single helical interpolation. Additionally, they allow a machinist to quickly turn around production-style jobs.
Long Flute Thread Mills
These tools are great when a job calls for a deep thread, due to their long flute. Long Flute Thread Mills also have a large cutter diameter and core, which provides the tool with improved tool strength and stability.
N.P.T. Multi-Form Thread Mills
