Tag Archive for: corner engagement
Harvey Tool Chamfer Cutters
  • Traditional Roughing
  • Slotting
  • Finishing
  • Contouring
  • Plunging
  • High Efficiency Milling
Material:
Application:
guide for proper end mill selection
Length of Cut & Reach
Tool Profile
end mill selection
  • Prolonged Tool life
  • Improved Chip Evacuation
Three Key Benefits
Indexing
Increased Feed Rates
Better Part Finish
Opt for a Smoother Operation
2 flute and 4 flute end mill
Front or Back
These tools are often offered in 2, 3, and 4 flute styles.  2 flute styles are normally used for aluminum and non-ferrous materials, although 3 flutes is quickly becoming a more popular choice for these materials, as they are softer than steels so a larger chip can be taken without an impact on tool life. 4 flutes should be chosen when machining steels to extend tool life by spreading out the wear over multiple teeth. 4 flute versions can also be run at higher feeds compared to 2 or 3 flute tools.
multiaxis machining
Corner Engagement
corner engagement
Generating an inside part radius that matches the radius of the tool with a sweeping direction change is a more desirable approach for corner engagement. The smaller radial depths of cut (RDOC) in this example help to manage the angle of engagement, but at the final pass, the tool will still experience a very high engagement angle.  Common results of this approach will be chatter, tool deflection/breakage and poor surface finish.
corner engagement effective approach
Most Effective Approach For Corner Engagement (Figure 3)
corner engagement
